pncconfig and usb to gs2 problem - solved
23 Aug 2016 00:25 - 03 Sep 2016 03:34 #79287
by calvin.d
pncconfig and usb to gs2 problem - solved was created by calvin.d
so I have this working ish but I want to bring up 2 items
1. when setting up gs2 vfd inside of pncconf having the ability to declare the device in my case /dev/ttyUSB0 would be very help full. providing the a list of the /dev/ttys... and /dev/ttyUSB... would be great
2. when follow the setup instruction the vfd would change direct ccw vs cw but would not go into run, I looked at the pin states and for some reason spindle-vfd.spindle-on is not going high. I used sim-pin and pulled it high and all of he sudden the vfd started working
any thoughts on why ?
I am adding my vfd config and machine config that were created by pnconf the only manual change that I have made is to change the device id in the gs2-vfd.hal to /ttyUSB0
Thank you for the help
C
C
Last edit: 03 Sep 2016 03:34 by calvin.d.
03 Sep 2016 03:31 #79951
by calvin.d
Replied by calvin.d on topic pncconfig and usb to gs2 problem
so i figured this out
in the gs2-vfd config i had to change
net spindle-on => spindle-vfd.spindle-on
to
net spindle-enable => spindle-vfd.spindle-on
once i made this change it all works correctly now
just in case anyone runs into this problem
C
to
C
Time to create page: 0.081 seconds
