7i80HD-25 configuration
08 Dec 2016 17:18 #83785
by mikikg
7i80HD-25 configuration was created by mikikg
Hello everybody,
I'm new member of this forum and new user of Mesa cards.
I have 7i80HD-25 card and would like to configure it to work for 6 axis step/dir generator which will drive servo motors with own drivers, so in this phase I need just basic example how to configure and run this card trough LinuxCNC.
At a moment I do not have servos with me, I have scope which I will use to check generated pulses.
Any advice where to start, or how to configure this card with PnCconfig as I don't see this card model in drop-down list, is there any alternative firmware for other cards which can be used just for this kind of tests?
Tnx in advance.
Tnx in advance.
08 Dec 2016 17:37 #83787
Replied by andypugh on topic 7i80HD-25 configuration
Are you intending to use it with any particular daughter cards, or are you going to connect directly to the headers?
You might have to pretend that the card is something else, and then edit the config files (the files are human-readable and are intended for hand-editing, PnCConf is only a tool to make putting together a basic configuration easier)
Do you know which firmware is on the card at the moment?
08 Dec 2016 17:57 #83789
by mikikg
Replied by mikikg on topic 7i80HD-25 configuration
At a moment I will connect directly to headers, later (temporary) will use custom interface in between servo drivers and lastly will probably switch to Mesa's daughter interface card.
Card currently have default firmware, didn't change that yet, don't know what is default.
My goal in this phase is just to see some electrical pulses on output pins on headers so looking for quite simple procedure to get that.
Of course I need to look and explore many more details on this matter, just looking for some firs step.
I have long-term experience in electronic and programming (mostly industrial) but I'm working with Mesa for first time.
08 Dec 2016 18:17 #83790
I think it depends on what you ordered.
There may be a sticker on the board that tells you.
Otherwise you need to use the mesaflash tool and the --redhmid switch to see what is on there.
08 Dec 2016 18:55 #83793
by mikikg
With following command:
I got this response:
Anyway can I use current HOSTMOT2 firmware for testing?
mesaflash --readhmid --addr 192.168.1.121 --device 7i80
Configuration Name: HOSTMOT2
BoardName : MESA7I80
FPGA Size: 25 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 24
08 Dec 2016 19:25 #83794
Was that everything?
No sticker?
No sticker?
08 Dec 2016 19:33 #83795
by mikikg
Those command return lots more information, I just paste first several lines, do you want me to paste whole info?
There are few stickers on PCB, only shows model "7i80HD-25", MAC address, lot number and some bar-codes.
08 Dec 2016 19:48 #83797
The extra information will indicate whether the board is programmed for stepper, servos or a mix.
08 Dec 2016 19:58 #83799
by mikikg
Here is whole output of command:
FPGA Pins: 256
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3500
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: PWM
There are 6 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4000
ClockFrequency: 200.000 MHz
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5A00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P1
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort PWM 0 /Enable (Out)
3 1 IOPort MuxedQCount 0 MuxQ-A (In)
5 2 IOPort MuxedQCount 0 MuxQ-B (In)
7 3 IOPort MuxedQCount 0 MuxQ-IDX (In)
9 4 IOPort MuxedQCount 1 MuxQ-A (In)
11 5 IOPort MuxedQCount 1 MuxQ-B (In)
13 6 IOPort MuxedQCount 1 MuxQ-IDX (In)
15 7 IOPort MuxedQCount 2 MuxQ-A (In)
17 8 IOPort MuxedQCount 2 MuxQ-B (In)
19 9 IOPort MuxedQCount 2 MuxQ-IDX (In)
21 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
23 11 IOPort PWM 0 PWM (Out)
25 12 IOPort PWM 0 Dir (Out)
27 13 IOPort PWM 1 PWM (Out)
29 14 IOPort PWM 1 Dir (Out)
31 15 IOPort PWM 2 PWM (Out)
33 16 IOPort PWM 2 Dir (Out)
35 17 IOPort PWM 3 PWM (Out)
37 18 IOPort PWM 3 Dir (Out)
39 19 IOPort PWM 4 PWM (Out)
41 20 IOPort PWM 4 Dir (Out)
43 21 IOPort PWM 5 PWM (Out)
45 22 IOPort PWM 5 Dir (Out)
47 23 IOPort PWM 0 /Enable (Out)
IO Connections for P2
1 24 IOPort None
3 25 IOPort None
5 26 IOPort None
7 27 IOPort None
9 28 IOPort None
11 29 IOPort None
13 30 IOPort None
15 31 IOPort None
17 32 IOPort None
19 33 IOPort None
21 34 IOPort None
23 35 IOPort None
25 36 IOPort None
27 37 IOPort None
29 38 IOPort None
31 39 IOPort None
33 40 IOPort None
35 41 IOPort None
37 42 IOPort None
39 43 IOPort None
41 44 IOPort None
43 45 IOPort None
45 46 IOPort None
47 47 IOPort None
IO Connections for P3
1 48 IOPort SSerial 0 RXData1 (In)
3 49 IOPort SSerial 0 RXData2 (In)
5 50 IOPort SSerial 0 RXData3 (In)
7 51 IOPort SSerial 0 RXData4 (In)
9 52 IOPort SSerial 0 TXData1 (Out)
11 53 IOPort SSerial 0 TXEn1 (Out)
13 54 IOPort SSerial 0 TXData2 (Out)
15 55 IOPort SSerial 0 TXEn2 (Out)
17 56 IOPort SSerial 0 TXData3 (Out)
19 57 IOPort SSerial 0 TXEn3 (Out)
21 58 IOPort SSerial 0 TXData4 (Out)
23 59 IOPort SSerial 0 TXEn4 (Out)
25 60 IOPort SSerial 0 RXData5 (In)
27 61 IOPort SSerial 0 RXData6 (In)
29 62 IOPort SSerial 0 RXData7 (In)
31 63 IOPort SSerial 0 RXData8 (In)
33 64 IOPort SSerial 0 TXData5 (Out)
35 65 IOPort SSerial 0 TXEn5 (Out)
37 66 IOPort SSerial 0 TXData6 (Out)
39 67 IOPort SSerial 0 TXEn6 (Out)
41 68 IOPort SSerial 0 TXData7 (Out)
43 69 IOPort SSerial 0 TXEn7 (Out)
45 70 IOPort SSerial 0 TXData8 (Out)
47 71 IOPort SSerial 0 TXEn8 (Out)
08 Dec 2016 20:11 #83804
Replied by PCW on topic 7i80HD-25 configuration
That config has no step generators
7i80hd_25_st18.bit
is a good 7I80HD25 config to test stepgens with
it has 18 step generators wired to P1 and 1/2 of P2
7i80hd_25_st18.bit
Time to create page: 0.296 seconds
