7i77 5i25 PNCconf
08 Aug 2017 12:43 - 08 Aug 2017 12:44 #97171
by ligthmare
7i77 5i25 PNCconf was created by ligthmare
Hi!
I'm trying to configure an plug and go kit from mesa. So in PNCconf when i select 7i77x2 with one 7i77, in the next page I haven't the 7i77 choice, I can only see the 7i71 with tb2 and tb3 pin configuration . How can i configurate it with the 7i77?
Last edit: 08 Aug 2017 12:44 by ligthmare.
08 Aug 2017 21:17 - 08 Aug 2017 21:18 #97206
Replied by cmorley on topic 7i77 5i25 PNCconf
Is this what you see?
Last edit: 08 Aug 2017 21:18 by cmorley.
08 Aug 2017 21:20 #97207
If not ..please specify what version of linuxcnc you are using.
and exactly what you did to get the result you see.
And finally a pic of what you get probably would help too.
Thanks Chris M
Thanks Chris M
09 Aug 2017 08:02 - 09 Aug 2017 09:26 #97230
by ligthmare
Thank you Chris . My Linux version is 2.7.0 (now i have update to 2.7.11) and I'm on beta1 with PNCconf
I'm in axis configuration , i have chosen one mesa card 5i25 internet and 7i77x2 with one 7i77
I can see the 7i77 in the I/O connector but i can't do some change. I can change just on one roll menu and i have the choice between a lot of mesa card but not the 7i77.
Idon't have the same configuration like you : 7i77 i/0 ss#0 , 7i77 PWM ss#1
I can't show you the pics , I don't know why my upload doesn"t work.
I share with an hosting.
Replied by ligthmare on topic 7i77 5i25 PNCconf
Last edit: 09 Aug 2017 09:26 by ligthmare.
09 Aug 2017 12:05 - 09 Aug 2017 12:06 #97236
ok there is a bug with pncconf - you must run it with an english locale.
this might help with the idea:
makandracards.com/makandra/28205-linux-r...le-than-your-default
Chris M
Chris M
Last edit: 09 Aug 2017 12:06 by cmorley.
11 Aug 2017 07:38 - 12 Aug 2017 14:04 #97327
by ligthmare
thank you Chris !! it's works!!
So I have a new problem, after configuring pncCONF I can't run linuxcnc , I think it's a problem about the parport address.
And I have an other question about my endstop, I have three switch, how can I connect them to the 7i77? Did I need to powered them?
And when i typ lspci -v in terminal i can't see the "0000:01:0a.0 Communication controller: " line
Last edit: 12 Aug 2017 14:04 by ligthmare.
14 Aug 2017 16:06 #97467
Replied by andypugh on topic 7i77 5i25 PNCconf
You don't need a parport if you have a 5i25 and 7i77. I would suggest going back to PnCConf and removing any references to the parport.
Also, your initial problem might have been that you were dropping-down the dedicated smart-serial port on the 7i77, and it was asking which smart-serial daughter (grand-daughter?) cards you had attached.
15 Aug 2017 10:57 - 15 Aug 2017 12:32 #97497
by ligthmare
Thank you so much! too easy....
So, I have no power supply on TB1 , CR1 CR3 CR6 and CR7 are yellow fix, CR16 is off and CR15 is blinking green at 1Hz when LinuxCNC is turning on.
I'm not shure but i have connected all the Vfield power and also Vin to the 12v on TB2, Can you confirm for Vin ?
Last edit: 15 Aug 2017 12:32 by ligthmare.
15 Aug 2017 12:56 #97503
by bevins
If you have the W1 jumper in the left hand position, you only need to supply power to VIN. Is something not working? The blinking green led tells me it is working. Are your inputs and outputs working? Are you getting an error message?
Without any power supply to TB1, you are using the 5 volts from the computer.
An example of power for Field power is attached:
Replied by bevins on topic 7i77 5i25 PNCconf
15 Aug 2017 13:12 #97504
Though possibly worth pointing out that that the actual limit-switch wiring there is a little unusual and should probably not be copied exactly.
Time to create page: 0.830 seconds
