relays always on 5i25 with extra bit file ?
19 Jun 2016 14:38 #76284
by tkamsker
relays always on 5i25 with extra bit file ? was created by tkamsker
i created an bit file to not need to solder an cable for an bob straight forward. everything works ,
spindle on off speed (the left relais seem tho have a contact problem which i need to check but not relevant for that issue )
so when i exit linuxcnc
the relays jumps to on and the spindle runs full speed !!
so my question how do i debug that or better how do i set the gpio output to standard low ?
where is that behavior coming from ? (the bob is an ionicube4 from granite )
any hints would help me thx thomas
19 Jun 2016 14:44 #76285
Replied by PCW on topic relays always on 5i25 with extra bit file ?
5I25 outputs are high when idle so this is not something you can easily
fix in software/firmware.
Relays and spindle enables should be either active low or
(better) enabled by a charge pump/watchdog
19 Jun 2016 14:53 #76286
by tkamsker
Replied by tkamsker on topic relays always on 5i25 with extra bit file ?
Wow that was fast ,..
i started with the pncconf for basic and
i connected them to an gpio pin and this pin will then always be high when linuxcnc is not in charge
if linuxcnc is running the relays and such behaves so how do i overcome that high when idle ?
i think the config is working ok when linuxcnc is running (like it did when using the parallel board ) but maybe that means i have to switch the whole logic in the relays right ? but then the spindle will run as soon the machine is powered on and the the linux pc is not running ?
how are the others doing that ? or i am now totally mistaken ? thank you for your very fast answer
thx thomas
thx thomas
19 Jun 2016 15:02 #76287
It normally not an issue as things like spindles should have a charge pump
and all of our breakouts use active low for enables
All 5I25 pins will be high on startup or watchdog bite
20 Jun 2016 15:23 #76320
by cncbasher
Replied by cncbasher on topic relays always on 5i25 with extra bit file ?
one way is to use an additional relay , as an enable in series with the spindle fwd/rev common line ,
so if the relay input goes high then the relay contacts are then oc .
Time to create page: 0.073 seconds
