Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
30 Jul 2017 13:31 #96679
by tecno
Replied by tecno on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
Now I have Z moving in correct direction for homing, but for some reason 7i73 inputs do not react on open or closed switch.
Have to open quite a bit to physically get to the switch block on Z axis (easiest). Will verify with multimeter that the switch is working OK.
I have replaced Z home with cable from +5V (pin25) to input 18 and no reaction if cable is cut so something is fishy but what? 7i73 broken in some ways?
30 Jul 2017 14:55 #96681
by tecno
Now I have verified my limit/home switches = all working NC tested with multimeter.
No reaction whatsoever on these inputs, only input I can see is working is the MPG that is counting.
So something is fishy, help please.
Cheers
Bengt
Cheers
Bengt
30 Jul 2017 16:40 #96685
by tecno
Verified that all jumpers are set correctly.
Encoder Counts
Other inputs work OK, have 3 on my frontpanel.
I am dubious if 7i73 can handle old limitswithes at 5VDC, I expressed this concern earlier and it looks like these inputs might be toasted.
Encoder Counts
30 Jul 2017 16:44 #96686
Replied by PCW on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
Which 7I73 inputs are you using?
Inputs 8..15 have pullup resistors, so if you use a switch,
the switch common must be grounded to the 7I73s ground
Other inputs (0..7) have neither pullups or pulldowns so these must be added
for sensing switches (note that inputs 0..7 are 3.3V max input)
30 Jul 2017 16:46 #96687
by tecno
30 Jul 2017 16:49 #96688
by tecno
Inputs 10 to 18 are used for Limits/Home
30 Jul 2017 17:13 #96689
1. If you connected 5V to the KEY inputs you may have damaged the 7I73 (all inputs except P2 IN 8..15 are 3.3V max)
2. In any case if you use inputs with pullups you must connect them to ground to be sensed (switch common must be 7I73 ground)
30 Jul 2017 17:18 #96690
by tecno
Any suggestion on what to move and connect how?
All switches have been connected to 5V. So 10-15 should be OK common grounded, right?
Where to move the rest 3 and connect how?
30 Jul 2017 17:38 #96691
IN 8 through 15 (P2) and KEY 8 through 15 (IN 16..23 --> P1)
have pullups so can be used with switches with common grounds
No inputs work with common 5V without adding external parts
30 Jul 2017 18:22 - 30 Jul 2017 18:46 #96692
by tecno
Those used inputs are TOASTED for sure, now tested with common ground.
I have this board that works with shared X/Y/Z+ X/Y/Z- X/Y/Zhome pins, 24VDC out.
Where to connect on 7i73 and what value on resistors?
Also Index pulse from encoders that are connected to 7i85S how to utilize these?
//edit
Oh no = only 1 free input left
//edit
Last edit: 30 Jul 2017 18:46 by tecno. Reason: added text
Time to create page: 0.130 seconds
