Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
08 Sep 2017 14:09 #98688
by tecno
Replied by tecno on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
renamed and it became a mess.
Obviously there was a mix of ini and hal = now only these 2 files.
I suspect *wrong* ini was used thus wrong hal.
Newbie mistake assuming things
08 Sep 2017 15:51 #98697
by tecno
setp hm2_7i76e.0.encoder.00.scale [AXIS_0] ENCODER_SCALE
Error FIXED [AXIS_0] ENCODER_SCALE to [AXIS_0]ENCODER_SCALE
The Popup shows and is counting BUT manually turning Spindle
Now net spindle-vel hm.........04.velocity does not exist
08 Sep 2017 16:05 #98698
Replied by andypugh on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
You can use the "select" button on the halmeter to see what the encoder velocity pin is really called.
I probably got the hal pin name wrong, I don't actually have an encyclopedic knowledge of the exact hal pin names of every possible system configuration including hardware I have never even seen.
- Thank you received: 1369
08 Sep 2017 16:18 #98699
I think your problem here might be the space between [AXIS_0] ENCODER_SCALE
So change these lines to this.
Replied by Todd Zuercher on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
Now error at above line = empty variable name
setp hm2_7i76e.0.encoder.00.scale [AXIS_0]ENCODER_SCALE
setp hm2_7i76e.0.encoder.01.scale [AXIS_1]ENCODER_SCALE
setp hm2_7i76e.0.encoder.02.scale [AXIS_2]ENCODER_SCALE
setp hm2_7i76e.0.encoder.03.scale [AXIS_3]ENCODER_SCALE
setp hm2_7i76e.0.encoder.04.scale [SPINDLE_9]ENCODER_SCALE
08 Sep 2017 16:18 #98700
by tecno
It is correct name
It counts turning by hand
BUT now only M4 is functioning not M3
08 Sep 2017 16:31 - 08 Sep 2017 16:45 #98702
by tecno
G33.1 is working by turning spindle by hand and returns with M4 when in position.
M3 = mysterious
edit/ output 8 is false all the time
M3 = mysterious
Last edit: 08 Sep 2017 16:45 by tecno. Reason: added text
08 Sep 2017 17:04 #98704
by tecno
Done forum.linuxcnc.org/39-pncconf/33069-help...oing?start=380#98697
So change these lines to this.setp hm2_7i76e.0.encoder.00.scale [AXIS_0]ENCODER_SCALE setp hm2_7i76e.0.encoder.01.scale [AXIS_1]ENCODER_SCALE setp hm2_7i76e.0.encoder.02.scale [AXIS_2]ENCODER_SCALE setp hm2_7i76e.0.encoder.03.scale [AXIS_3]ENCODER_SCALE setp hm2_7i76e.0.encoder.04.scale [SPINDLE_9]ENCODER_SCALE
09 Sep 2017 16:06 #98733
by tecno
Can somebody share their knowledge why M3 / Spindle forward is not functioning.
# SPINDLE S
net spindle-cmd-rpm motion.spindle-speed-out-abs => hm2_7i76e.0.7i76.0.0.spinout
net spindle-enable motion.spindle-on => hm2_7i76e.0.7i76.0.0.spinena
net spindle-ccw motion.spindle-reverse => hm2_7i76e.0.7i76.0.0.spindir
net spindle-index-enable motion.spindle-index-enable <=> hm2_7i76e.0.encoder.04.index-enable
net spindle-pos hm2_7i76e.0.encoder.04.position => motion.spindle-revs
loadusr halmeter sig spindle-pos
>>>> errors here net spindle-vel hm2_7i76.0.encoder.04.velocity => motion.spindle-speed-in
setp hm2_7i76e.0.7i76.0.0.spinout-scalemax 1200
setp hm2_7i76e.0.7i76.0.0.spinout-maxlim 2500
Testing G33.1 it works if I turn spindle by hand in CW direction and when in depth position M4 goes active and returns.
# SPINDLE S
09 Sep 2017 16:16 #98735
You have a bad pin name (7i76 instead of 7i76e)
I usually make a "donor" file of pin names to select from so I don't ever have to type them
something like:
halcmd show pin hm2* > hardware-pins
Replied by PCW on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
something like:
09 Sep 2017 16:55 #98739
by tecno
OK, error message gone BUT...
Still no M3 so something must be missing in Andys code for Spindle.
Time to create page: 0.241 seconds
