kernel_version error in PnCConf with 7I76E
05 Sep 2016 22:01 #80060
by Rogla
kernel_version error in PnCConf with 7I76E was created by Rogla
Using this kernel:
roger@linuxcnc:~/linuxcnc/configs/millton$ uname -a
Linux linuxcnc 3.2.0-4-rt-amd64 #1 SMP PREEMPT RT Debian 3.2.81-1 x86_64 GNU/Linux
I get following error on "Test/Tune Axis" in PnCConf:
"Traceback (most recent call last):
File "/usr/lib/pymodules/python2.7/pncconf/pages.py", line 1068, in on_xaxistune_clicked
def on_xaxistune_clicked(self, *args): self.t.tune_axis('x')
File "/usr/lib/pymodules/python2.7/pncconf/tests.py", line 463, in tune_axis
if not self.a.check_for_rt():
File "/usr/bin/pncconf", line 1640, in check_for_rt
elif hal.is_rt and not hal.kernel_version == actual_kernel:
AttributeError: 'module' object has no attribute 'kernel_version'"
Any idea how to resolve this?
Add some kernel_version attribute to the ini file?
30 Sep 2016 01:58 #81095
by atrox1333
Replied by atrox1333 on topic kernel_version error in PnCConf with 7I76E
I have the same setup and I am getting the same error when I try to use PnCConf with 7i76E
The machine works fine with the numbers I put in the .ini file by hand.
When I try to use the axis tuning window button in PnCConf.
The tuning configure window never comes up and I get the same error as Rogla
Can someone give a hint to fix this?
30 Sep 2016 14:02 #81109
Replied by PCW on topic kernel_version error in PnCConf with 7I76E
This has be discussed on the LinuxCNC developers list
PnCConf needs to be taught that the kernel version doesn't matter on Preempt-RT kernels
30 Sep 2016 17:14 #81114
by atrox1333
Rogla
It appears the developers are aware of this issue.
It may be issue 159
github.com/LinuxCNC/linuxcnc/issues/159
Thanks to the developers
It may be issue 159
30 Sep 2016 19:26 #81116
by Rogla
Replied by Rogla on topic kernel_version error in PnCConf with 7I76E
Great!
Many thanks to both of you for leting us know and for diging up the relevant thread.
01 Oct 2016 03:26 - 01 Oct 2016 03:28 #81124
As a temporary work around you could edit your file directly:
in /usr/bin/pncconf just after line 1632
add the line return True
Chris M
Replied by cmorley on topic kernel_version error in PnCConf with 7I76E
Using this kernel:
# check for realtime kernel
def check_for_rt(self):
return True
Chris M
Last edit: 01 Oct 2016 03:28 by cmorley. Reason: forgot True command
The following user(s) said Thank You: Rogla
01 Oct 2016 10:53 #81128
by Rogla
Thanks for the effort, appreciate it!
Time to create page: 0.149 seconds
