Upgrade Script fails LinuxCNC 2.7 to 2.8
23 May 2017 20:27 #93568
by dewayne
Upgrade Script fails LinuxCNC 2.7 to 2.8 was created by dewayne
The attached HAL and INI when upgrading to 2.8 Fails
Trying to upgrade them manually.
Rgds
Rgds
24 May 2017 07:33 #93581
by dewayne
Replied by dewayne on topic Upgrade Script fails LinuxCNC 2.7 to 2.8
Hello All,
LinuxCNC 2.8
I used Pncconf to create a XY ZZ A fpr the MesaIO 6i25 and (2) 7i76
I then went through and edit the HAl and IN by copying and paste the Rotary A-Axis stuff and changing the JOINT STEPGEN and HOME SEQ
Even adding 1 more axis B or C i get the same error
Debug file information:
./MESA_XYZABC_28_02.hal:305: Pin 'joint.4.motor-pos-cmd' does not exist
2534
What I am doing is this
JOINT NUM Stepgen Home
X 0 .00 1
Y 1 .01 2
Z 2 .02 0
Z 2 .03 TANDEM
A 3 .07 3
B 4 .08 4
C 5 .09 5
Can any one please take a look at what I am doing
This is how on LinuxCNC 2.7 i got 6-axis working Linear and Rotary
Rgds DeWayne
LinuxCNC 2.8
2534
X 0 .00 1
Y 1 .01 2
Z 2 .02 0
Z 2 .03 TANDEM
A 3 .07 3
B 4 .08 4
C 5 .09 5
Rgds DeWayne
25 May 2017 12:11 #93611
Joints start counting at 0, so to have a joint.4.. you need [KINS]JOINTS=5
Replied by andypugh on topic Upgrade Script fails LinuxCNC 2.7 to 2.8
25 May 2017 13:26 #93616
by dewayne
I changed Kins to 5
still getting this
./MESA_XYZABC_28_02.hal:359: Pin 'joint.5.motor-pos-cmd' does not exist
3113
Having 2 7i76 card trying to setup so that XYZ and ABC are on different 7i76 boards
Even if I just use all the StepGens on P3 the First card still get the error
still getting this
3113
25 May 2017 13:36 #93617
If you want 6 joints, then you need JOINTS = 6...
25 May 2017 13:50 #93619
by dewayne
Andy You are a STAR
Thank You it is working now.
Time to create page: 0.303 seconds
