[solved] strange result with mesa5i25 7i77 what wrong?
04 Apr 2017 07:17 - 04 Apr 2017 21:04 #90854
by bkt
[solved] strange result with mesa5i25 7i77 what wrong? was created by bkt
I install linuxcnc-dev on my ubuntu 14.04.... all seems to work Ok with par port. .... But when I try to install mesa5i25 i'm not able to load mesa driver ... so install mesaflash and charge 7i77x2.bit on mesa super port. ... copyright My working configurazione from other pc and run..... But only input seems to work.... output Not. .... And i'm not able tu toggle emergency button on axis gui...... why these.... I have no error or warning..... lo ad correctly version 0.15 of firmware hostmot2 but no output working seems...
Regards
Miki
Regards
Miki
Last edit: 04 Apr 2017 21:04 by bkt. Reason: add solved prefix
- Thank you received: 5925
04 Apr 2017 07:45 #90856
Replied by tommylight on topic strange result with mesa5i25 7i77 what wrong?
What do you get from
Sudo mesaflash --device 5i25 --readhmid
Maybe you need to change the ports on 5i25 as that can be changed with firmware.
The following user(s) said Thank You: bkt
04 Apr 2017 07:58 #90857
by bkt
these the results ... but I'm not able to undertand if is all ok or not ... for me is ok ...
my hal header is these:
Replied by bkt on topic strange result with mesa5i25 7i77 what wrong?
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 12 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort SSerial 0 TXEn3 (Out)
14 1 IOPort SSerial 0 TXData3 (Out)
2 2 IOPort SSerial 0 RXData3 (In)
15 3 IOPort SSerial 0 TXData2 (Out)
3 4 IOPort SSerial 0 RXData2 (In)
16 5 IOPort SSerial 0 TXData1 (Out)
4 6 IOPort SSerial 0 RXData1 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P2
1 17 IOPort SSerial 0 TXEn6 (Out)
14 18 IOPort SSerial 0 TXData6 (Out)
2 19 IOPort SSerial 0 RXData6 (In)
15 20 IOPort SSerial 0 TXData5 (Out)
3 21 IOPort SSerial 0 RXData5 (In)
16 22 IOPort SSerial 0 TXData4 (Out)
4 23 IOPort SSerial 0 RXData4 (In)
17 24 IOPort MuxedQCountSel 6 MuxSel0 (Out)
5 25 IOPort MuxedQCount 3 MuxQ-A (In)
6 26 IOPort MuxedQCount 3 MuxQ-B (In)
7 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 28 IOPort MuxedQCount 4 MuxQ-A (In)
9 29 IOPort MuxedQCount 4 MuxQ-B (In)
10 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 5 MuxQ-A (In)
12 32 IOPort MuxedQCount 5 MuxQ-B (In)
13 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
loadrt [KINS]KINEMATICS
#autoconverted trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_dio=32
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=000xxx"
setp hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.a
loadrt mux4 names=jogincr
loadrt ilowpass
loadrt conv_s32_float names=c32f.0,c32f.1,c32f.2,c32f.3,c32f.4
04 Apr 2017 12:53 #90865
Replied by PCW on topic strange result with mesa5i25 7i77 what wrong?
What kernel are you using?
(run uname -a and post the results here)
Which outputs dont work?
04 Apr 2017 16:15 #90870
by bkt
Kernel 4.8.15 rt10..... But now all works like a charm..... I Not understand why but after a restart of pc all works....
Regards
Miki
Regards
Miki
04 Apr 2017 18:34 #90875
After flashing new firmware, you have to use sudo mesaflash --device 5i25 --reload or power off and on the computer.
Glad you got it goimg.
Tom
Tom
04 Apr 2017 21:03 #90886
by bkt
I use ether .... --reload and reboot .... but isn't these the problem .... during motor config (arghh .. motor online too for adding some difficult) the modification of .ini file was not immediate or certain ... only after the second run of axis gui the modification was for shure modify. So I think was something related to linuxcnc-dev folder and config path.
Miki
Miki
Time to create page: 0.266 seconds
