Sable-2015(G540) configuration with 5i25
06 Jul 2016 19:10 #77098
by C9cnc
Sable-2015(G540) configuration with 5i25 was created by C9cnc
I am trying to get my setup to turn some plastic.
I am new to Linux and CNCs in general but trying to move forward.
I have had some direction from Peter at Mesa but still not there. I have been able to use the Linux CNC and move around using the built in parallel port on the PC. So I know the hardware and PC are working. Just would like to use the 5i25 card.
I have done the following with no problems as Peter recommended using the G540 configuration as it was the same. I am using just he DB-25 connector on the 5i25 with no BOB.
sudo mesaflash --device 5i25 --write 5i25_g540x2.bit
and then to load the FPGA with the new information
sudo mesaflash --device 5i25 --reload
I was hoping then to use PnCConfig to use the documentation from the Sable-2015 to finish the configuration. If that is possible I am not seeing it. ??? Please advise.
Peter did send an .xml, an .ini and a .hal files that said would need to use a text editor to make all the changes to configure to the Sable 2015. Looking in these files I have no idea what lines need to be changed in them. I do know the configuration values for the Sable.
He indicated to place them in the ~/linuxcnc/configs path.
Was hoping to modify these files using the PnCConfig tool.
Any help for this newbie would be appreciated.
TIA,
Mark
TIA,
Mark
06 Jul 2016 19:18 #77100
Replied by andypugh on topic Sable-2015(G540) configuration with 5i25
PnCConf is a one-way tool. It creates a config from its internal data, but can't populate its internal data from a config.
The INI file is moderately comprehensible:
linuxcnc.org/docs/2.7/html/config/ini-config.html
The HAL file ought to be almost self explanatory. Note that the HAL file reads values from the INI using [SECTION]VARIABLE format.
06 Jul 2016 19:39 #77102
by C9cnc
Replied by C9cnc on topic Sable-2015(G540) configuration with 5i25
Ok, I will attempt to make the changes and try to get the axis's to all move properly.
Then I will need to add my abort and limit switches in to the configuration. Electrically that is easy for me.
Thanks for your time.
Time to create page: 0.182 seconds
