Mesa 6i25 + 7i77 setup help needed
28 Apr 2016 21:46 #74021
by jsskangas
Mesa 6i25 + 7i77 setup help needed was created by jsskangas
Im new with this type, previously used 5i20 with different setups.
Im finding a lot difficulties to get my setup to run.
I tried ready setups wound in internet 5i25 + 7i77, not working even after taking watchdog lines out.
I tried to make new setup pnconf, not worked ether.
it crashes to first 7i77 parameter or signal.
Any quick tips how to get started?
28 Apr 2016 22:07 #74023
by BigJohnT
Replied by BigJohnT on topic Mesa 6i25 + 7i77 setup help needed
More information is needed "not work" does not help us understand at all.
Version of LinuxCNC
EXACT error.
JT
Version of LinuxCNC
EXACT error.
JT
28 Apr 2016 23:28 - 28 Apr 2016 23:29 #74036
Replied by PCW on topic Mesa 6i25 + 7i77 setup help needed
If the first parameter or signal is a 7I77 parameter, that suggests you have a power problem
I would check:
1. 7I77 5V source
2. 6I25 jumpered properly to match 7I77 5V source
For 6I25 powers 7I77 5V: 7I77 W5 LEFT, 6I25 W2 UP, TB1 unconnected
For external 7I77 5V power: 7I77 W5 RIGHT, 6I25 W2 DOWN, TB1 supplied with 5V
3. 7I77 Field power (8 to 32V)
I would check:
1. 7I77 5V source
Last edit: 28 Apr 2016 23:29 by PCW.
The following user(s) said Thank You: jsskangas
29 Apr 2016 07:24 #74045
by jsskangas
Replied by jsskangas on topic Mesa 6i25 + 7i77 setup help needed
Hello PCW.
I will check power jumpers setting.
Could be the reason, I was just quick checking components on table, will they work after got them from shipping.
Packet had seen some abuse(By Finnish postal service ), but you guys did packing really well.
29 Apr 2016 08:26 #74046
by jsskangas
OK
First problem solved, I had no Power from 6i25 to 7i77.
But still same same problem, first 7i77 signal not found.
Depian and 2.7.4 version linuxcnc.
I'm using some setup found from Internet, did not find anything included with linuxncn livecd.
Debug file information:
./7i77.hal:48: Pin 'hm2_5i25.0.7i77.0.0.input-00' does not exist
4312
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
4312
29 Apr 2016 08:35 #74047
by jsskangas
Hello
Got it working.
I did complete new HAL File with PnCConf, now up and running.
Problem was like you suggested power jumpers from 6i25 card.
Thanks for quick reply.
Got it working.
Time to create page: 0.142 seconds
