Spindle PID 5i25+7i77
19 Aug 2016 11:42 #79046 by dinkata
LinuxCNC 2.7.6 , configuration 5i25+7i77 Lathe X,Z ,spindle encoder. with PnCConf Wizard :
#  SPINDLE S
setp   pid.s.Pgain     [SPINDLE_9]P
setp   pid.s.Igain     [SPINDLE_9]I
setp   pid.s.Dgain     [SPINDLE_9]D
setp   pid.s.bias      [SPINDLE_9]BIAS
setp   pid.s.FF0       [SPINDLE_9]FF0
setp   pid.s.FF1       [SPINDLE_9]FF1
setp   pid.s.FF2       [SPINDLE_9]FF2
setp   pid.s.deadband  [SPINDLE_9]DEADBAND
setp   pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp   pid.s.error-previous-target true
net spindle-index-enable  <=> pid.s.index-enable
net spindle-enable        =>  pid.s.enable
net spindle-vel-cmd-rpm   => pid.s.command
net spindle-vel-fb-rpm    => pid.s.feedback
net spindle-output        <=  pid.s.output
# ---PWM Generator signals/setup---
setp   hm2_5i25.0.7i77.0.1.analogout5-scalemax  [SPINDLE_9]OUTPUT_SCALE
setp   hm2_5i25.0.7i77.0.1.analogout5-minlim    [SPINDLE_9]OUTPUT_MIN_LIMIT
setp   hm2_5i25.0.7i77.0.1.analogout5-maxlim    [SPINDLE_9]OUTPUT_MAX_LIMIT
net spindle-output      => hm2_5i25.0.7i77.0.1.analogout5
net spindle-enable      => hm2_5i25.0.7i77.0.1.spinena
setp    hm2_5i25.0.encoder.02.counter-mode 0
setp    hm2_5i25.0.encoder.02.filter 1
setp    hm2_5i25.0.encoder.02.index-invert 0
setp    hm2_5i25.0.encoder.02.index-mask 0
setp    hm2_5i25.0.encoder.02.index-mask-invert 0
setp    hm2_5i25.0.encoder.02.scale  [SPINDLE_9]ENCODER_SCALE
net spindle-revs             <=   hm2_5i25.0.encoder.02.position
net spindle-vel-fb-rps       <=   hm2_5i25.0.encoder.02.velocity
net spindle-index-enable     <=>  hm2_5i25.0.encoder.02.index-enable
net spindle-vel-cmd-rps        <=  motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs    <=  motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm        <=  motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs    <=  motion.spindle-speed-out-abs
net spindle-enable             <=  motion.spindle-on   => parport.0.pin-01-out
net spindle-cw                 <=  motion.spindle-forward
net spindle-ccw                <=  motion.spindle-reverse
net spindle-brake              <=  motion.spindle-brake
net spindle-revs               =>  motion.spindle-revs
net spindle-at-speed           =>  motion.spindle-at-speed
net spindle-vel-fb-rps         =>  motion.spindle-speed-in
net spindle-index-enable      <=>  motion.spindle-index-enable
net spindle-vel-cmd-rps    =>  near.0.in1
net spindle-vel-fb-rps     =>  near.0.in2
net spindle-at-speed       <=  near.0.out
setp near.0.scale 1.000000
setp near.0.difference 20.00
net spindle-vel-fb-rps <= hm2_5i25.0.encoder.02.velocity #### ???
net spindle-vel-fb-rpm => pid.s.feedback ##### ?????
net spindle-vel-fb-rpm ### Where can i find it
19 Aug 2016 14:09 - 19 Aug 2016 14:10 #79076 by andypugh
Replied by andypugh on topic Spindle PID 5i25+7i77
It's a signal. Signal names have no special meaning, you can use any names you want. (feel free to use your native language for them, for example).
However, as this is a PnCConf config, the names have not been chosen by you.
I don't know why PnCConf has configured things that way. The PID component ought to work perfectly with both command and feedback using the -rps signal.
Is there a "scale" component created anywhere in the HAL?
Last edit: 19 Aug 2016 14:10 by andypugh.
The following user(s) said Thank You: dinkata
19 Aug 2016 16:16 #79079 by dinkata
Replied by dinkata on topic Spindle PID 5i25+7i77
aha ,I remembered PnCConf in Linuxcnc2.7.3
loadrt scale names=scale.spindle
addf scale.spindle            servo-thread
 setp     scale.spindle.gain 60
maybe this will help :
     net spindle-vel-fb-rps <= hm2_5i25.0.encoder.02.velocity  => scale.spindle.in
     net spindle-fb-rpm  <=     scale.spindle.out   => pid.s.feedback
Time to create page: 0.065 seconds
