Newbee Lost on setting !
21 Dec 2016 16:26 #84498 by WhyMe1
Dell D620 with Docking Station for Parallel port . LinuxCNC2.5
Is this right ? Pncconf is to set up the parallel port in LinCNC and Mesa is type or hardware/software used for parallel port,In my case Dell Docking station and daughter board is the Controller board in my case 5 axis bl-mach-v1.1 (china one I will only be using 3axiz )
I have I/O control port board set for 5i20 but lost on Firmware pick also ?
21 Dec 2016 16:31 #84499 by PCW
Replied by PCW on topic Newbee Lost on setting !
If you have a parallel port based system. you should use stepconf, not pncconf
pncconf is for Mesa hardware.
21 Dec 2016 18:52 #84510 by WhyMe1
Replied by WhyMe1 on topic Newbee Lost on setting !
Thank You - Wow I must need a new Light Bulb I over look that one .
Time to create page: 0.062 seconds
