Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
OK, error message gone BUT...
Still no M3 so something must be missing in Andys code for Spindle.
Very likely. I have next to no idea what any of your HAL pins are called or how your spindle is powered.
You do know all these things, and are in a position to investigate your HAL and correct my wild guesses.
My next wild guess is that there is a miss-match between the pins you have enabling the spindle drive and the pins the spindle drive expects.
As a starting point, is your VFD configured for ON / REV or FWD / REV ?
(And is the spindle even a VFD?)
I am finding this thread _extremely_ frustrating. Could you at least start each new question with a summary of whether the previous problem is solved or not? And given that we are about 23 pages of posts in, the occasional summary of the hardware and machine status would be nice. This is not the only thread that we are all reading, and it is hard to remember which machine is which when trying to support half a dozen simultaneous build threads.
Answers to your questions.
VFD
forum.linuxcnc.org/media/kunena/attachments/481/fwdrev.pdf
# --- SPINDLE-CW ---
net spindle-cw hm2_7i76e.0.7i76.0.0.output-08
# --- SPINDLE-CCW ---
net spindle-ccw hm2_7i76e.0.7i76.0.0.output-09
Old HAL with M3 OK but not spindle encoder
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
### --- net some-signal-name pid.X.feedback >> already declared ---
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
### --- net some-signal-name axis.N.motor-position-fb hm2_7i76e.0.encoder.MM.position -- is the line below to be changed???
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
net spindle-pos hm2_7i76e.0.encoder.04.position motion.spindle-revs ### new added line
net spindle-vel hm2_7i76.0.encoder.04.velocity motion.spindle-vel ### new added line
sets spindle-at-speed true
setp hm2_7i76e.0.7i76.0.0.spinout-scalemax 1200
setp hm2_7i76e.0.7i76.0.0.spinout-maxlim 2500
net spindle-enable hm2_7i76e.0.7i76.0.0.spinena
net spindle-vel-cmd-rpm-abs hm2_7i76e.0.7i76.0.0.spinout
net spindle-ccw hm2_7i76e.0.7i76.0.0.spindir
New HAL with no M3 but spindle encoder functioning
# SPINDLE S
net spindle-cmd-rpm motion.spindle-speed-out-abs => hm2_7i76e.0.7i76.0.0.spinout
net spindle-enable motion.spindle-on => hm2_7i76e.0.7i76.0.0.spinena
net spindle-ccw motion.spindle-reverse => hm2_7i76e.0.7i76.0.0.spindir
net spindle-index-enable motion.spindle-index-enable <=> hm2_7i76e.0.encoder.04.index-enable
net spindle-pos hm2_7i76e.0.encoder.04.position => motion.spindle-revs
net spindle-vel hm2_7i76e.0.encoder.04.velocity => motion.spindle-speed-in
I assume that the problem is this line
is this correct?
net spindle-cw motion.spindle-forward => hm2_7i76e.0.7i76.0.0.spinena
Now M3 functions but M4 does not, why is that so?
/edit
M4 output 9 works OK but nothing happens = spindle is still
The 7i76E spindle outputs rather assume ON / REV wiring rather than FWD / REV wiring.
Can you set the VFD to ON / REV mode?
To clarify With ON / REV wiring forwards is
Forwards spindle: ON = TRUE, REV = FALSE
Reverse Spindle: ON = TRUE, REV = TRUE
FWD / REV wiring has:
Forwards spindle: FWD = TRUE, REV = FALSE
Reverse Spindle: FWD = FALSE, REV = TRUE
Most VFDs can be set to either mode.
Above schematics is supplied by Peter and it has been working with the old HAL as shown here
forum.linuxcnc.org/39-pncconf/33069-help...oing?start=390#98758
VFD discussed here
forum.linuxcnc.org/27-driver-boards/32933-7i76e-to-vfd
Can you confirm that you are now connected according to the PDF, and wired to the ENA and DIR outputs of the 7I76E? (and that the wiring suggested above is no longer relevant?)
Outputs 8 and 9 controls 3-phase contactor
This HAL code has been working MINUS encoder trouble
# SPINDLE S
Does the relay click when you reverse the spindle?
modified as below
M3 works OK
M4 relay works but VFD is not outputting anything
spinena - spindir - spinout must be messed up somehow
If
net spindle-enable motion.spindle-on => hm2_7i76e.0.7i76.0.0.spinena = only M4 works
Cannot be right because it will disable the spindle enable output and analog when not going forward
Is correct
If this does not work with your VFD, the trouble is elsewhere
