Mesa 7i92M Support
- tuffduck33
07 Mar 2017 20:06 #89158
by tuffduck33
Replied by tuffduck33 on topic Mesa 7i92M Support
Would the original stepgen files help? They worked before the parallel port died and I added the 7i92.
- Thank you received: 5918
07 Mar 2017 20:12 #89159
Replied by tommylight on topic Mesa 7i92M Support
They might, so please do attach them.
Thanks.
Thanks.
- tuffduck33
07 Mar 2017 20:44 #89165
by tuffduck33
Here are those files.
The following user(s) said Thank You: looping
07 Mar 2017 21:08 #89168
A stab in the dark, but you have no PWM in that config for spindle speed, if i am not mistaken you mentioned that, so you do need spindle control, right? Do you have a VFD?
- tuffduck33
07 Mar 2017 21:30 #89171
by tuffduck33
I have a VFD but it is not connected to the G540. Never could get it work. Is there a way to do that with the 7i92?
07 Mar 2017 22:23 #89175
Here you go, all set, even the ini file should be as you need it ( why was your max velocity 2 inch per minute and your x axis travel over 1200 inches??? That would make for a loooong wait ! )
Make sure you have the 7i92_g540something.bit flashed on the board, right click on the ini file and choose open with >linuxcnc.
- tuffduck33
07 Mar 2017 23:30 - 08 Mar 2017 19:48 #89180
by tuffduck33
Hi Tom,
I must have changed those settings at some point---It wasn't slow a few wees ago.lol I followed our instructions and I received a message box. It is as follows:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.8
Machine configuration directory is '/home/debian/linuxcnc/configs/tuffduck'
Machine configuration file is 'tuffduck.ini'
INIFILE=/home/debian/linuxcnc/configs/tuffduck/tuffduck.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./tuffduck.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=8237
Debug file information:
Note: Using POSIX realtime
Unknown parameter `coordinates=XYZ'
./tuffduck.hal:5: waitpid failed /usr/bin/rtapi_app trivkins
./tuffduck.hal:5: /usr/bin/rtapi_app exited without becoming ready
./tuffduck.hal:5: insmod for trivkins failed, returned -1
8237
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-4-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT RT Debian 3.2.84-2
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-rt-amd64 root=UUID=5560c829-04ed-4b61-abe3-96fa16ed530d ro initrd=/install/gtk/initrd.gz quiet
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000bfe4a000 (usable)
[ 0.000000] BIOS-e820: 00000000bfe4a000 - 00000000bfee9000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bfee9000 - 00000000bfeed000 (usable)
[ 0.000000] BIOS-e820: 00000000bfeed000 - 00000000bfeff000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000bfeff000 - 00000000bff00000 (usable)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: /D945GTP, BIOS NT94510J.86A.2487.2005.0906.1451 09/06/2005
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] No AGP bridge found
[ 0.000000] last_pfn = 0xbff00 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 080000000 mask FC0000000 write-back
[ 0.000000] 2 base 0BFF00000 mask FFFF00000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [ffff8800000fe680] fe680
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] Base memory trampoline at [ffff88000009a000] 9a000 size 20480
[ 0.000000] init_memory_mapping: 0000000000000000-00000000bff00000
[ 0.000000] 0000000000 - 00bfe00000 page 2M
[ 0.000000] 00bfe00000 - 00bff00000 page 4k
[ 0.000000] kernel direct mapping tables up to bff00000 @ 1fffb000-20000000
[ 0.000000] RAMDISK: 36ba8000 - 375cc000
[ 0.000000] ACPI: RSDP 0x00000000000FE020 00014 (v00 INTEL )
[ 0.000000] ACPI: RSDT 0x00000000BFEFDE48 00034 (v01 INTEL D945GTP 000009B7 MSFT 01000013)
[ 0.000000] ACPI: FACP 0x00000000BFEFCF10 00074 (v01 INTEL D945GTP 000009B7 MSFT 01000013)
[ 0.000000] ACPI: DSDT 0x00000000BFEF8010 03FBC (v01 INTEL D945GTP 000009B7 MSFT 01000013)
[ 0.000000] ACPI: FACS 0x00000000BFEE5C40 00040
[ 0.000000] ACPI: APIC 0x00000000BFEFCE10 00078 (v01 INTEL D945GTP 000009B7 MSFT 01000013)
[ 0.000000] ACPI: WDDT 0x00000000BFEF7F90 00040 (v01 INTEL D945GTP 000009B7 MSFT 01000013)
[ 0.000000] ACPI: MCFG 0x00000000BFEF7F10 0003C (v01 INTEL D945GTP 000009B7 MSFT 01000013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at 0000000000000000-00000000bff00000
[ 0.000000] Initmem setup node 0 0000000000000000-00000000bff00000
[ 0.000000] NODE_DATA [00000000bfe45000 - 00000000bfe49fff]
[ 0.000000] [ffffea0000000000-ffffea00029fffff] PMD -> [ffff8800bc600000-ffff8800beffffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal empty
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[4] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x000bfe4a
[ 0.000000] 0: 0x000bfee9 -> 0x000bfeed
[ 0.000000] 0: 0x000bfeff -> 0x000bff00
[ 0.000000] On node 0 totalpages: 785886
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 5 pages reserved
[ 0.000000] DMA zone: 3922 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 10693 pages used for memmap
[ 0.000000] DMA32 zone: 771210 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 00000000bfe4a000 - 00000000bfee9000
[ 0.000000] PM: Registered nosave memory: 00000000bfeed000 - 00000000bfeff000
[ 0.000000] Allocating PCI resources starting at bff00000 (gap: bff00000:40100000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 107 pages/cpu @ffff8800bfa00000 s409408 r8192 d20672 u524288
[ 0.000000] pcpu-alloc: s409408 r8192 d20672 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 775132
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-rt-amd64 root=UUID=5560c829-04ed-4b61-abe3-96fa16ed530d ro initrd=/install/gtk/initrd.gz quiet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Checking aperture...
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 3079172k/3144704k available (3532k kernel code, 1160k absent, 64372k reserved, 3239k data, 916k init)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:33024 nr_irqs:712 16
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2800.058 MHz processor.
[ 0.004005] Calibrating delay loop (skipped), value calculated using timer frequency.. 5600.11 BogoMIPS (lpj=11200232)
[ 0.004011] pid_max: default: 32768 minimum: 301
[ 0.008038] Security Framework initialized
[ 0.008046] AppArmor: AppArmor disabled by boot time parameter
[ 0.009571] Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.014832] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.016122] Mount-cache hash table entries: 256
[ 0.016356] Initializing cgroup subsys cpuacct
[ 0.016364] Initializing cgroup subsys memory
[ 0.016386] Initializing cgroup subsys devices
[ 0.016389] Initializing cgroup subsys freezer
[ 0.016392] Initializing cgroup subsys net_cls
[ 0.016395] Initializing cgroup subsys blkio
[ 0.016408] Initializing cgroup subsys perf_event
[ 0.016473] CPU: Physical Processor ID: 0
[ 0.016476] CPU: Processor Core ID: 0
[ 0.016479] mce: CPU supports 4 MCE banks
[ 0.016494] CPU0: Thermal monitoring enabled (TM1)
[ 0.016501] using mwait in idle threads.
[ 0.017212] ACPI: Core revision 20110623
[ 0.022475] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.062173] CPU0: Intel(R) Pentium(R) D CPU 2.80GHz stepping 04
[ 0.064003] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.064003] ... version: 0
[ 0.064003] ... bit width: 40
[ 0.064003] ... generic registers: 18
[ 0.064003] ... value mask: 000000ffffffffff
[ 0.064003] ... max period: 0000007fffffffff
[ 0.064003] ... fixed-purpose events: 0
[ 0.064003] ... event mask: 000000000003ffff
[ 0.080296] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.100060] Booting Node 0, Processors #1
[ 0.100067] smpboot cpu 1: start_ip = 9a000
[ 0.196081] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.200030] Brought up 2 CPUs
[ 0.200036] Total of 2 processors activated (11200.53 BogoMIPS).
[ 0.201074] devtmpfs: initialized
[ 0.205743] PM: Registering ACPI NVS region at bfe4a000 (651264 bytes)
[ 0.206248] print_constraints: dummy:
[ 0.206424] NET: Registered protocol family 16
[ 0.206737] ACPI: bus type pci registered
[ 0.206925] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xf0000000-0xffffffff] (base 0xf0000000)
[ 0.206931] PCI: not using MMCONFIG
[ 0.206935] PCI: Using configuration type 1 for base access
[ 0.209259] bio: create slab <bio-0> at 0
[ 0.209259] ACPI: Added _OSI(Module Device)
[ 0.209259] ACPI: Added _OSI(Processor Device)
[ 0.209259] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.209259] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.210103] ACPI: EC: Look up EC in DSDT
[ 0.217594] ACPI: Interpreter enabled
[ 0.217603] ACPI: (supports S0 S1 S4 S5)
[ 0.217686] ACPI: Using IOAPIC for interrupt routing
[ 0.217750] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xf0000000-0xffffffff] (base 0xf0000000)
[ 0.220381] PCI: MMCONFIG at [mem 0xf0000000-0xffffffff] reserved in ACPI motherboard resources
[ 0.220389] PCI: MMCONFIG for 0000 [bus00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000) (size reduced!)
[ 0.239529] ACPI: No dock devices found.
[ 0.239534] HEST: Table not found.
[ 0.239540] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.243342] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.250961] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.250968] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.250973] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.250978] pci_root PNP0A03:00: host bridge window [mem 0x000e0000-0x000effff] (ignored)
[ 0.250982] pci_root PNP0A03:00: host bridge window [mem 0xf8000000-0xfebfffff] (ignored)
[ 0.250987] pci_root PNP0A03:00: host bridge window [mem 0xc0000000-0xf0000000] (ignored)
[ 0.251008] pci 0000:00:00.0: [8086:2770] type 0 class 0x000600
[ 0.251088] pci 0000:00:01.0: [8086:2771] type 1 class 0x000604
[ 0.251158] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.251225] pci 0000:00:1c.0: [8086:27d0] type 1 class 0x000604
[ 0.251322] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.251364] pci 0000:00:1c.2: [8086:27d4] type 1 class 0x000604
[ 0.251460] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.251499] pci 0000:00:1c.3: [8086:27d6] type 1 class 0x000604
[ 0.251594] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.251633] pci 0000:00:1d.0: [8086:27c8] type 0 class 0x000c03
[ 0.251686] pci 0000:00:1d.0: reg 20: [io 0x2080-0x209f]
[ 0.251735] pci 0000:00:1d.1: [8086:27c9] type 0 class 0x000c03
[ 0.251788] pci 0000:00:1d.1: reg 20: [io 0x2060-0x207f]
[ 0.251836] pci 0000:00:1d.2: [8086:27ca] type 0 class 0x000c03
[ 0.251889] pci 0000:00:1d.2: reg 20: [io 0x2040-0x205f]
[ 0.251937] pci 0000:00:1d.3: [8086:27cb] type 0 class 0x000c03
[ 0.251990] pci 0000:00:1d.3: reg 20: [io 0x2020-0x203f]
[ 0.252075] pci 0000:00:1d.7: [8086:27cc] type 0 class 0x000c03
[ 0.252102] pci 0000:00:1d.7: reg 10: [mem 0xd2100000-0xd21003ff]
[ 0.252206] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.252240] pci 0000:00:1e.0: [8086:244e] type 1 class 0x000604
[ 0.252334] pci 0000:00:1f.0: [8086:27b8] type 0 class 0x000601
[ 0.252441] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[ 0.252455] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0680 (mask 007f)
[ 0.252518] pci 0000:00:1f.1: [8086:27df] type 0 class 0x000101
[ 0.252536] pci 0000:00:1f.1: reg 10: [io 0x0000-0x0007]
[ 0.252549] pci 0000:00:1f.1: reg 14: [io 0x0000-0x0003]
[ 0.252562] pci 0000:00:1f.1: reg 18: [io 0x0000-0x0007]
[ 0.252574] pci 0000:00:1f.1: reg 1c: [io 0x0000-0x0003]
[ 0.252587] pci 0000:00:1f.1: reg 20: [io 0x20b0-0x20bf]
[ 0.252640] pci 0000:00:1f.2: [8086:27c0] type 0 class 0x000101
[ 0.252660] pci 0000:00:1f.2: reg 10: [io 0x20c8-0x20cf]
[ 0.252672] pci 0000:00:1f.2: reg 14: [io 0x20e4-0x20e7]
[ 0.252683] pci 0000:00:1f.2: reg 18: [io 0x20c0-0x20c7]
[ 0.252695] pci 0000:00:1f.2: reg 1c: [io 0x20e0-0x20e3]
[ 0.252706] pci 0000:00:1f.2: reg 20: [io 0x20a0-0x20af]
[ 0.252754] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.252785] pci 0000:00:1f.3: [8086:27da] type 0 class 0x000c05
[ 0.252848] pci 0000:00:1f.3: reg 20: [io 0x2000-0x201f]
[ 0.252960] pci 0000:01:00.0: [10de:01d1] type 0 class 0x000300
[ 0.252976] pci 0000:01:00.0: reg 10: [mem 0xd1000000-0xd1ffffff]
[ 0.252992] pci 0000:01:00.0: reg 14: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.253008] pci 0000:01:00.0: reg 1c: [mem 0xd0000000-0xd0ffffff 64bit]
[ 0.253026] pci 0000:01:00.0: reg 30: [mem 0xfffe0000-0xffffffff pref]
[ 0.253083] pci 0000:01:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.253095] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.253103] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xd1ffffff]
[ 0.253110] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.253165] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.253174] pci 0000:00:1c.0: bridge window [mem 0xd2200000-0xd22fffff]
[ 0.253238] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
[ 0.253247] pci 0000:00:1c.2: bridge window [mem 0xd2300000-0xd23fffff]
[ 0.253306] pci 0000:00:1c.3: PCI bridge to [bus 04-04]
[ 0.253315] pci 0000:00:1c.3: bridge window [mem 0xd2400000-0xd24fffff]
[ 0.253381] pci 0000:05:05.0: [104c:8024] type 0 class 0x000c00
[ 0.253405] pci 0000:05:05.0: reg 10: [mem 0xd2005000-0xd20057ff]
[ 0.253419] pci 0000:05:05.0: reg 14: [mem 0xd2000000-0xd2003fff]
[ 0.253507] pci 0000:05:05.0: supports D1 D2
[ 0.253510] pci 0000:05:05.0: PME# supported from D0 D1 D2 D3hot
[ 0.253546] pci 0000:05:08.0: [8086:27dc] type 0 class 0x000200
[ 0.253569] pci 0000:05:08.0: reg 10: [mem 0xd2004000-0xd2004fff]
[ 0.253583] pci 0000:05:08.0: reg 14: [io 0x1000-0x103f]
[ 0.253666] pci 0000:05:08.0: supports D1 D2
[ 0.253669] pci 0000:05:08.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.253718] pci 0000:00:1e.0: PCI bridge to [bus 05-05] (subtractive decode)
[ 0.253724] pci 0000:00:1e.0: bridge window [io 0x1000-0x1fff]
[ 0.253730] pci 0000:00:1e.0: bridge window [mem 0xd2000000-0xd20fffff]
[ 0.253741] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.253746] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xfffffffff] (subtractive decode)
[ 0.253780] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.254646] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P32_._PRT]
[ 0.255635] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
[ 0.255898] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX2._PRT]
[ 0.256191] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX3._PRT]
[ 0.256577] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.256585] pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
[ 0.256589] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.272967] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.273206] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.273439] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.273672] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.273904] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.274138] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.274378] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.274613] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 *9 10 11 12)
[ 0.274866] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.274866] vgaarb: loaded
[ 0.274866] vgaarb: bridge control possible 0000:01:00.0
[ 0.274866] PCI: Using ACPI for IRQ routing
[ 0.277007] PCI: pci_cache_line_size set to 64 bytes
[ 0.277175] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.277181] reserve RAM buffer: 00000000bfe4a000 - 00000000bfffffff
[ 0.277186] reserve RAM buffer: 00000000bfeed000 - 00000000bfffffff
[ 0.277191] reserve RAM buffer: 00000000bff00000 - 00000000bfffffff
[ 0.277593] hpet clockevent registered
[ 0.277602] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.277609] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.277619] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.284074] AMD NB: Cannot enumerate AMD northbridges.
[ 0.284080] Switching to clocksource hpet
[ 0.292204] pnp: PnP ACPI init
[ 0.292248] ACPI: bus type pnp registered
[ 0.296070] pnp 00:00: [bus 00-ff]
[ 0.296077] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.296082] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.296087] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.296092] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.296097] pnp 00:00: [mem 0x000e0000-0x000effff window]
[ 0.296103] pnp 00:00: [mem 0xf8000000-0xfebfffff window]
[ 0.296107] pnp 00:00: [mem 0xc0000000-0xf0000000 window]
[ 0.296225] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.296267] pnp 00:01: [mem 0xf0000000-0xf3ffffff]
[ 0.296273] pnp 00:01: [mem 0xfed13000-0xfed13fff]
[ 0.296277] pnp 00:01: [mem 0xfed14000-0xfed17fff]
[ 0.296282] pnp 00:01: [mem 0xfed18000-0xfed18fff]
[ 0.296286] pnp 00:01: [mem 0xfed19000-0xfed19fff]
[ 0.296290] pnp 00:01: [mem 0xfed1c000-0xfed1ffff]
[ 0.296295] pnp 00:01: [mem 0xfed20000-0xfed9ffff]
[ 0.296299] pnp 00:01: [mem 0x000c0000-0x000dffff]
[ 0.296304] pnp 00:01: [mem 0x000e0000-0x000fffff]
[ 0.296456] system 00:01: [mem 0xf0000000-0xf3ffffff] has been reserved
[ 0.296463] system 00:01: [mem 0xfed13000-0xfed13fff] has been reserved
[ 0.296470] system 00:01: [mem 0xfed14000-0xfed17fff] has been reserved
[ 0.296476] system 00:01: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.296482] system 00:01: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.296488] system 00:01: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.296494] system 00:01: [mem 0xfed20000-0xfed9ffff] has been reserved
[ 0.296501] system 00:01: [mem 0x000c0000-0x000dffff] could not be reserved
[ 0.296508] system 00:01: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.296515] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.297035] pnp 00:02: [io 0x0000-0x000f]
[ 0.297041] pnp 00:02: [io 0x0081-0x0083]
[ 0.297045] pnp 00:02: [io 0x0087]
[ 0.297050] pnp 00:02: [io 0x0089-0x008b]
[ 0.297054] pnp 00:02: [io 0x008f]
[ 0.297058] pnp 00:02: [io 0x00c0-0x00df]
[ 0.297063] pnp 00:02: [dma 4]
[ 0.297150] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.297189] pnp 00:03: [io 0x0070-0x0071]
[ 0.297194] pnp 00:03: [io 0x0074-0x0077]
[ 0.297210] pnp 00:03: [irq 8]
[ 0.297288] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.297329] pnp 00:04: [io 0x00f0]
[ 0.297344] pnp 00:04: [irq 13]
[ 0.297425] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.297468] pnp 00:05: [io 0x0061]
[ 0.297552] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.297586] pnp 00:06: [io 0x0500-0x053f]
[ 0.297591] pnp 00:06: [io 0x0400-0x047f]
[ 0.297595] pnp 00:06: [io 0x0092]
[ 0.297600] pnp 00:06: [io 0x0680-0x06ff]
[ 0.297604] pnp 00:06: [io 0x0010-0x001f]
[ 0.297608] pnp 00:06: [io 0x0072-0x0073]
[ 0.297613] pnp 00:06: [io 0x0080]
[ 0.297617] pnp 00:06: [io 0x0084-0x0086]
[ 0.297621] pnp 00:06: [io 0x0088]
[ 0.297625] pnp 00:06: [io 0x008c-0x008e]
[ 0.297629] pnp 00:06: [io 0x0090-0x009f]
[ 0.297784] system 00:06: [io 0x0500-0x053f] has been reserved
[ 0.297792] system 00:06: [io 0x0400-0x047f] could not be reserved
[ 0.297798] system 00:06: [io 0x0680-0x06ff] has been reserved
[ 0.297805] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.298374] pnp 00:07: [irq 12]
[ 0.298459] pnp 00:07: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
[ 0.298536] pnp 00:08: [io 0x0060]
[ 0.298541] pnp 00:08: [io 0x0064]
[ 0.298550] pnp 00:08: [irq 1]
[ 0.298639] pnp 00:08: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.299055] pnp 00:09: [io 0x03f8-0x03ff]
[ 0.299065] pnp 00:09: [irq 4]
[ 0.299263] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.299508] pnp 00:0a: [mem 0xfec00000-0xfec000ff]
[ 0.299602] pnp 00:0a: Plug and Play ACPI device, IDs PNP0003 (active)
[ 0.299726] pnp: PnP ACPI: found 11 devices
[ 0.299730] ACPI: ACPI bus type pnp unregistered
[ 0.310991] pci 0000:01:00.0: no compatible bridge window for [mem 0xfffe0000-0xffffffff pref]
[ 0.311007] PCI: max bus depth: 1 pci_try_num: 2
[ 0.311072] pci 0000:00:1c.3: BAR 15: assigned [mem 0xd2500000-0xd26fffff 64bit pref]
[ 0.311082] pci 0000:00:1c.3: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.311091] pci 0000:00:1c.2: BAR 15: assigned [mem 0xd2700000-0xd28fffff 64bit pref]
[ 0.311098] pci 0000:00:1c.2: BAR 13: assigned [io 0x4000-0x4fff]
[ 0.311104] pci 0000:00:1c.0: BAR 15: assigned [mem 0xd2900000-0xd2afffff 64bit pref]
[ 0.311111] pci 0000:00:1c.0: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.311123] pci 0000:01:00.0: BAR 6: can't assign mem pref (size 0x20000)
[ 0.311128] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.311135] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xd1ffffff]
[ 0.311141] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.311148] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.311153] pci 0000:00:1c.0: bridge window [io 0x5000-0x5fff]
[ 0.311160] pci 0000:00:1c.0: bridge window [mem 0xd2200000-0xd22fffff]
[ 0.311166] pci 0000:00:1c.0: bridge window [mem 0xd2900000-0xd2afffff 64bit pref]
[ 0.311175] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
[ 0.311180] pci 0000:00:1c.2: bridge window [io 0x4000-0x4fff]
[ 0.311187] pci 0000:00:1c.2: bridge window [mem 0xd2300000-0xd23fffff]
[ 0.311193] pci 0000:00:1c.2: bridge window [mem 0xd2700000-0xd28fffff 64bit pref]
[ 0.311202] pci 0000:00:1c.3: PCI bridge to [bus 04-04]
[ 0.311208] pci 0000:00:1c.3: bridge window [io 0x3000-0x3fff]
[ 0.311216] pci 0000:00:1c.3: bridge window [mem 0xd2400000-0xd24fffff]
[ 0.311223] pci 0000:00:1c.3: bridge window [mem 0xd2500000-0xd26fffff 64bit pref]
[ 0.311232] pci 0000:00:1e.0: PCI bridge to [bus 05-05]
[ 0.311237] pci 0000:00:1e.0: bridge window [io 0x1000-0x1fff]
[ 0.311244] pci 0000:00:1e.0: bridge window [mem 0xd2000000-0xd20fffff]
[ 0.311279] pci 0000:00:01.0: setting latency timer to 64
[ 0.311309] pci 0000:00:1c.0: setting latency timer to 64
[ 0.311331] pci 0000:00:1c.2: setting latency timer to 64
[ 0.311353] pci 0000:00:1c.3: setting latency timer to 64
[ 0.311364] pci 0000:00:1e.0: setting latency timer to 64
[ 0.311370] pci_bus 0000:00: resource 0 [io 0x0000-0xffff]
[ 0.311375] pci_bus 0000:00: resource 1 [mem 0x00000000-0xfffffffff]
[ 0.311379] pci_bus 0000:01: resource 1 [mem 0xd0000000-0xd1ffffff]
[ 0.311383] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.311387] pci_bus 0000:02: resource 0 [io 0x5000-0x5fff]
[ 0.311391] pci_bus 0000:02: resource 1 [mem 0xd2200000-0xd22fffff]
[ 0.311395] pci_bus 0000:02: resource 2 [mem 0xd2900000-0xd2afffff 64bit pref]
[ 0.311400] pci_bus 0000:03: resource 0 [io 0x4000-0x4fff]
[ 0.311404] pci_bus 0000:03: resource 1 [mem 0xd2300000-0xd23fffff]
[ 0.311408] pci_bus 0000:03: resource 2 [mem 0xd2700000-0xd28fffff 64bit pref]
[ 0.311412] pci_bus 0000:04: resource 0 [io 0x3000-0x3fff]
[ 0.311416] pci_bus 0000:04: resource 1 [mem 0xd2400000-0xd24fffff]
[ 0.311420] pci_bus 0000:04: resource 2 [mem 0xd2500000-0xd26fffff 64bit pref]
[ 0.311424] pci_bus 0000:05: resource 0 [io 0x1000-0x1fff]
[ 0.311428] pci_bus 0000:05: resource 1 [mem 0xd2000000-0xd20fffff]
[ 0.311432] pci_bus 0000:05: resource 4 [io 0x0000-0xffff]
[ 0.311437] pci_bus 0000:05: resource 5 [mem 0x00000000-0xfffffffff]
[ 0.311574] NET: Registered protocol family 2
[ 0.314928] IP route cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.318359] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.324283] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[ 0.326370] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.326376] TCP reno registered
[ 0.326473] UDP hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.326700] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.327094] NET: Registered protocol family 1
[ 0.327459] pci 0000:01:00.0: Boot video device
[ 0.327488] pci 0000:05:08.0: Firmware left e100 interrupts enabled; disabling
[ 0.327503] PCI: CLS 0 bytes, default 64
[ 0.327657] Unpacking initramfs...
[ 0.707633] Freeing initrd memory: 10384k freed
[ 0.715902] audit: initializing netlink socket (disabled)
[ 0.715931] type=2000 audit(1488907269.708:1): initialized
[ 0.735470] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.735993] VFS: Disk quotas dquot_6.5.2
[ 0.736105] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.736287] msgmni has been set to 6034
[ 0.736685] alg: No test for stdrng (krng)
[ 0.736752] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.736759] io scheduler noop registered
[ 0.736763] io scheduler deadline registered
[ 0.736795] io scheduler cfq registered (default)
[ 0.737034] pcieport 0000:00:01.0: setting latency timer to 64
[ 0.737088] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
[ 0.737201] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.737255] pcieport 0000:00:1c.0: irq 41 for MSI/MSI-X
[ 0.737375] pcieport 0000:00:1c.2: setting latency timer to 64
[ 0.737428] pcieport 0000:00:1c.2: irq 42 for MSI/MSI-X
[ 0.737547] pcieport 0000:00:1c.3: setting latency timer to 64
[ 0.737600] pcieport 0000:00:1c.3: irq 43 for MSI/MSI-X
[ 0.737818] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.737887] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.737891] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.738691] ERST: Table is not found!
[ 0.738695] GHES: HEST is not enabled!
[ 0.738834] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.759278] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.880671] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.916294] Linux agpgart interface v0.103
[ 0.917026] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 0.920420] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.920436] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.920815] mousedev: PS/2 mouse device common for all mice
[ 0.920900] rtc_cmos 00:03: RTC can wake from S4
[ 0.921156] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 0.921259] rtc0: alarms up to one month, 114 bytes nvram, hpet irqs
[ 0.921290] cpuidle: using governor ladder
[ 0.921294] cpuidle: using governor menu
[ 0.921965] TCP cubic registered
[ 0.922058] NET: Registered protocol family 10
[ 0.923647] Mobile IPv6
[ 0.923654] NET: Registered protocol family 17
[ 0.923664] Registering the dns_resolver key type
[ 0.923965] PM: Hibernation image not present or could not be loaded.
[ 0.924036] registered taskstats version 1
[ 0.924660] rtc_cmos 00:03: setting system clock to 2017-03-07 17:21:10 UTC (1488907270)
[ 0.924756] Initializing network drop monitor service
[ 0.928037] Freeing unused kernel memory: 916k freed
[ 0.928628] Write protecting the kernel read-only data: 6144k
[ 0.932083] Freeing unused kernel memory: 548k freed
[ 0.936427] Freeing unused kernel memory: 652k freed
[ 0.941729] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 0.963705] udevd[64]: starting version 175
[ 1.040600] usbcore: registered new interface driver usbfs
[ 1.041763] usbcore: registered new interface driver hub
[ 1.057584] SCSI subsystem initialized
[ 1.058036] usbcore: registered new device driver usb
[ 1.085835] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.087692] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.087701] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.087919] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.087961] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 1.087977] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.091868] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.092305] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xd2100000
[ 1.095096] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.096785] libata version 3.00 loaded.
[ 1.101231] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 1.101242] e100: Copyright(c) 1999-2006 Intel Corporation
[ 1.108074] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.108728] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.108738] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.108743] usb usb1: Product: EHCI Host Controller
[ 1.108748] usb usb1: Manufacturer: Linux 3.2.0-4-rt-amd64 ehci_hcd
[ 1.108754] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.131498] hub 1-0:1.0: USB hub found
[ 1.131526] hub 1-0:1.0: 8 ports detected
[ 1.137901] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.137909] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.138075] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.138252] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00002080
[ 1.138353] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.138359] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.138363] usb usb2: Product: UHCI Host Controller
[ 1.138367] usb usb2: Manufacturer: Linux 3.2.0-4-rt-amd64 uhci_hcd
[ 1.138370] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.142820] e100 0000:05:08.0: eth0: addr 0xd2004000, irq 20, MAC addr 00:16:76:1f:1b:8e
[ 1.151002] hub 2-0:1.0: USB hub found
[ 1.151019] hub 2-0:1.0: 2 ports detected
[ 1.155079] ata_piix 0000:00:1f.1: version 2.13
[ 1.155191] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.192305] scsi0 : ata_piix
[ 1.196312] firewire_ohci: Added fw-ohci device 0000:05:05.0, OHCI v1.10, 4 IR + 8 IT contexts, quirks 0x2
[ 1.198509] scsi1 : ata_piix
[ 1.202117] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x20b0 irq 14
[ 1.202123] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x20b8 irq 15
[ 1.202409] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.202417] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.202481] ata2: port disabled--ignoring
[ 1.202559] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.202806] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00002060
[ 1.202914] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.202921] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.202927] usb usb3: Product: UHCI Host Controller
[ 1.202931] usb usb3: Manufacturer: Linux 3.2.0-4-rt-amd64 uhci_hcd
[ 1.202935] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.209236] hub 3-0:1.0: USB hub found
[ 1.209252] hub 3-0:1.0: 2 ports detected
[ 1.214237] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.214326] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.242837] scsi2 : ata_piix
[ 1.245683] scsi3 : ata_piix
[ 1.248949] ata3: SATA max UDMA/133 cmd 0x20c8 ctl 0x20e4 bmdma 0x20a0 irq 19
[ 1.248955] ata4: SATA max UDMA/133 cmd 0x20c0 ctl 0x20e0 bmdma 0x20a8 irq 19
[ 1.249148] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.249155] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.249225] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.249367] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00002040
[ 1.249478] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.249484] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.249489] usb usb4: Product: UHCI Host Controller
[ 1.249493] usb usb4: Manufacturer: Linux 3.2.0-4-rt-amd64 uhci_hcd
[ 1.249498] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.255968] hub 4-0:1.0: USB hub found
[ 1.255985] hub 4-0:1.0: 2 ports detected
[ 1.259947] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.259955] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.260076] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.260222] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00002020
[ 1.260324] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.260330] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.260334] usb usb5: Product: UHCI Host Controller
[ 1.260337] usb usb5: Manufacturer: Linux 3.2.0-4-rt-amd64 uhci_hcd
[ 1.260341] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.267464] hub 5-0:1.0: USB hub found
[ 1.267481] hub 5-0:1.0: 2 ports detected
[ 1.364338] ata1.00: ATAPI: HL-DT-ST DVDRAM GSA-4167B, DL11, max UDMA/33
[ 1.380202] ata1.00: configured for UDMA/33
[ 1.386873] scsi 0:0:0:0: CD-ROM HL-DT-ST DVDRAM GSA-4167B DL11 PQ: 0 ANSI: 5
[ 1.420341] ata3.00: ATA-8: WDC WD5000AAKS-07V0A0, 05.01D05, max UDMA/133
[ 1.420347] ata3.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.436354] ata3.00: configured for UDMA/133
[ 1.436526] scsi 2:0:0:0: Direct-Access ATA WDC WD5000AAKS-0 05.0 PQ: 0 ANSI: 5
[ 1.440059] usb 1-4: new high-speed USB device number 2 using ehci_hcd
[ 1.475974] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.475983] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.476896] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 1.477667] sd 2:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 1.477835] sd 2:0:0:0: [sda] Write Protect is off
[ 1.477842] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.477912] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.482623] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 1.482743] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 1.510779] sda: sda1 sda2 < sda5 >
[ 1.511615] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.690511] usb 1-4: New USB device found, idVendor=1b1c, idProduct=1ab1
[ 1.690519] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.690523] usb 1-4: Product: Voyager
[ 1.690527] usb 1-4: Manufacturer: Corsair
[ 1.690530] usb 1-4: SerialNumber: AA00000000000070
[ 1.696238] firewire_core: created device fw0: GUID 0090270001980d0d, S400
[ 1.697527] Initializing USB Mass Storage driver...
[ 1.697751] scsi4 : usb-storage 1-4:1.0
[ 1.698552] usbcore: registered new interface driver usb-storage
[ 1.698557] USB Mass Storage support registered.
[ 1.712100] Refined TSC clocksource calibration: 2799.996 MHz.
[ 1.712109] Switching to clocksource tsc
[ 2.128037] usb 4-1: new full-speed USB device number 2 using uhci_hcd
[ 2.188842] PM: Starting manual resume from disk
[ 2.188850] PM: Hibernation image partition 8:5 present
[ 2.188853] PM: Looking for hibernation image.
[ 2.189215] PM: Image not found (code -22)
[ 2.189219] PM: Hibernation image not present or could not be loaded.
[ 2.301452] usb 4-1: New USB device found, idVendor=058f, idProduct=9360
[ 2.301459] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.301464] usb 4-1: Product: USB Reader
[ 2.301468] usb 4-1: Manufacturer:
[ 2.301471] usb 4-1: SerialNumber: 2004888
[ 2.304662] scsi5 : usb-storage 4-1:1.0
[ 2.308104] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.269943] scsi 4:0:0:0: Direct-Access Corsair Voyager 1100 PQ: 0 ANSI: 0 CCS
[ 3.271429] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 3.308496] scsi 5:0:0:0: Direct-Access Generic USB SD Reader 1.00 PQ: 0 ANSI: 0
[ 3.311486] scsi 5:0:0:1: Direct-Access Generic USB CF Reader 1.01 PQ: 0 ANSI: 0
[ 3.314487] scsi 5:0:0:2: Direct-Access Generic USB SM Reader 1.02 PQ: 0 ANSI: 0
[ 3.317487] scsi 5:0:0:3: Direct-Access Generic USB MS Reader 1.03 PQ: 0 ANSI: 0
[ 3.318821] sd 5:0:0:0: Attached scsi generic sg3 type 0
[ 3.319295] sd 5:0:0:1: Attached scsi generic sg4 type 0
[ 3.319726] sd 5:0:0:2: Attached scsi generic sg5 type 0
[ 3.320179] sd 5:0:0:3: Attached scsi generic sg6 type 0
[ 3.358489] sd 5:0:0:0: [sdc] Attached SCSI removable disk
[ 3.368478] sd 5:0:0:1: [sdd] Attached SCSI removable disk
[ 3.373471] sd 5:0:0:3: [sdf] Attached SCSI removable disk
[ 3.377469] sd 5:0:0:2: [sde] Attached SCSI removable disk
[ 4.089422] udevd[350]: starting version 175
[ 4.349678] sd 4:0:0:0: [sdb] 15663104 512-byte logical blocks: (8.01 GB/7.46 GiB)
[ 4.350800] sd 4:0:0:0: [sdb] Write Protect is off
[ 4.350808] sd 4:0:0:0: [sdb] Mode Sense: 43 00 00 00
[ 4.351924] sd 4:0:0:0: [sdb] No Caching mode page found
[ 4.351978] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 4.438993] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 4.439008] ACPI: Sleep Button [SLPB]
[ 4.458210] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 4.458224] ACPI: Power Button [PWRF]
[ 4.550108] input: PC Speaker as /devices/platform/pcspkr/input/input3
[ 4.920150] sd 4:0:0:0: [sdb] No Caching mode page found
[ 4.920202] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 4.921326] sdb: sdb1
[ 4.941424] sd 4:0:0:0: [sdb] No Caching mode page found
[ 4.941474] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 4.941519] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 5.027696] intel_rng: Firmware space is locked read-only. If you can't or
[ 5.027699] intel_rng: don't want to disable this in firmware setup, and if
[ 5.027701] intel_rng: you are certain that your system has a functional
[ 5.027703] intel_rng: RNG, try using the 'no_fwh_detect' option.
[ 5.067222] iTCO_vendor_support: vendor-support=0
[ 5.131168] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 5.131360] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0460)
[ 5.132680] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 5.139984] [drm] Initialized drm 1.1.0 20060810
[ 5.230373] leds_ss4200: no LED devices found
[ 5.339951] wmi: Mapper loaded
[ 5.439195] nouveau 0000:01:00.0: setting latency timer to 64
[ 5.439226] [drm] nouveau 0000:01:00.0: Detected an NV40 generation card (0x046100a3)
[ 5.442299] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS
[ 5.523509] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 5.523516] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN
[ 5.523522] [drm] nouveau 0000:01:00.0: BIT BIOS found
[ 5.523528] [drm] nouveau 0000:01:00.0: Bios version 05.72.22.49
[ 5.523533] [drm] nouveau 0000:01:00.0: TMDS table version 1.1
[ 5.523537] [drm] nouveau 0000:01:00.0: TMDS table script pointers not stubbed
[ 5.523784] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do
[ 5.523790] [drm] nouveau 0000:01:00.0: DCB version 3.0
[ 5.523795] [drm] nouveau 0000:01:00.0: DCB outp 00: 01000300 00000028
[ 5.523800] [drm] nouveau 0000:01:00.0: DCB outp 01: 02011310 00000028
[ 5.523804] [drm] nouveau 0000:01:00.0: DCB outp 02: 01011312 00000000
[ 5.523810] [drm] nouveau 0000:01:00.0: DCB outp 03: 020223f1 00c0c080
[ 5.523814] [drm] nouveau 0000:01:00.0: DCB conn 00: 0000
[ 5.523819] [drm] nouveau 0000:01:00.0: DCB conn 01: 2130
[ 5.523824] [drm] nouveau 0000:01:00.0: DCB conn 02: 0210
[ 5.523829] [drm] nouveau 0000:01:00.0: DCB conn 03: 0211
[ 5.523833] [drm] nouveau 0000:01:00.0: DCB conn 04: 0213
[ 5.523843] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xD25F
[ 5.523908] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xD58E
[ 5.539038] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xDB2C
[ 5.539065] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xDCA7
[ 5.540198] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xDF00
[ 5.540509] [TTM] Zone kernel: Available graphics memory: 1545836 kiB
[ 5.540513] [TTM] Initializing pool allocator
[ 5.540530] [TTM] Initializing DMA pool allocator
[ 5.540557] [drm] nouveau 0000:01:00.0: Detected 128MiB VRAM (DDR2)
[ 5.552384] [drm] nouveau 0000:01:00.0: 512 MiB GART (aperture)
[ 5.552667] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 5.617226] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 5.617231] [drm] No driver support for vblank timestamp query.
[ 5.622944] [drm] nouveau 0000:01:00.0: 1 available performance level(s)
[ 5.622952] [drm] nouveau 0000:01:00.0: 0: core 450MHz shader 450MHz memory 648MHz fanspeed 100%
[ 5.622957] [drm] nouveau 0000:01:00.0: c: core 199MHz memory 391MHz
[ 5.624702] [drm] nouveau 0000:01:00.0: 0xC61E: Parsing digital output script table
[ 5.675033] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 3)
[ 5.784714] [drm] nouveau 0000:01:00.0: allocated 1280x1024 fb: 0x49000, bo ffff8800372b0400
[ 5.789522] fbcon: nouveaufb (fb0) is primary device
[ 5.810842] Console: switching to colour frame buffer device 160x64
[ 5.813512] fb0: nouveaufb frame buffer device
[ 5.813517] drm: registered panic notifier
[ 5.813527] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0
[ 5.949652] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input4
[ 7.399438] Adding 6286332k swap on /dev/sda5. Priority:-1 extents:1 across:6286332k
[ 7.431949] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 7.683966] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 7.809470] loop: module loaded
[ 9.297804] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.300168] e100 0000:05:08.0: eth0: NIC Link is Up 100 Mbps Full Duplex
[ 9.313225] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.908863] RPC: Registered named UNIX socket transport module.
[ 9.908869] RPC: Registered udp transport module.
[ 9.908873] RPC: Registered tcp transport module.
[ 9.908877] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 9.956644] FS-Cache: Loaded
[ 10.003054] FS-Cache: Netfs 'nfs' registered for caching
[ 10.016100] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 12.288915] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input5
[ 15.858583] Bluetooth: Core ver 2.16
[ 15.858628] NET: Registered protocol family 31
[ 15.858635] Bluetooth: HCI device and connection manager initialized
[ 15.858643] Bluetooth: HCI socket layer initialized
[ 15.858648] Bluetooth: L2CAP socket layer initialized
[ 15.858665] Bluetooth: SCO socket layer initialized
[ 15.904208] Bluetooth: RFCOMM TTY layer initialized
[ 15.904223] Bluetooth: RFCOMM socket layer initialized
[ 15.904229] Bluetooth: RFCOMM ver 1.11
[ 16.229935] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.229941] Bluetooth: BNEP filters: protocol multicast
[ 16.554089] lp: driver loaded but no devices found
[ 16.646676] ppdev: user-space parallel port driver
[ 19.744015] eth0: no IPv6 routers present
[ 906.338371] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 919.467001] ip_tables: (C) 2000-2006 Netfilter Core Team
[11526.644849] usb 1-4: USB disconnect, device number 2
[20934.940026] usb 1-4: new high-speed USB device number 4 using ehci_hcd
[20935.190497] usb 1-4: New USB device found, idVendor=1b1c, idProduct=1ab1
[20935.190505] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[20935.190509] usb 1-4: Product: Voyager
[20935.190512] usb 1-4: Manufacturer: Corsair
[20935.190516] usb 1-4: SerialNumber: AA00000000000070
[20935.192063] scsi6 : usb-storage 1-4:1.0
[20937.473065] scsi 6:0:0:0: Direct-Access Corsair Voyager 1100 PQ: 0 ANSI: 0 CCS
[20937.475230] sd 6:0:0:0: Attached scsi generic sg2 type 0
[20938.558155] sd 6:0:0:0: [sdb] 15663104 512-byte logical blocks: (8.01 GB/7.46 GiB)
[20938.559268] sd 6:0:0:0: [sdb] Write Protect is off
[20938.559275] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00
[20938.560395] sd 6:0:0:0: [sdb] No Caching mode page found
[20938.560404] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[20940.711770] sd 6:0:0:0: [sdb] No Caching mode page found
[20940.711779] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[20940.712855] sdb: sdb1
[20941.259773] sd 6:0:0:0: [sdb] No Caching mode page found
[20941.259781] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[20941.259788] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[21010.589457] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Last edit: 08 Mar 2017 19:48 by BigJohnT.
08 Mar 2017 00:18 #89184
Oh well, you are using 2.7 version and i am using 2.8pre, so that will not work, it will need a bit of editing the ini file to make it work.
linuxcnc.org/docs/devel/html/getting-sta...dating-linuxcnc.html
Have a look here, it mentions differences between the two.
- tuffduck33
08 Mar 2017 02:21 #89187
by tuffduck33
I thought that 2.8 was sim only
08 Mar 2017 13:08 #89198
Nope, it is fully functional, i have it on several machines working all day every day.
I call that testing properly, if something is wrong, i get called.
No calls, yet !
No calls, yet !
Time to create page: 0.190 seconds
