Analog Overrides? 5i25+7i77 Mode 3
- B.Reilly01
- Topic Author
- Thank you received: 11
08 Sep 2017 01:16 #98650
by B.Reilly01
Analog Overrides? 5i25+7i77 Mode 3 was created by B.Reilly01
I would like to have analog overrides for spindle, rapid, and feed. I would like to use the Analog inputs connected to potentiometers. I would like to use PNCConf for this so I don't hose something up. Is this possible? My 7i77 is set to Mode3, which should allow 4 analog inputs (0-3) as well as 2 MPGs (only using 1 on 16-17). Under this mode, I don't seem to be able to select analog input in PNCCONF. Any help would be appreciated.
Thank you
Thank you
The following user(s) said Thank You: Ichzwei
08 Sep 2017 15:42 - 08 Sep 2017 15:45 #98696
Replied by andypugh on topic Analog Overrides? 5i25+7i77 Mode 3
I think that this level of complexity is beyond the capability of PnCConf.
You will have to configure this by hand in the HAL file.
Something like:
linuxcnc.org/docs/2.7/html/man/man1/halui.1.html
Something like:
net spindle-override hm2_7i77.0.analog0 => halui.spindle-override.scale
setp halui.spindle-override.counts 100
setp halui.spindle-override.direct-value 1
Last edit: 08 Sep 2017 15:45 by andypugh.
28 Dec 2017 23:39 #103805
by Ichzwei
Replied by Ichzwei on topic Analog Overrides? 5i25+7i77 Mode 3
Hi, i have search the forum for help with a potentiometer as spindle override, and find this post.
but it don't work for me.
i have this in my HAL-file:
loadrt scale names=spindle-scale
addf spindle-scale servo-thread
net spindle-analogue hm2_5i25.0.7i77.0.0.analogin0 => spindle-scale.in
net spindle-override spindle-scale.out => halui.spindle-override.value
setp spindle-scale.gain 1
setp spindle-scale.offset -2.5
it shows this error:
Debug file information:
./my_LinuxCNC_machine.hal:318: Signal 'spindle-override' can not add OUT pin 'halui.spindle-override.value', it already has OUT pin 'spindle-scale.out'
16983
what is my mistake?
16983
what is my mistake?
29 Dec 2017 05:09 #103812
by Henk
Replied by Henk on topic Analog Overrides? 5i25+7i77 Mode 3
Hi
It seems that the signal spindle-override exists somewhere else in your hal file and you are trying to connect another out pin which is not allowed.
henk
henk
29 Dec 2017 09:45 - 29 Dec 2017 09:50 #103817
by Ichzwei
Thanks henk.
I have chanced the name of the pin, so it definitely only on this position in the HAL-file.
but it shows the same error.
i add the hal file, maybe i overlooking something
thanks for your help
michael
michael
Warning: Spoiler!
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.8.0-pre1-3393-g8afc258
Machine configuration directory is '/home/linuxcnc/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/home/linuxcnc/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
VERSION=1.0
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./my_LinuxCNC_machine.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=4544
4544
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f400 (usable)
[ 0.000000] BIOS-e820: 000000000009f400 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007fff0000 (usable)
[ 0.000000] BIOS-e820: 000000007fff0000 - 000000007fff3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007fff3000 - 0000000080000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.2 present.
[ 0.000000] DMI: /nForce4 DDR: 9NPA+ / 9NPA+Ultra / 9NPAJ / 9NPA Ultra Series, BIOS 6.00 PG 08/11/2006
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7fff0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask FF80000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00f4250] f4250
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 3652a000 - 3728d000
[ 0.000000] ACPI: RSDP 000f8380 00014 (v00 Nvidia)
[ 0.000000] ACPI: RSDT 7fff3040 00030 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 7fff30c0 00074 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 7fff3180 06633 (v01 NVIDIA AWRDACPI 00001000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 7fff0000 00040
[ 0.000000] ACPI: MCFG 7fff98c0 0003C (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: APIC 7fff9800 0007C (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1159MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007fff0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0007fff0
[ 0.000000] On node 0 totalpages: 524159
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f552a200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2320 pages used for memmap
[ 0.000000] HighMem zone: 294626 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] Nvidia board detected. Ignoring ACPI timer override.
[ 0.000000] If you got timer trouble try acpi_use_timer_override
[ 0.000000] ACPI: PM-Timer IO Port: 0x4008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: BIOS IRQ0 override ignored.
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] ACPI: IRQ14 used by override.
[ 0.000000] ACPI: IRQ15 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:60000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77cf000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 520063
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=61e7afdd-fdbe-4754-b456-10b0e2c56271 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 4194048 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007fff0)
[ 0.000000] Memory: 2055600k/2097088k available (3495k kernel code, 41036k reserved, 1237k data, 416k init, 1187784k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f5006000 soft=f5008000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2009.406 MHz processor.
[ 0.000000] Marking TSC unstable due to TSCs unsynchronized
[ 0.008005] Calibrating delay loop (skipped), value calculated using timer frequency.. 4018.81 BogoMIPS (lpj=8037624)
[ 0.008010] pid_max: default: 32768 minimum: 301
[ 0.008064] Security Framework initialized
[ 0.008070] AppArmor: AppArmor disabled by boot time parameter
[ 0.008090] Mount-cache hash table entries: 512
[ 0.008298] Initializing cgroup subsys cpuacct
[ 0.008301] Initializing cgroup subsys memory
[ 0.008310] Initializing cgroup subsys devices
[ 0.008312] Initializing cgroup subsys freezer
[ 0.008315] Initializing cgroup subsys net_cls
[ 0.008317] Initializing cgroup subsys blkio
[ 0.008325] Initializing cgroup subsys perf_event
[ 0.008351] CPU: Physical Processor ID: 0
[ 0.008353] CPU: Processor Core ID: 0
[ 0.008356] mce: CPU supports 5 MCE banks
[ 0.008413] ACPI: Core revision 20120320
[ 0.016090] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.016447] ..TIMER: vector=0x30 apic1=0 pin1=0 apic2=-1 pin2=-1
[ 0.056432] CPU0: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ stepping 01
[ 0.060003] Performance Events: AMD PMU driver.
[ 0.060003] ... version: 0
[ 0.060003] ... bit width: 48
[ 0.060003] ... generic registers: 4
[ 0.060003] ... value mask: 0000ffffffffffff
[ 0.060003] ... max period: 00007fffffffffff
[ 0.060003] ... fixed-purpose events: 0
[ 0.060003] ... event mask: 000000000000000f
[ 0.068026] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.080023] CPU 1 irqstacks, hard=f5094000 soft=f5096000
[ 0.080025] Booting Node 0, Processors #1 Ok.
[ 0.012000] Initializing CPU#1
[ 0.168103] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.168134] Brought up 2 CPUs
[ 0.168138] Total of 2 processors activated (8037.58 BogoMIPS).
[ 0.168542] devtmpfs: initialized
[ 0.168542] PM: Registering ACPI NVS region [mem 0x7fff0000-0x7fff2fff] (12288 bytes)
[ 0.168542] dummy:
[ 0.168542] NET: Registered protocol family 16
[ 0.168542] node 0 link 0: io port [6000, ffff]
[ 0.168542] TOM: 0000000080000000 aka 2048M
[ 0.168542] node 0 link 0: mmio [a0000, bffff]
[ 0.168542] node 0 link 0: mmio [feb00000, fec0ffff]
[ 0.168542] node 0 link 0: mmio [80000000, fe02ffff]
[ 0.168542] node 0 link 0: mmio [e0000000, e05fffff]
[ 0.168542] bus: [00, 05] on node 0 link 0
[ 0.168542] bus: 00 index 0 [io 0x0000-0xffff]
[ 0.168542] bus: 00 index 1 [mem 0x000a0000-0x000bffff]
[ 0.168542] bus: 00 index 2 [mem 0xfe030000-0xffffffff]
[ 0.168542] bus: 00 index 3 [mem 0x80000000-0xfe02ffff]
[ 0.168542] ACPI: bus type pci registered
[ 0.168542] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.168542] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.168542] PCI: Using MMCONFIG for extended config space
[ 0.168542] PCI: Using configuration type 1 for base access
[ 0.169126] bio: create slab <bio-0> at 0
[ 0.169126] ACPI: Added _OSI(Module Device)
[ 0.169126] ACPI: Added _OSI(Processor Device)
[ 0.169126] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.169126] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.172206] ACPI: EC: Look up EC in DSDT
[ 0.178317] ACPI: Interpreter enabled
[ 0.178324] ACPI: (supports S0 S1 S4 S5)
[ 0.178352] ACPI: Using IOAPIC for interrupt routing
[ 0.185356] ACPI: No dock devices found.
[ 0.185363] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.186074] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-05])
[ 0.187419] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.187422] pci_root PNP0A08:00: host bridge window [io 0x6000-0xffff] (ignored)
[ 0.187426] pci_root PNP0A08:00: host bridge window [io 0x03b0-0x03df] (ignored)
[ 0.187429] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.187433] pci_root PNP0A08:00: host bridge window [mem 0x80000000-0xfe02ffff] (ignored)
[ 0.187437] pci_root PNP0A08:00: host bridge window [mem 0xfeb00000-0xfebfffff] (ignored)
[ 0.187440] PCI: root bus 00: hardware-probed resources
[ 0.187484] PCI host bridge to bus 0000:00
[ 0.187488] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.187491] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.187495] pci_bus 0000:00: root bus resource [mem 0xfe030000-0xffffffff]
[ 0.187498] pci_bus 0000:00: root bus resource [mem 0x80000000-0xfe02ffff]
[ 0.187516] pci 0000:00:00.0: [10de:005e] type 00 class 0x058000
[ 0.187586] pci 0000:00:01.0: [10de:0050] type 00 class 0x060100
[ 0.187612] HPET not enabled in BIOS. You might try hpet=force boot option
[ 0.187626] pci 0000:00:01.1: [10de:0052] type 00 class 0x0c0500
[ 0.187636] pci 0000:00:01.1: reg 10: [io 0xfc00-0xfc1f]
[ 0.187651] pci 0000:00:01.1: reg 20: [io 0xf800-0xf83f]
[ 0.187658] pci 0000:00:01.1: reg 24: [io 0xf400-0xf43f]
[ 0.187672] pci 0000:00:01.1: PME# supported from D3hot D3cold
[ 0.187690] pci 0000:00:02.0: [10de:005a] type 00 class 0x0c0310
[ 0.187700] pci 0000:00:02.0: reg 10: [mem 0xfe02f000-0xfe02ffff]
[ 0.187728] pci 0000:00:02.0: supports D1 D2
[ 0.187731] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.187746] pci 0000:00:02.1: [10de:005b] type 00 class 0x0c0320
[ 0.187756] pci 0000:00:02.1: reg 10: [mem 0xfeb00000-0xfeb000ff]
[ 0.187789] pci 0000:00:02.1: supports D1 D2
[ 0.187791] pci 0000:00:02.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.187813] pci 0000:00:06.0: [10de:0053] type 00 class 0x01018a
[ 0.187834] pci 0000:00:06.0: reg 20: [io 0xe800-0xe80f]
[ 0.187863] pci 0000:00:07.0: [10de:0054] type 00 class 0x010185
[ 0.187872] pci 0000:00:07.0: reg 10: [io 0x09f0-0x09f7]
[ 0.187878] pci 0000:00:07.0: reg 14: [io 0x0bf0-0x0bf3]
[ 0.187884] pci 0000:00:07.0: reg 18: [io 0x0970-0x0977]
[ 0.187890] pci 0000:00:07.0: reg 1c: [io 0x0b70-0x0b73]
[ 0.187896] pci 0000:00:07.0: reg 20: [io 0xd400-0xd40f]
[ 0.187902] pci 0000:00:07.0: reg 24: [mem 0xfe02c000-0xfe02cfff]
[ 0.187924] pci 0000:00:08.0: [10de:0055] type 00 class 0x010185
[ 0.187933] pci 0000:00:08.0: reg 10: [io 0x09e0-0x09e7]
[ 0.187940] pci 0000:00:08.0: reg 14: [io 0x0be0-0x0be3]
[ 0.187946] pci 0000:00:08.0: reg 18: [io 0x0960-0x0967]
[ 0.187952] pci 0000:00:08.0: reg 1c: [io 0x0b60-0x0b63]
[ 0.187958] pci 0000:00:08.0: reg 20: [io 0xc000-0xc00f]
[ 0.187965] pci 0000:00:08.0: reg 24: [mem 0xfe02b000-0xfe02bfff]
[ 0.187986] pci 0000:00:09.0: [10de:005c] type 01 class 0x060401
[ 0.188018] pci 0000:00:0a.0: [10de:0057] type 00 class 0x068000
[ 0.188028] pci 0000:00:0a.0: reg 10: [mem 0xfe02a000-0xfe02afff]
[ 0.188034] pci 0000:00:0a.0: reg 14: [io 0xbc00-0xbc07]
[ 0.188060] pci 0000:00:0a.0: supports D1 D2
[ 0.188063] pci 0000:00:0a.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.188079] pci 0000:00:0b.0: [10de:005d] type 01 class 0x060400
[ 0.188109] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.188127] pci 0000:00:0c.0: [10de:005d] type 01 class 0x060400
[ 0.188155] pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.188173] pci 0000:00:0d.0: [10de:005d] type 01 class 0x060400
[ 0.188201] pci 0000:00:0d.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.188218] pci 0000:00:0e.0: [10de:005d] type 01 class 0x060400
[ 0.188246] pci 0000:00:0e.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.188268] pci 0000:00:18.0: [1022:1100] type 00 class 0x060000
[ 0.188293] pci 0000:00:18.1: [1022:1101] type 00 class 0x060000
[ 0.188315] pci 0000:00:18.2: [1022:1102] type 00 class 0x060000
[ 0.188336] pci 0000:00:18.3: [1022:1103] type 00 class 0x060000
[ 0.188379] pci 0000:01:06.0: [2718:5125] type 00 class 0x110000
[ 0.188390] pci 0000:01:06.0: reg 10: [mem 0xfdee0000-0xfdeeffff]
[ 0.188439] pci 0000:01:09.0: [1106:3044] type 00 class 0x0c0010
[ 0.188453] pci 0000:01:09.0: reg 10: [mem 0xfdeff000-0xfdeff7ff]
[ 0.188462] pci 0000:01:09.0: reg 14: [io 0xac00-0xac7f]
[ 0.188504] pci 0000:01:09.0: supports D2
[ 0.188506] pci 0000:01:09.0: PME# supported from D2 D3hot D3cold
[ 0.188533] pci 0000:00:09.0: PCI bridge to [bus 01-01] (subtractive decode)
[ 0.188538] pci 0000:00:09.0: bridge window [io 0xa000-0xafff]
[ 0.188542] pci 0000:00:09.0: bridge window [mem 0xfde00000-0xfdefffff]
[ 0.188546] pci 0000:00:09.0: bridge window [mem 0xfdf00000-0xfdffffff pref]
[ 0.188550] pci 0000:00:09.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.188553] pci 0000:00:09.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.188557] pci 0000:00:09.0: bridge window [mem 0xfe030000-0xffffffff] (subtractive decode)
[ 0.188561] pci 0000:00:09.0: bridge window [mem 0x80000000-0xfe02ffff] (subtractive decode)
[ 0.188586] pci 0000:00:0b.0: PCI bridge to [bus 02-02]
[ 0.188590] pci 0000:00:0b.0: bridge window [io 0x9000-0x9fff]
[ 0.188594] pci 0000:00:0b.0: bridge window [mem 0xfdd00000-0xfddfffff]
[ 0.188600] pci 0000:00:0b.0: bridge window [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.188625] pci 0000:00:0c.0: PCI bridge to [bus 03-03]
[ 0.188630] pci 0000:00:0c.0: bridge window [io 0x8000-0x8fff]
[ 0.188634] pci 0000:00:0c.0: bridge window [mem 0xfdb00000-0xfdbfffff]
[ 0.188639] pci 0000:00:0c.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.188663] pci 0000:00:0d.0: PCI bridge to [bus 04-04]
[ 0.188668] pci 0000:00:0d.0: bridge window [io 0x7000-0x7fff]
[ 0.188672] pci 0000:00:0d.0: bridge window [mem 0xfd900000-0xfd9fffff]
[ 0.188677] pci 0000:00:0d.0: bridge window [mem 0xfd800000-0xfd8fffff 64bit pref]
[ 0.188710] pci 0000:05:00.0: [102b:2539] type 00 class 0x030000
[ 0.188724] pci 0000:05:00.0: reg 10: [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.188735] pci 0000:05:00.0: reg 18: [mem 0xfd7fe000-0xfd7fffff 64bit]
[ 0.188752] pci 0000:05:00.0: reg 30: [mem 0x00000000-0x0001ffff pref]
[ 0.196025] pci 0000:00:0e.0: PCI bridge to [bus 05-05]
[ 0.196030] pci 0000:00:0e.0: bridge window [io 0x6000-0x6fff]
[ 0.196034] pci 0000:00:0e.0: bridge window [mem 0xfd700000-0xfd7fffff]
[ 0.196039] pci 0000:00:0e.0: bridge window [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.196051] pci_bus 0000:00: on NUMA node 0
[ 0.196055] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.196280] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
[ 0.196510] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.237174] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237238] ACPI: PCI Interrupt Link [LNK2] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237302] ACPI: PCI Interrupt Link [LNK3] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.237364] ACPI: PCI Interrupt Link [LNK4] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.237425] ACPI: PCI Interrupt Link [LNK5] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237488] ACPI: PCI Interrupt Link [LUBA] (IRQs 3 *4 5 7 9 10 11 12 14 15)
[ 0.237549] ACPI: PCI Interrupt Link [LUBB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237615] ACPI: PCI Interrupt Link [LMAC] (IRQs 3 4 5 *7 9 10 11 12 14 15)
[ 0.237678] ACPI: PCI Interrupt Link [LACI] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237740] ACPI: PCI Interrupt Link [LMCI] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237803] ACPI: PCI Interrupt Link [LSMB] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.237865] ACPI: PCI Interrupt Link [LUB2] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.237926] ACPI: PCI Interrupt Link [LIDE] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237997] ACPI: PCI Interrupt Link [LSID] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.238066] ACPI: PCI Interrupt Link [LFID] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.238134] ACPI: PCI Interrupt Link [LPCA] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.238180] ACPI: PCI Interrupt Link [APC1] (IRQs *16), disabled.
[ 0.238219] ACPI: PCI Interrupt Link [APC2] (IRQs *17), disabled.
[ 0.238258] ACPI: PCI Interrupt Link [APC3] (IRQs *18)
[ 0.238296] ACPI: PCI Interrupt Link [APC4] (IRQs *19)
[ 0.238334] ACPI: PCI Interrupt Link [APC5] (IRQs *16), disabled.
[ 0.238420] ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0
[ 0.238506] ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22 23) *0, disabled.
[ 0.238594] ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0
[ 0.238679] ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22 23) *0, disabled.
[ 0.238765] ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22 23) *0, disabled.
[ 0.238850] ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0
[ 0.238936] ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0
[ 0.239020] ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled.
[ 0.239113] ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0
[ 0.239205] ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0
[ 0.239297] ACPI: PCI Interrupt Link [APCP] (IRQs 20 21 22 23) *0, disabled.
[ 0.239372] vgaarb: device added: PCI:0000:05:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.239372] vgaarb: loaded
[ 0.239372] vgaarb: bridge control possible 0000:05:00.0
[ 0.239372] PCI: Using ACPI for IRQ routing
[ 0.245045] PCI: pci_cache_line_size set to 64 bytes
[ 0.245108] reserve RAM buffer: 000000000009f400 - 000000000009ffff
[ 0.245112] reserve RAM buffer: 000000007fff0000 - 000000007fffffff
[ 0.245390] pnp: PnP ACPI init
[ 0.245402] ACPI: bus type pnp registered
[ 0.245426] pnp 00:00: [io 0x4000-0x407f]
[ 0.245429] pnp 00:00: [io 0x4080-0x40ff]
[ 0.245432] pnp 00:00: [io 0x4400-0x447f]
[ 0.245435] pnp 00:00: [io 0x4480-0x44ff]
[ 0.245438] pnp 00:00: [io 0x4800-0x487f]
[ 0.245441] pnp 00:00: [io 0x4880-0x48ff]
[ 0.245494] system 00:00: [io 0x4000-0x407f] has been reserved
[ 0.245498] system 00:00: [io 0x4080-0x40ff] has been reserved
[ 0.245502] system 00:00: [io 0x4400-0x447f] has been reserved
[ 0.245506] system 00:00: [io 0x4480-0x44ff] has been reserved
[ 0.245509] system 00:00: [io 0x4800-0x487f] has been reserved
[ 0.245513] system 00:00: [io 0x4880-0x48ff] has been reserved
[ 0.245517] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.246231] pnp 00:01: [bus 00-05]
[ 0.246234] pnp 00:01: [io 0x0cf8-0x0cff]
[ 0.246238] pnp 00:01: [io 0x0000-0x0cf7 window]
[ 0.246241] pnp 00:01: [io 0x6000-0xffff window]
[ 0.246244] pnp 00:01: [io 0x03b0-0x03df window]
[ 0.246248] pnp 00:01: [mem 0x000a0000-0x000bffff window]
[ 0.246251] pnp 00:01: [mem 0x80000000-0xfe02ffff window]
[ 0.246255] pnp 00:01: [mem 0x00000000 window]
[ 0.246259] pnp 00:01: [mem 0xfeb00000-0xfebfffff window]
[ 0.246324] pnp 00:01: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.247028] pnp 00:02: [io 0x0010-0x001f]
[ 0.247031] pnp 00:02: [io 0x0022-0x003f]
[ 0.247035] pnp 00:02: [io 0x0044-0x005f]
[ 0.247038] pnp 00:02: [io 0x0062-0x0063]
[ 0.247041] pnp 00:02: [io 0x0065-0x006f]
[ 0.247044] pnp 00:02: [io 0x0074-0x007f]
[ 0.247047] pnp 00:02: [io 0x0091-0x0093]
[ 0.247050] pnp 00:02: [io 0x00a2-0x00bf]
[ 0.247053] pnp 00:02: [io 0x00e0-0x00ef]
[ 0.247056] pnp 00:02: [io 0x0b78-0x0b7b]
[ 0.247059] pnp 00:02: [io 0x0f78-0x0f7b]
[ 0.247062] pnp 00:02: [io 0x0a78-0x0a7b]
[ 0.247065] pnp 00:02: [io 0x0e78-0x0e7b]
[ 0.247068] pnp 00:02: [io 0x0bbc-0x0bbf]
[ 0.247071] pnp 00:02: [io 0x0fbc-0x0fbf]
[ 0.247074] pnp 00:02: [io 0x04d0-0x04d1]
[ 0.247078] pnp 00:02: [io 0x0290-0x029f]
[ 0.247080] pnp 00:02: [io 0x04e0-0x04e7]
[ 0.247174] system 00:02: [io 0x0b78-0x0b7b] has been reserved
[ 0.247177] system 00:02: [io 0x0f78-0x0f7b] has been reserved
[ 0.247181] system 00:02: [io 0x0a78-0x0a7b] has been reserved
[ 0.247185] system 00:02: [io 0x0e78-0x0e7b] has been reserved
[ 0.247189] system 00:02: [io 0x0bbc-0x0bbf] has been reserved
[ 0.247192] system 00:02: [io 0x0fbc-0x0fbf] has been reserved
[ 0.247196] system 00:02: [io 0x04d0-0x04d1] has been reserved
[ 0.247199] system 00:02: [io 0x0290-0x029f] has been reserved
[ 0.247203] system 00:02: [io 0x04e0-0x04e7] has been reserved
[ 0.247207] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.247225] pnp 00:03: [dma 4]
[ 0.247228] pnp 00:03: [io 0x0000-0x000f]
[ 0.247232] pnp 00:03: [io 0x0080-0x0090]
[ 0.247235] pnp 00:03: [io 0x0094-0x009f]
[ 0.247238] pnp 00:03: [io 0x00c0-0x00df]
[ 0.247288] pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.247304] pnp 00:04: [io 0x0070-0x0073]
[ 0.247319] pnp 00:04: [irq 8]
[ 0.247370] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.247383] pnp 00:05: [io 0x0061]
[ 0.247433] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.247446] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.247453] pnp 00:06: [irq 13]
[ 0.247504] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.248156] pnp 00:07: [mem 0xe0000000-0xefffffff]
[ 0.248233] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.248237] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.248383] pnp 00:08: [mem 0x000d0000-0x000d3fff]
[ 0.248387] pnp 00:08: [mem 0x000f0000-0x000f7fff]
[ 0.248390] pnp 00:08: [mem 0x000f8000-0x000fbfff]
[ 0.248393] pnp 00:08: [mem 0x000fc000-0x000fffff]
[ 0.248397] pnp 00:08: [mem 0x7fff0000-0x7fffffff]
[ 0.248400] pnp 00:08: [mem 0xffff0000-0xffffffff]
[ 0.248403] pnp 00:08: [mem 0x00000000-0x0009ffff]
[ 0.248406] pnp 00:08: [mem 0x00100000-0x7ffeffff]
[ 0.248410] pnp 00:08: [mem 0xfec00000-0xfec00fff]
[ 0.248413] pnp 00:08: [mem 0xfee00000-0xfeefffff]
[ 0.248416] pnp 00:08: [mem 0xfefff000-0xfeffffff]
[ 0.248419] pnp 00:08: [mem 0xfff80000-0xfff80fff]
[ 0.248423] pnp 00:08: [mem 0xfff90000-0xfffbffff]
[ 0.248426] pnp 00:08: [mem 0xfffed000-0xfffeffff]
[ 0.248513] system 00:08: [mem 0x000d0000-0x000d3fff] has been reserved
[ 0.248517] system 00:08: [mem 0x000f0000-0x000f7fff] could not be reserved
[ 0.248521] system 00:08: [mem 0x000f8000-0x000fbfff] could not be reserved
[ 0.248525] system 00:08: [mem 0x000fc000-0x000fffff] could not be reserved
[ 0.248529] system 00:08: [mem 0x7fff0000-0x7fffffff] could not be reserved
[ 0.248532] system 00:08: [mem 0xffff0000-0xffffffff] has been reserved
[ 0.248539] system 00:08: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.248543] system 00:08: [mem 0x00100000-0x7ffeffff] could not be reserved
[ 0.248547] system 00:08: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.248551] system 00:08: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.248555] system 00:08: [mem 0xfefff000-0xfeffffff] has been reserved
[ 0.248558] system 00:08: [mem 0xfff80000-0xfff80fff] has been reserved
[ 0.248562] system 00:08: [mem 0xfff90000-0xfffbffff] has been reserved
[ 0.248566] system 00:08: [mem 0xfffed000-0xfffeffff] has been reserved
[ 0.248570] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.248583] pnp: PnP ACPI: found 9 devices
[ 0.248586] ACPI: ACPI bus type pnp unregistered
[ 0.248590] PnPBIOS: Disabled by ACPI PNP
[ 0.285541] Switching to clocksource acpi_pm
[ 0.285594] pci 0000:00:09.0: PCI bridge to [bus 01-01]
[ 0.285598] pci 0000:00:09.0: bridge window [io 0xa000-0xafff]
[ 0.285603] pci 0000:00:09.0: bridge window [mem 0xfde00000-0xfdefffff]
[ 0.285607] pci 0000:00:09.0: bridge window [mem 0xfdf00000-0xfdffffff pref]
[ 0.285612] pci 0000:00:0b.0: PCI bridge to [bus 02-02]
[ 0.285615] pci 0000:00:0b.0: bridge window [io 0x9000-0x9fff]
[ 0.285620] pci 0000:00:0b.0: bridge window [mem 0xfdd00000-0xfddfffff]
[ 0.285624] pci 0000:00:0b.0: bridge window [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.285629] pci 0000:00:0c.0: PCI bridge to [bus 03-03]
[ 0.285632] pci 0000:00:0c.0: bridge window [io 0x8000-0x8fff]
[ 0.285636] pci 0000:00:0c.0: bridge window [mem 0xfdb00000-0xfdbfffff]
[ 0.285640] pci 0000:00:0c.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.285645] pci 0000:00:0d.0: PCI bridge to [bus 04-04]
[ 0.285648] pci 0000:00:0d.0: bridge window [io 0x7000-0x7fff]
[ 0.285653] pci 0000:00:0d.0: bridge window [mem 0xfd900000-0xfd9fffff]
[ 0.285657] pci 0000:00:0d.0: bridge window [mem 0xfd800000-0xfd8fffff 64bit pref]
[ 0.285666] pci 0000:05:00.0: BAR 6: assigned [mem 0xfd700000-0xfd71ffff pref]
[ 0.285669] pci 0000:00:0e.0: PCI bridge to [bus 05-05]
[ 0.285673] pci 0000:00:0e.0: bridge window [io 0x6000-0x6fff]
[ 0.285677] pci 0000:00:0e.0: bridge window [mem 0xfd700000-0xfd7fffff]
[ 0.285681] pci 0000:00:0e.0: bridge window [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.285691] pci 0000:00:09.0: setting latency timer to 64
[ 0.285706] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.285709] pci_bus 0000:00: resource 5 [mem 0x000a0000-0x000bffff]
[ 0.285712] pci_bus 0000:00: resource 6 [mem 0xfe030000-0xffffffff]
[ 0.285716] pci_bus 0000:00: resource 7 [mem 0x80000000-0xfe02ffff]
[ 0.285719] pci_bus 0000:01: resource 0 [io 0xa000-0xafff]
[ 0.285723] pci_bus 0000:01: resource 1 [mem 0xfde00000-0xfdefffff]
[ 0.285726] pci_bus 0000:01: resource 2 [mem 0xfdf00000-0xfdffffff pref]
[ 0.285729] pci_bus 0000:01: resource 4 [io 0x0000-0xffff]
[ 0.285733] pci_bus 0000:01: resource 5 [mem 0x000a0000-0x000bffff]
[ 0.285736] pci_bus 0000:01: resource 6 [mem 0xfe030000-0xffffffff]
[ 0.285739] pci_bus 0000:01: resource 7 [mem 0x80000000-0xfe02ffff]
[ 0.285742] pci_bus 0000:02: resource 0 [io 0x9000-0x9fff]
[ 0.285746] pci_bus 0000:02: resource 1 [mem 0xfdd00000-0xfddfffff]
[ 0.285749] pci_bus 0000:02: resource 2 [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.285753] pci_bus 0000:03: resource 0 [io 0x8000-0x8fff]
[ 0.285756] pci_bus 0000:03: resource 1 [mem 0xfdb00000-0xfdbfffff]
[ 0.285759] pci_bus 0000:03: resource 2 [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.285763] pci_bus 0000:04: resource 0 [io 0x7000-0x7fff]
[ 0.285766] pci_bus 0000:04: resource 1 [mem 0xfd900000-0xfd9fffff]
[ 0.285769] pci_bus 0000:04: resource 2 [mem 0xfd800000-0xfd8fffff 64bit pref]
[ 0.285773] pci_bus 0000:05: resource 0 [io 0x6000-0x6fff]
[ 0.285776] pci_bus 0000:05: resource 1 [mem 0xfd700000-0xfd7fffff]
[ 0.285780] pci_bus 0000:05: resource 2 [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.285887] NET: Registered protocol family 2
[ 0.285961] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.286237] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.286926] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.287285] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.287288] TCP: reno registered
[ 0.287292] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.287305] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.287432] NET: Registered protocol family 1
[ 0.287645] ACPI: PCI Interrupt Link [APCF] enabled at IRQ 23
[ 0.356171] ACPI: PCI Interrupt Link [APCL] enabled at IRQ 22
[ 0.356206] pci 0000:00:0b.0: Linking AER extended capability
[ 0.356212] pci 0000:00:0c.0: Linking AER extended capability
[ 0.356217] pci 0000:00:0d.0: Linking AER extended capability
[ 0.356222] pci 0000:00:0e.0: Linking AER extended capability
[ 0.356241] pci 0000:05:00.0: Boot video device
[ 0.356244] PCI: CLS 32 bytes, default 64
[ 0.356303] Unpacking initramfs...
[ 0.723533] Freeing initrd memory: 13708k freed
[ 0.732406] audit: initializing netlink socket (disabled)
[ 0.732424] type=2000 audit(1514539782.728:1): initialized
[ 0.747166] highmem bounce pool size: 64 pages
[ 0.747172] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.747490] VFS: Disk quotas dquot_6.5.2
[ 0.747526] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.747611] msgmni has been set to 1721
[ 0.747862] alg: No test for stdrng (krng)
[ 0.747904] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.747909] io scheduler noop registered
[ 0.747911] io scheduler deadline registered
[ 0.747938] io scheduler cfq registered (default)
[ 0.748226] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.748259] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.748262] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.748933] GHES: HEST is not enabled!
[ 0.748947] isapnp: Scanning for PnP cards...
[ 1.101534] isapnp: No Plug & Play device found
[ 1.101613] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.102121] Linux agpgart interface v0.103
[ 1.102448] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.104920] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.104935] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.105096] mousedev: PS/2 mouse device common for all mice
[ 1.105135] rtc_cmos 00:04: RTC can wake from S4
[ 1.105276] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.105300] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 1.105443] TCP: cubic registered
[ 1.105523] NET: Registered protocol family 10
[ 1.105771] Mobile IPv6
[ 1.105775] NET: Registered protocol family 17
[ 1.105780] Registering the dns_resolver key type
[ 1.105833] Using IPI No-Shortcut mode
[ 1.105988] PM: Hibernation image not present or could not be loaded.
[ 1.106005] registered taskstats version 1
[ 1.106383] rtc_cmos 00:04: setting system clock to 2017-12-29 09:29:43 UTC (1514539783)
[ 1.106494] Freeing unused kernel memory: 416k freed
[ 1.106790] Write protecting the kernel text: 3496k
[ 1.106821] Write protecting the kernel read-only data: 984k
[ 1.121289] udevd[49]: starting version 175
[ 1.140866] usbcore: registered new interface driver usbfs
[ 1.140896] usbcore: registered new interface driver hub
[ 1.148875] usbcore: registered new device driver usb
[ 1.155179] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.155255] ehci_hcd 0000:00:02.1: setting latency timer to 64
[ 1.155261] ehci_hcd 0000:00:02.1: EHCI Host Controller
[ 1.155300] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1
[ 1.155333] ehci_hcd 0000:00:02.1: debug port 1
[ 1.155340] ehci_hcd 0000:00:02.1: cache line size of 32 is not supported
[ 1.155363] ehci_hcd 0000:00:02.1: irq 22, io mem 0xfeb00000
[ 1.157331] SCSI subsystem initialized
[ 1.161965] libata version 3.00 loaded.
[ 1.164085] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00
[ 1.164144] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.164149] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.164153] usb usb1: Product: EHCI Host Controller
[ 1.164156] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.164159] usb usb1: SerialNumber: 0000:00:02.1
[ 1.165750] hub 1-0:1.0: USB hub found
[ 1.165759] hub 1-0:1.0: 10 ports detected
[ 1.166345] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.166409] ohci_hcd 0000:00:02.0: setting latency timer to 64
[ 1.166413] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 1.166426] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
[ 1.166461] ohci_hcd 0000:00:02.0: irq 23, io mem 0xfe02f000
[ 1.190574] microcode: AMD CPU family 0xf not supported
[ 1.196162] ACPI: Fan [FAN] (on)
[ 1.222080] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.222086] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.222091] usb usb2: Product: OHCI Host Controller
[ 1.222094] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 1.222096] usb usb2: SerialNumber: 0000:00:02.0
[ 1.222302] hub 2-0:1.0: USB hub found
[ 1.222312] hub 2-0:1.0: 10 ports detected
[ 1.222457] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64.
[ 1.222700] ACPI: PCI Interrupt Link [APCH] enabled at IRQ 21
[ 1.222725] forcedeth 0000:00:0a.0: setting latency timer to 64
[ 1.225301] ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19
[ 1.288074] firewire_ohci 0000:01:09.0: added OHCI v1.0 device as card 0, 4 IR + 8 IT contexts, quirks 0x11
[ 1.536030] usb 1-2: new high-speed USB device number 3 using ehci_hcd
[ 1.669272] usb 1-2: New USB device found, idVendor=0bda, idProduct=8179
[ 1.669277] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.669280] usb 1-2: Product: 802.11n NIC
[ 1.669283] usb 1-2: Manufacturer: Realtek
[ 1.669286] usb 1-2: SerialNumber: 7CDD90D4AD5B
[ 1.744698] forcedeth 0000:00:0a.0: ifname eth0, PHY OUI 0x3f1 @ 1, addr 00:04:61:ab:77:94
[ 1.744705] forcedeth 0000:00:0a.0: highdma csum gbit lnktim desc-v3
[ 1.744741] sata_nv 0000:00:07.0: version 3.5
[ 1.744995] ACPI: PCI Interrupt Link [APSI] enabled at IRQ 20
[ 1.745088] sata_nv 0000:00:07.0: setting latency timer to 64
[ 1.745774] scsi0 : sata_nv
[ 1.746000] scsi1 : sata_nv
[ 1.746173] ata1: SATA max UDMA/133 cmd 0x9f0 ctl 0xbf0 bmdma 0xd400 irq 20
[ 1.746177] ata2: SATA max UDMA/133 cmd 0x970 ctl 0xb70 bmdma 0xd408 irq 20
[ 1.746452] ACPI: PCI Interrupt Link [APSJ] enabled at IRQ 23
[ 1.746512] sata_nv 0000:00:08.0: setting latency timer to 64
[ 1.746801] scsi2 : sata_nv
[ 1.746881] scsi3 : sata_nv
[ 1.747032] ata3: SATA max UDMA/133 cmd 0x9e0 ctl 0xbe0 bmdma 0xc000 irq 23
[ 1.747036] ata4: SATA max UDMA/133 cmd 0x960 ctl 0xb60 bmdma 0xc008 irq 23
[ 1.747078] pata_amd 0000:00:06.0: version 0.4.1
[ 1.747121] pata_amd 0000:00:06.0: setting latency timer to 64
[ 1.747504] scsi4 : pata_amd
[ 1.747735] scsi5 : pata_amd
[ 1.748318] ata5: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xe800 irq 14
[ 1.748321] ata6: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xe808 irq 15
[ 1.748644] ata5: port disabled--ignoring
[ 1.788151] firewire_core 0000:01:09.0: created device fw0: GUID 00046100000cb97a, S400
[ 2.056037] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.140030] usb 2-1: new low-speed USB device number 2 using ohci_hcd
[ 2.212034] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.220357] ata3.00: ATA-9: SanDisk SDSSDP064G, 2.0.0, max UDMA/133
[ 2.220360] ata3.00: 125045424 sectors, multi 1: LBA48 NCQ (depth 0/32)
[ 2.236221] ata3.00: configured for UDMA/133
[ 2.368025] ata2: SATA link down (SStatus 0 SControl 300)
[ 2.368232] scsi 2:0:0:0: Direct-Access ATA SanDisk SDSSDP06 2.0. PQ: 0 ANSI: 5
[ 2.474084] usb 2-1: New USB device found, idVendor=1532, idProduct=0001
[ 2.474088] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.474092] usb 2-1: Product: Razer 1600dpi Mouse
[ 2.474094] usb 2-1: Manufacturer: Razer
[ 2.680033] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.680131] ata6: port disabled--ignoring
[ 2.686587] sd 2:0:0:0: [sda] 125045424 512-byte logical blocks: (64.0 GB/59.6 GiB)
[ 2.686678] sd 2:0:0:0: [sda] Write Protect is off
[ 2.686685] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.686748] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.687680] sda: sda1 sda2 < sda5 >
[ 2.688191] sd 2:0:0:0: [sda] Attached SCSI disk
[ 2.690368] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 2.692165] input: Razer Razer 1600dpi Mouse as /devices/pci0000:00/0000:00:02.0/usb2/2-1/2-1:1.0/input/input0
[ 2.693199] generic-usb 0003:1532:0001.0001: input,hidraw0: USB HID v1.10 Mouse [Razer Razer 1600dpi Mouse] on usb-0000:00:02.0-1/input0
[ 2.693322] usbcore: registered new interface driver usbhid
[ 2.693325] usbhid: USB HID core driver
[ 2.784039] usb 2-3: new low-speed USB device number 3 using ohci_hcd
[ 3.016083] usb 2-3: New USB device found, idVendor=062a, idProduct=0102
[ 3.016089] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.016093] usb 2-3: Product: Wireless Keyboard & Mouse
[ 3.016096] usb 2-3: Manufacturer: MOSART Semi.
[ 3.026616] input: MOSART Semi. Wireless Keyboard & Mouse as /devices/pci0000:00/0000:00:02.0/usb2/2-3/2-3:1.0/input/input1
[ 3.026721] generic-usb 0003:062A:0102.0002: input,hidraw1: USB HID v1.10 Keyboard [MOSART Semi. Wireless Keyboard & Mouse] on usb-0000:00:02.0-3/input0
[ 3.037366] input: MOSART Semi. Wireless Keyboard & Mouse as /devices/pci0000:00/0000:00:02.0/usb2/2-3/2-3:1.1/input/input2
[ 3.037503] generic-usb 0003:062A:0102.0003: input,hiddev0,hidraw2: USB HID v1.10 Mouse [MOSART Semi. Wireless Keyboard & Mouse] on usb-0000:00:02.0-3/input1
[ 3.340028] usb 2-4: new full-speed USB device number 4 using ohci_hcd
[ 3.566078] usb 2-4: New USB device found, idVendor=0403, idProduct=6001
[ 3.566082] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.566086] usb 2-4: Product: USB-SMV2
[ 3.566088] usb 2-4: Manufacturer: FTDI
[ 3.566091] usb 2-4: SerialNumber: AH026T6E
[ 7.776315] microcode: AMD CPU family 0xf not supported
[ 8.176447] PM: Starting manual resume from disk
[ 8.176453] PM: Hibernation image partition 8:5 present
[ 8.176456] PM: Looking for hibernation image.
[ 8.176796] PM: Image not found (code -22)
[ 8.176798] PM: Hibernation image not present or could not be loaded.
[ 8.196340] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.484069] udevd[375]: starting version 175
[ 8.608535] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 8.608544] ACPI: Power Button [PWRB]
[ 8.608755] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 8.608760] ACPI: Power Button [PWRF]
[ 8.610690] i2c i2c-0: nForce2 SMBus adapter at 0xf800
[ 8.610721] i2c i2c-1: nForce2 SMBus adapter at 0xf400
[ 8.695747] microcode: AMD CPU family 0xf not supported
[ 8.715637] usbcore: registered new interface driver usbserial
[ 8.715657] usbcore: registered new interface driver usbserial_generic
[ 8.715673] USB Serial support registered for generic
[ 8.715697] usbserial: USB Serial Driver core
[ 8.717902] usbcore: registered new interface driver ftdi_sio
[ 8.717924] USB Serial support registered for FTDI USB Serial Device
[ 8.717987] ftdi_sio 2-4:1.0: FTDI USB Serial Device converter detected
[ 8.718029] usb 2-4: Detected FT232RL
[ 8.718032] usb 2-4: Number of endpoints 2
[ 8.718035] usb 2-4: Endpoint 1 MaxPacketSize 64
[ 8.718038] usb 2-4: Endpoint 2 MaxPacketSize 64
[ 8.718040] usb 2-4: Setting MaxPacketSize 64
[ 8.722160] usb 2-4: FTDI USB Serial Device converter now attached to ttyUSB0
[ 8.722178] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[ 8.753091] RTL871X: module init start
[ 8.753887] RTL871X: rtl8188eu v4.3.0.8_13968.20150417
[ 8.753891] RTL871X: build time: Apr 1 2017 21:56:46
[ 8.753930] RTL871X:
[ 8.753931] usb_endpoint_descriptor(0):
[ 8.753934] RTL871X: bLength=7
[ 8.753936] RTL871X: bDescriptorType=5
[ 8.753938] RTL871X: bEndpointAddress=81
[ 8.753940] RTL871X: wMaxPacketSize=512
[ 8.753942] RTL871X: bInterval=0
[ 8.753944] RTL871X: RT_usb_endpoint_is_bulk_in = 1
[ 8.753947] RTL871X:
[ 8.753948] usb_endpoint_descriptor(1):
[ 8.753950] RTL871X: bLength=7
[ 8.753952] RTL871X: bDescriptorType=5
[ 8.753954] RTL871X: bEndpointAddress=2
[ 8.753956] RTL871X: wMaxPacketSize=512
[ 8.753959] RTL871X: bInterval=0
[ 8.753961] RTL871X: RT_usb_endpoint_is_bulk_out = 2
[ 8.753963] RTL871X:
[ 8.753964] usb_endpoint_descriptor(2):
[ 8.753966] RTL871X: bLength=7
[ 8.753968] RTL871X: bDescriptorType=5
[ 8.753970] RTL871X: bEndpointAddress=3
[ 8.753972] RTL871X: wMaxPacketSize=512
[ 8.753975] RTL871X: bInterval=0
[ 8.753976] RTL871X: RT_usb_endpoint_is_bulk_out = 3
[ 8.753979] RTL871X: nr_endpoint=3, in_num=1, out_num=2
[ 8.753980]
[ 8.753983] RTL871X: USB_SPEED_HIGH
[ 8.754017] RTL871X: CHIP TYPE: RTL8188E
[ 8.754028] RTL871X: register rtw_netdev_ops to netdev_ops
[ 8.754496] RTL871X: Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_K_CUT_1T1R_RomVer(0)
[ 8.754499] RTL871X: RF_Type is 3!!
[ 8.754503] RTL871X: _ConfigNormalChipOutEP_8188E OutEpQueueSel(0x05), OutEpNumber(2)
[ 8.754787] RTL871X: EEPROM type is E-FUSE
[ 8.754790] RTL871X: ====> _ReadAdapterInfo8188EU
[ 8.755171] RTL871X: Boot from EFUSE, Autoload OK !
[ 8.759926] RTL871X: SetHwReg8188EU: bMacPwrCtrlOn=1
[ 8.760142] bFWReady == _FALSE call reset 8051...
[ 8.761028] RTL871X: =====> _8051Reset88E(): 8051 reset success .
[ 8.775894] RTL871X: efuse_read_phymap_from_txpktbuf bcnhead:0
[ 8.776897] RTL871X: efuse_read_phymap_from_txpktbuf len:111, lenbak:111, aaa:111, aaabak:111
[ 8.785148] RTL871X: efuse_read_phymap_from_txpktbuf read count:109
[ 8.785543] RTL871X: EEPROM ID=0x8129
[ 8.785546] RTL871X: VID = 0x0BDA, PID = 0x8179
[ 8.785549] RTL871X: Customer ID: 0x00, SubCustomer ID: 0xCD
[ 8.785553] RTL871X: Hal_ReadPowerSavingMode88E...bHWPwrPindetect(0)-bHWPowerdown(0) ,bSupportRemoteWakeup(1)
[ 8.785556] RTL871X: ### PS params=> power_mgnt(1),usbss_enable(0) ###
[ 8.785560] RTL871X: ======= Path 0, Channel 1 =======
[ 8.785563] RTL871X: Index24G_CCK_Base[0][1] = 0x30
[ 8.785566] RTL871X: Index24G_BW40_Base[0][1] = 0x30
[ 8.785568] RTL871X: ======= Path 0, Channel 2 =======
[ 8.785571] RTL871X: Index24G_CCK_Base[0][2] = 0x30
[ 8.785574] RTL871X: Index24G_BW40_Base[0][2] = 0x30
[ 8.785577] RTL871X: ======= Path 0, Channel 3 =======
[ 8.785580] RTL871X: Index24G_CCK_Base[0][3] = 0x30
[ 8.785583] RTL871X: Index24G_BW40_Base[0][3] = 0x30
[ 8.785586] RTL871X: ======= Path 0, Channel 4 =======
[ 8.785590] RTL871X: Index24G_CCK_Base[0][4] = 0x30
[ 8.785593] RTL871X: Index24G_BW40_Base[0][4] = 0x30
[ 8.785597] RTL871X: ======= Path 0, Channel 5 =======
[ 8.785600] RTL871X: Index24G_CCK_Base[0][5] = 0x30
[ 8.785604] RTL871X: Index24G_BW40_Base[0][5] = 0x30
[ 8.785607] RTL871X: ======= Path 0, Channel 6 =======
[ 8.785610] RTL871X: Index24G_CCK_Base[0][6] = 0x30
[ 8.785614] RTL871X: Index24G_BW40_Base[0][6] = 0x30
[ 8.785617] RTL871X: ======= Path 0, Channel 7 =======
[ 8.785620] RTL871X: Index24G_CCK_Base[0][7] = 0x30
[ 8.785623] RTL871X: Index24G_BW40_Base[0][7] = 0x30
[ 8.785626] RTL871X: ======= Path 0, Channel 8 =======
[ 8.785629] RTL871X: Index24G_CCK_Base[0][8] = 0x30
[ 8.785631] RTL871X: Index24G_BW40_Base[0][8] = 0x30
[ 8.785634] RTL871X: ======= Path 0, Channel 9 =======
[ 8.785636] RTL871X: Index24G_CCK_Base[0][9] = 0x30
[ 8.785639] RTL871X: Index24G_BW40_Base[0][9] = 0x30
[ 8.785641] RTL871X: ======= Path 0, Channel 10 =======
[ 8.785644] RTL871X: Index24G_CCK_Base[0][10] = 0x30
[ 8.785646] RTL871X: Index24G_BW40_Base[0][10] = 0x30
[ 8.785649] RTL871X: ======= Path 0, Channel 11 =======
[ 8.785651] RTL871X: Index24G_CCK_Base[0][11] = 0x30
[ 8.785654] RTL871X: Index24G_BW40_Base[0][11] = 0x30
[ 8.785656] RTL871X: ======= Path 0, Channel 12 =======
[ 8.785659] RTL871X: Index24G_CCK_Base[0][12] = 0x30
[ 8.785661] RTL871X: Index24G_BW40_Base[0][12] = 0x30
[ 8.785664] RTL871X: ======= Path 0, Channel 13 =======
[ 8.785667] RTL871X: Index24G_CCK_Base[0][13] = 0x30
[ 8.785669] RTL871X: Index24G_BW40_Base[0][13] = 0x30
[ 8.785672] RTL871X: ======= Path 0, Channel 14 =======
[ 8.785675] RTL871X: Index24G_CCK_Base[0][14] = 0x30
[ 8.785677] RTL871X: Index24G_BW40_Base[0][14] = 0x30
[ 8.785680] RTL871X: ======= TxCount 0 =======
[ 8.785682] RTL871X: CCK_24G_Diff[0][0]= 0
[ 8.785685] RTL871X: OFDM_24G_Diff[0][0]= 0
[ 8.785687] RTL871X: BW20_24G_Diff[0][0]= -3
[ 8.785690] RTL871X: BW40_24G_Diff[0][0]= 0
[ 8.785692] RTL871X: EEPROMRegulatory = 0x0
[ 8.785695] RTL871X: mlmepriv.ChannelPlan = 0x20
[ 8.785697] RTL871X: CrystalCap: 0x2d
[ 8.785700] RTL871X: EEPROM Customer ID: 0x 0
[ 8.785702] RTL871X: EEPROM : AntDivCfg = 1, TRxAntDivType = 1
[ 8.785704] RTL871X: Board Type: 0x 0
[ 8.785706] RTL871X: ThermalMeter = 0x1a
[ 8.785709] RTL871X: <==== _ReadAdapterInfo8188EU in 32 ms
[ 8.785821] RTL871X: init_channel_set ChannelPlan ID 20 Chan num:13
[ 8.786293] RTL871X: pwrctrlpriv.bSupportRemoteWakeup~~~~~~
[ 8.786296] RTL871X: pwrctrlpriv.bSupportRemoteWakeup~~~[1]~~~
[ 8.786302] RTL871X: rtw_macaddr_cfg MAC Address = 7c:dd:90:d4:ad:5b
[ 8.786305] RTL871X: bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0
[ 8.786320] RTL871X: rtw_ndev_init(wlan0)
[ 8.786649] RTL871X: _rtw_drv_register_netdev, MAC Address (if1) = 7c:dd:90:d4:ad:5b
[ 8.786720] usbcore: registered new interface driver rtl8188eu
[ 8.786723] RTL871X: module init ret=0
[ 9.180570] Adding 2579452k swap on /dev/sda5. Priority:-1 extents:1 across:2579452k SS
[ 9.198726] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 9.255868] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 9.291391] loop: module loaded
[ 10.143652] RPC: Registered named UNIX socket transport module.
[ 10.143658] RPC: Registered udp transport module.
[ 10.143661] RPC: Registered tcp transport module.
[ 10.143664] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 10.152609] FS-Cache: Loaded
[ 10.161371] NFS: Registering the id_resolver key type
[ 10.161398] FS-Cache: Netfs 'nfs' registered for caching
[ 10.168194] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 11.326939] Bluetooth: Core ver 2.16
[ 11.326977] NET: Registered protocol family 31
[ 11.326980] Bluetooth: HCI device and connection manager initialized
[ 11.326984] Bluetooth: HCI socket layer initialized
[ 11.326987] Bluetooth: L2CAP socket layer initialized
[ 11.326993] Bluetooth: SCO socket layer initialized
[ 11.341130] Bluetooth: RFCOMM TTY layer initialized
[ 11.341138] Bluetooth: RFCOMM socket layer initialized
[ 11.341141] Bluetooth: RFCOMM ver 1.11
[ 11.350122] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.350128] Bluetooth: BNEP filters: protocol multicast
[ 11.385019] lp: driver loaded but no devices found
[ 11.391927] ppdev: user-space parallel port driver
[ 11.459932] RTL871X: LeaveAllPowerSaveMode(wlan0): bup=0 Skip!
[ 11.459938] RTL871X: rtw_wx_set_scan: bDriverStopped=1, bup=0, hw_init_completed=0
[ 11.460751] RTL871X: +871x_drv - drv_open, bup=0
[ 11.460758] RTL871X: Set RF Chip ID to RF_6052 and RF type to 1T1R.
[ 11.461478] RTL871X: rtl8188e_FirmwareDownload fw:NIC, size: 13904
[ 11.461483] RTL871X: rtl8188e_FirmwareDownload: fw_ver=b fw_subver=0001 sig=0x88e1, Month=11, Date=27, Hour=30, Minute=36
[ 11.485986] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00030005
[ 11.487472] RTL871X: =====> _8051Reset88E(): 8051 reset success .
[ 11.490100] RTL871X: _FWFreeToGo: Polling FW ready OK! (18, 4ms), REG_MCUFWDL:0x000300c6
[ 11.490104] RTL871X: FWDL success. write_fw:1, 28ms
[ 11.664945] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input5
[ 11.788582] ==> rtl8188e_iol_efuse_patch
[ 11.863693] RTL871X: ==> _InitAntenna_Selection ....
[ 11.864318] RTL871X: _InitAntenna_Selection,Cur_ant:(1)MAIN_ANT
[ 11.875943] RTL871X: pDM_Odm TxPowerTrackControl = 1
[ 12.168920] RTL871X: rtl8188eu_hal_init in 708ms
[ 12.169538] RTL871X: hw_var_set_opmode()-4042 mode = 2
[ 12.176668] RTL871X: MAC Address = 7c:dd:90:d4:ad:5b
[ 12.184097] RTL871X: -871x_drv - drv_open, bup=1
[ 12.184316] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 12.195539] forcedeth 0000:00:0a.0: eth0: no link during initialization
[ 12.196851] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.212767] RTL871X: [rtw_wx_set_pmkid] IW_PMKSA_FLUSH!
[ 12.212778] RTL871X: set_mode = IW_MODE_INFRA
[ 12.212874] RTL871X: set bssid:00:00:00:00:00:00
[ 12.212930] RTL871X: =>rtw_wx_set_essid
[ 12.212933] RTL871X: ssid=g\xffffffc6isQ\xffffffffJ\xffffffec)\xffffffcd\xffffffba\xffffffba\xffffffab\xfffffff2\xfffffffb\xffffffe3F|\xffffffc2T\xfffffff8\x1b\xffffffe8\xffffffe7\xffffff8dvZ.c3\xffffff9f\xffffffc9\xffffff9a\xffffff9a, len=32
[ 12.212937] RTL871X: set ssid [g\xffffffc6isQ\xffffffffJ\xffffffec)\xffffffcd\xffffffba\xffffffba\xffffffab\xfffffff2\xfffffffb\xffffffe3F|\xffffffc2T\xfffffff8\x1b\xffffffe8\xffffffe7\xffffff8dvZ.c3\xffffff9f\xffffffc9\xffffff9a\xffffff9a\xffffffbd\xffffffe7\xffffffb9N\xfffffff2\xffffffff\xffffffff\xffffffff\x1a\xffffff8b] fw_state=0x00000008
[ 12.212941] RTL871X: Set SSID under fw_state=0x00000008
[ 12.212947] RTL871X: <=rtw_wx_set_essid, ret 0
[ 12.213914] RTL871X: hw_var_set_opmode()-4042 mode = 2
[ 12.220178] RTL871X: [rtw_wx_set_pmkid] IW_PMKSA_FLUSH!
[ 14.303488] RTL871X: survey done event(2) band:0 for wlan0
[ 14.303498] RTL871X: rtw_select_and_join_from_scanned_queue: return _FAIL(candidate == NULL)
[ 14.303502] RTL871X: try_to_join, but select scanning queue fail, to_roam:0
[ 14.303506] RTL871X: indicate disassoc
[ 14.303518] RTL871X: rtw_indicate_scan_done(wlan0)
[ 14.303525] RTL871X: rtl8188e_set_FwJoinBssReport_cmd mstatus(0)
[ 14.304413] RTL871X: ==>rtw_ps_processor .fw_state(8)
[ 14.304418] RTL871X: ==>ips_enter cnts:1
[ 14.304420] RTL871X: nolinked power save enter
[ 14.304423] RTL871X: ===> rtw_ips_pwr_down...................
[ 14.304425] RTL871X: ====> rtw_ips_dev_unload...
[ 14.334650] RTL871X: usb_read_port_cancel
[ 14.334724] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340099] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340221] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340345] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340471] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340595] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340720] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340846] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340856] RTL871X: usb_write_port_cancel
[ 14.340875] RTL871X: ==> rtl8188eu_hal_deinit
[ 14.341349] RTL871X: bkeepfwalive(0)
[ 14.348109] RTL871X: SetHwReg8188EU: bMacPwrCtrlOn=0
[ 14.348115] RTL871X: <=== rtw_ips_pwr_down..................... in 44ms
[ 14.403935] RTL871X: _rtw_pwr_wakeup call ips_leave....
[ 14.403938] RTL871X: ==>ips_leave cnts:1
[ 14.403941] RTL871X: ===> rtw_ips_pwr_up..............
[ 14.403946] RTL871X: ===> ips_netdrv_open.........
[ 14.406976] RTL871X: SetHwReg8188EU: bMacPwrCtrlOn=1
[ 14.406978] RTL871X: Set RF Chip ID to RF_6052 and RF type to 1T1R.
[ 14.407725] RTL871X: rtl8188e_FirmwareDownload fw:NIC, size: 13904
[ 14.407729] RTL871X: rtl8188e_FirmwareDownload: fw_ver=b fw_subver=0001 sig=0x88e1, Month=11, Date=27, Hour=30, Minute=36
[ 14.426725] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00030005
[ 14.428224] RTL871X: =====> _8051Reset88E(): 8051 reset success .
[ 14.430847] RTL871X: _FWFreeToGo: Polling FW ready OK! (21, 4ms), REG_MCUFWDL:0x000300c6
[ 14.430850] RTL871X: FWDL success. write_fw:1, 20ms
[ 14.716706] ==> rtl8188e_iol_efuse_patch
[ 14.791825] RTL871X: ==> _InitAntenna_Selection ....
[ 14.792571] RTL871X: _InitAntenna_Selection,Cur_ant:(1)MAIN_ANT
[ 14.804448] RTL871X: pDM_Odm TxPowerTrackControl = 1
[ 15.053300] RTL871X: rtl8188eu_hal_init in 652ms
[ 15.053921] RTL871X: hw_var_set_opmode()-4042 mode = 2
[ 15.062308] RTL871X: <=== rtw_ips_pwr_up.............. in 660ms
[ 15.062314] RTL871X: nolinked power save leave
[ 15.062417] RTL871X: ==> ips_leave.....LED(0x00828282)...
[ 15.062422] RTL871X: IW_SCAN_THIS_ESSID, ssid=Net_M, len=5
[ 17.160249] RTL871X: survey done event(2) band:0 for wlan0
[ 17.160259] RTL871X: rtw_indicate_scan_done(wlan0)
[ 17.160620] RTL871X: wpa_set_auth_algs, AUTH_ALG_OPEN_SYSTEM
[ 17.160629] RTL871X: set_mode = IW_MODE_INFRA
[ 17.160646] RTL871X:
[ 17.160647] wpa_ie(length:22):
[ 17.160650] RTL871X: 0x30 0x14 0x01 0x00 0x00 0x0f 0xac 0x02
[ 17.160654] RTL871X: 0x01 0x00 0x00 0x0f 0xac 0x04 0x01 0x00
[ 17.160658] RTL871X: 0x00 0x0f 0xac 0x02 0x00 0x00 0x52 0xf4
[ 17.160996] RTL871X: SetHwReg8188EU, 2964, RCR= 700060ca
[ 17.161009] RTL871X: rtw_wx_set_freq: set to channel 3
[ 17.161016] RTL871X: =>rtw_wx_set_essid
[ 17.161018] RTL871X: ssid=Net_M, len=5
[ 17.161022] RTL871X: set ssid [Net_M] fw_state=0x00000008
[ 17.161025] RTL871X: Set SSID under fw_state=0x00000008
[ 17.161031] RTL871X: [by_bssid:0][assoc_ssid:Net_M][to_roam:0] new candidate: Net_M(00:a0:57:19:f0:39, ch3) rssi:-49
[ 17.161036] RTL871X: rtw_select_and_join_from_scanned_queue: candidate: Net_M(00:a0:57:19:f0:39, ch:3)
[ 17.161039] RTL871X: #### Opt_Ant_(A) , cur_Ant(A)
[ 17.161045] RTL871X: link to new AP
[ 17.161050] RTL871X: <=rtw_wx_set_essid, ret 0
[ 17.161056] RTL871X: set bssid:00:a0:57:19:f0:39
[ 17.161058] RTL871X: Set BSSID under fw_state=0x00000088
[ 17.161615] RTL871X: hw_var_set_opmode()-4042 mode = 2
[ 17.162239] RTL871X: start_join_set_ch_bw: ch=3, bwmode=0, ch_offset=0
[ 17.192376] RTL871X: link to new AP
[ 17.192379] RTL871X: start auth
[ 17.192383] RTL871X: issue_auth
[ 17.193861] RTL871X: OnAuthClient
[ 17.193863] RTL871X: auth success, start assoc
[ 17.193869] RTL871X: network.SupportedRates[0]=0C
[ 17.193872] RTL871X: network.SupportedRates[1]=12
[ 17.193874] RTL871X: network.SupportedRates[2]=98
[ 17.193876] RTL871X: network.SupportedRates[3]=24
[ 17.193878] RTL871X: network.SupportedRates[4]=30
[ 17.193881] RTL871X: network.SupportedRates[5]=48
[ 17.193883] RTL871X: network.SupportedRates[6]=60
[ 17.193885] RTL871X: network.SupportedRates[7]=6C
[ 17.193888] RTL871X: bssrate_len = 8
[ 17.195861] RTL871X: OnAssocRsp
[ 17.195865] RTL871X: report_join_res(3)
[ 17.195869] RTL871X: rtw_joinbss_update_network
[ 17.195877] RTL871X: rtw_alloc_macid = 0
[ 17.195879] RTL871X: rtw_joinbss_update_stainfo
[ 17.195883] RTL871X: ### Set STA_(0) info
[ 17.195887] RTL871X: assoc success
[ 17.195919] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x15f -> 0x15f
[ 17.196107] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 17.198115] RTL871X: HTOnAssocRsp
[ 17.198622] RTL871X: recv eapol packet
[ 17.199492] RTL871X: send eapol packet
[ 17.204743] RTL871X: UpdateHalRAMask8188E => mac_id:0, networkType:0x02, mask:0x00000ff0
[ 17.204745] ==> rssi_level:0, rate_bitmap:0x00000ff0
[ 17.204750] RTL871X: ### MacID(1),Set Max Tx RPT MID(2)
[ 17.204860] RTL871X: ### rtl8188e_set_FwMediaStatus_cmd: MStatus=1 MACID=0
[ 17.205860] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 17.206985] RTL871X: rtl8188e_set_FwJoinBssReport_cmd mstatus(1)
[ 17.208119] RTL871X: SetFwRsvdPagePkt(wlan0)
[ 17.208122] RsvdPageNum: 8
[ 17.208134] RTL871X: SetFwRsvdPagePkt: Set RSVD page location to Fw ,TotalPacketLen(706)
[ 17.209109] RTL871X: wlan0: 1 DL RSVD page success! DLBcnCount:1, poll:1
[ 17.209858] RTL871X: Set RSVD page location to Fw.
[ 17.209984] RTL871X: =>mlmeext_joinbss_event_callback
[ 17.499852] RTL871X: recv eapol packet
[ 17.499978] RTL871X: send eapol packet
[ 17.504965] RTL871X: recv eapol packet
[ 17.505082] RTL871X: send eapol packet
[ 17.505098] RTL871X: ~~~~set sta key:unicastkey
[ 17.505127] RTL871X: set pairwise key camid:4, addr:00:a0:57:19:f0:39, kid:0, type:AES
[ 17.505191] RTL871X: ~~~~set sta key:groupkey
[ 17.505195] RTL871X: ==> rtw_set_key algorithm(2),keyid(1),key_mask(0)
[ 17.508840] RTL871X: set group key camid:5, addr:00:a0:57:19:f0:39, kid:1, type:TKIP
[ 17.509209] RTL871X: SetHwReg8188EU, 2960, RCR= 700060ce
[ 19.074462] RTL871X: UpdateHalRAMask8188E => mac_id:0, networkType:0x02, mask:0x00000ff0
[ 19.074464] ==> rssi_level:1, rate_bitmap:0x00000f00
[ 21.078166] RTL871X: UpdateHalRAMask8188E => mac_id:0, networkType:0x02, mask:0x00000ff0
[ 21.078168] ==> rssi_level:2, rate_bitmap:0x00000ff0
[ 28.032021] wlan0: no IPv6 routers present
[ 29.558929] I-pipe: head domain RTAI registered.
[ 29.558937] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 29.558985] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 29.558990] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12557835, CLK_FREQ 2009406000, CPU_FREQ 2009406000
[ 29.558994] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 29.558998] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12557835, 12557835, 12003250
[ 29.581508] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 29.581566] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 29.581571] RTAI[sched]: hard timer type/freq = APIC/12557835(Hz); default timing: oneshot; linear timed lists.
[ 29.581575] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2009406000 hz.
[ 29.581578] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 29.596157] RTAI[math]: loaded.
[ 29.693802] hm2: loading Mesa HostMot2 driver version 0.15
[ 29.697887] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 29.698034] ACPI: PCI Interrupt Link [APC3] enabled at IRQ 18
[ 29.698054] hm2_pci: discovered 5i25 at 0000:01:06.0
[ 29.699096] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 29.756103] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 29.758848] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 29.761137] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 29.765151] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 29.770336] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 29.894217] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 29.896764] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 29.997000] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 29.997004] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 29.997008] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 29.997011] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 29.997015] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 29.997019] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 29.997023] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 29.997027] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 29.997031] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 29.997035] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 29.997039] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 29.997043] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 29.997047] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 29.997050] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 29.997054] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 29.997058] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 29.997062] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 29.997066] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 29.997070] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #0, pin Direction (Output)
[ 29.997073] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #0, pin Step (Output)
[ 29.997077] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #1, pin Direction (Output)
[ 29.997081] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #1, pin Step (Output)
[ 29.997084] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #2, pin Direction (Output)
[ 29.997088] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #2, pin Step (Output)
[ 29.997092] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #3, pin Direction (Output)
[ 29.997095] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #3, pin Step (Output)
[ 29.997099] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #4, pin Direction (Output)
[ 29.997104] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #4, pin Step (Output)
[ 29.997107] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 29.997110] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 29.997113] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 29.997116] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 29.997119] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 29.997122] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 29.997125] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 29.997291] hm2/hm2_5i25.0: registered
[ 29.997294] hm2_5i25.0: initialized AnyIO board at 0000:01:06.0
[ 30.327270] hm2_5i25.0: dropping AnyIO board at 0000:01:06.0
[ 30.327277] hm2/hm2_5i25.0: unregistered
[ 30.327342] hm2_pci: driver unloaded
[ 30.329735] hm2: unloading
[ 32.001926] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 32.458196] RTAI[math]: unloaded.
[ 32.461183] SCHED releases registered named ALIEN PEDV$D
[ 32.467479] RTAI[malloc]: unloaded.
[ 32.564031] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 32.566688] I-pipe: head domain RTAI unregistered.
[ 32.566742] RTAI[hal]: unmounted.
[ 33.415741] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 33.417615] RTL871X: survey done event(2) band:0 for wlan0
[ 33.417633] RTL871X: rtw_indicate_scan_done(wlan0)
[ 39.109387] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 39.111126] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 67.165127] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 72.006727] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 72.006735] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 72.012336] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 73.419346] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 73.421844] RTL871X: survey done event(2) band:0 for wlan0
[ 73.421850] RTL871X: rtw_indicate_scan_done(wlan0)
[ 75.181324] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 75.181331] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 99.229283] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 99.229289] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 109.249435] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 109.249443] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 129.288855] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 132.006665] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 132.006672] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 132.016249] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 133.424253] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 133.426369] RTL871X: survey done event(3) band:0 for wlan0
[ 133.426376] RTL871X: rtw_indicate_scan_done(wlan0)
[ 135.301221] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 135.301229] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 137.305050] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 137.305058] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 139.308881] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 139.308889] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 163.356962] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 179.388601] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 195.421239] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 201.432604] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 201.432611] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 203.436437] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 203.436444] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 212.002897] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 212.002905] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 212.012343] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 213.423460] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 213.425582] RTL871X: survey done event(2) band:0 for wlan0
[ 213.425592] RTL871X: rtw_indicate_scan_done(wlan0)
[ 213.456586] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 213.456593] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 213.815181] I-pipe: head domain RTAI registered.
[ 213.815191] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 213.815244] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 213.815249] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12557835, CLK_FREQ 2009406000, CPU_FREQ 2009406000
[ 213.815252] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 213.815256] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12557835, 12557835, 10894250
[ 213.824090] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 213.824176] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 213.824182] RTAI[sched]: hard timer type/freq = APIC/12557835(Hz); default timing: oneshot; linear timed lists.
[ 213.824186] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2009406000 hz.
[ 213.824189] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 213.829850] RTAI[math]: loaded.
[ 213.999804] hm2: loading Mesa HostMot2 driver version 0.15
[ 214.002519] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 214.002568] hm2_pci: discovered 5i25 at 0000:01:06.0
[ 214.003844] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 214.060730] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 214.063376] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 214.065715] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 214.069845] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 214.074821] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 214.198900] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 214.201447] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 214.301567] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 214.301571] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 214.301574] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 214.301578] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 214.301582] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 214.301586] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 214.301590] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 214.301594] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 214.301598] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 214.301602] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 214.301606] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 214.301610] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 214.301614] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 214.301618] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 214.301621] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 214.301625] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 214.301629] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 214.301633] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 214.301637] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #0, pin Direction (Output)
[ 214.301641] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #0, pin Step (Output)
[ 214.301644] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #1, pin Direction (Output)
[ 214.301648] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #1, pin Step (Output)
[ 214.301652] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #2, pin Direction (Output)
[ 214.301656] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #2, pin Step (Output)
[ 214.301659] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #3, pin Direction (Output)
[ 214.301663] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #3, pin Step (Output)
[ 214.301667] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #4, pin Direction (Output)
[ 214.301670] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #4, pin Step (Output)
[ 214.301674] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 214.301677] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 214.301680] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 214.301683] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 214.301686] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 214.301689] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 214.301693] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 214.301858] hm2/hm2_5i25.0: registered
[ 214.301862] hm2_5i25.0: initialized AnyIO board at 0000:01:06.0
[ 214.559058] hm2_5i25.0: dropping AnyIO board at 0000:01:06.0
[ 214.559066] hm2/hm2_5i25.0: unregistered
[ 214.559132] hm2_pci: driver unloaded
[ 214.561419] hm2: unloading
[ 216.684648] RTAI[math]: unloaded.
[ 216.686871] SCHED releases registered named ALIEN PEDV$D
[ 216.701231] RTAI[malloc]: unloaded.
[ 216.800024] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 216.802288] I-pipe: head domain RTAI unregistered.
[ 216.802341] RTAI[hal]: unmounted.
[ 221.473029] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 237.504668] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 253.537306] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 269.568823] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 269.568831] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 271.572653] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 271.572660] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 291.613074] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 307.644713] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 312.004536] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 312.004543] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 312.012343] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 313.423972] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 313.426345] RTL871X: survey done event(3) band:0 for wlan0
[ 313.426351] RTL871X: rtw_indicate_scan_done(wlan0)
[ 313.657078] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 313.657084] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 323.677352] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 355.740631] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 371.773269] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 387.804908] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 423.876846] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 432.007469] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 432.007477] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 432.016442] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 433.427786] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 433.429408] RTL871X: survey done event(1) band:0 for wlan0
[ 433.429415] RTL871X: rtw_indicate_scan_done(wlan0)
[ 433.896872] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 433.896879] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 439.909483] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 448.722997] I-pipe: head domain RTAI registered.
[ 448.723005] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 448.723056] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 448.723060] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12557835, CLK_FREQ 2009406000, CPU_FREQ 2009406000
[ 448.723064] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 448.723068] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12557835, 12557835, 11380750
[ 448.731516] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 448.731574] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 448.731580] RTAI[sched]: hard timer type/freq = APIC/12557835(Hz); default timing: oneshot; linear timed lists.
[ 448.731584] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2009406000 hz.
[ 448.731587] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 448.739971] RTAI[math]: loaded.
[ 448.907247] hm2: loading Mesa HostMot2 driver version 0.15
[ 448.909697] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 448.909750] hm2_pci: discovered 5i25 at 0000:01:06.0
[ 448.911017] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 448.967949] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 448.970645] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 448.972884] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 448.976947] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 448.982029] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 449.105642] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 449.108183] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 449.208335] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 449.208339] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 449.208343] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 449.208346] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 449.208350] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 449.208355] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 449.208359] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 449.208363] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 449.208367] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 449.208371] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 449.208374] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 449.208378] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 449.208382] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 449.208386] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 449.208390] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 449.208394] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 449.208398] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 449.208402] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 449.208406] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #0, pin Direction (Output)
[ 449.208409] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #0, pin Step (Output)
[ 449.208413] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #1, pin Direction (Output)
[ 449.208417] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #1, pin Step (Output)
[ 449.208421] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #2, pin Direction (Output)
[ 449.208424] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #2, pin Step (Output)
[ 449.208428] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #3, pin Direction (Output)
[ 449.208432] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #3, pin Step (Output)
[ 449.208435] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #4, pin Direction (Output)
[ 449.208439] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #4, pin Step (Output)
[ 449.208442] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 449.208445] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 449.208449] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 449.208452] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 449.208455] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 449.208458] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 449.208461] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 449.208626] hm2/hm2_5i25.0: registered
[ 449.208629] hm2_5i25.0: initialized AnyIO board at 0000:01:06.0
[ 449.480059] hm2_5i25.0: dropping AnyIO board at 0000:01:06.0
[ 449.480066] hm2/hm2_5i25.0: unregistered
[ 449.480304] hm2_pci: driver unloaded
[ 449.482456] hm2: unloading
[ 451.605946] RTAI[math]: unloaded.
[ 451.608313] SCHED releases registered named ALIEN PEDV$D
[ 451.614178] RTAI[malloc]: unloaded.
[ 451.712034] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 451.714478] I-pipe: head domain RTAI unregistered.
[ 451.714531] RTAI[hal]: unmounted.
[ 455.941124] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 492.013062] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 508.044700] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 524.077338] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 536.101191] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 536.101200] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 540.108851] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 540.108864] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 542.112677] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 542.112685] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 550.129005] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 550.129014] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 552.004566] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 552.004575] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 552.012809] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 553.423586] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 553.425586] RTL871X: survey done event(1) band:0 for wlan0
[ 553.425614] RTL871X: rtw_indicate_scan_done(wlan0)
[ 556.140496] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 556.140504] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 564.156810] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 564.156818] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 578.184622] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 578.184630] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 586.200942] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 586.200950] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 588.204775] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 588.204783] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 594.217256] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 594.217264] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 598.224921] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 598.224930] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 600.228753] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 600.228761] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 602.232581] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 602.232589] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 604.237414] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 604.237422] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 608.245074] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 608.245082] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 616.261391] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 616.261399] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 618.265223] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 618.265231] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 620.268424] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 620.268432] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 622.272883] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 622.272891] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 624.276710] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 624.276717] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 628.285372] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 628.285380] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 630.289197] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 630.289206] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 634.296861] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 634.296869] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 636.300692] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 636.300699] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 638.304521] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 638.304528] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 646.320837] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 646.320844] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 648.324667] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 648.324674] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 656.340989] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 656.340995] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 658.344820] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 658.344828] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 660.348650] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 660.348658] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 662.352480] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 662.352488] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 666.361139] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 666.361147] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 668.364970] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 668.364977] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 672.006974] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 672.006983] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 672.016306] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 673.427412] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 673.429533] RTL871X: survey done event(3) band:0 for wlan0
[ 673.429539] RTL871X: rtw_indicate_scan_done(wlan0)
[ 674.376458] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 674.376466] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 676.381289] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 676.381297] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 678.385117] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 678.385126] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 680.388948] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 680.388956] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 682.392779] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 682.392787] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 690.409097] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 690.409105] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 692.412927] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 692.412935] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 720.898745] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_SPECIAL_PACKET
[ 720.898755] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 722.473376] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 722.473384] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 746.521334] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 746.521342] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 750.528998] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 750.529006] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 766.560755] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 782.593395] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 792.007341] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 792.007349] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 792.016427] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 793.424225] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 793.426216] RTL871X: survey done event(3) band:0 for wlan0
[ 793.426223] RTL871X: rtw_indicate_scan_done(wlan0)
[ 794.617253] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 794.617262] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 800.628739] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 800.628747] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 802.632570] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 802.632578] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 808.645311] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 808.645318] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 810.648892] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 810.648901] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 812.652720] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 812.652727] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 814.656551] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 814.656559] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 832.693142] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 848.724781] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 864.757419] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 900.829356] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 912.004653] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 912.004661] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 912.012529] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 913.424041] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 913.426071] RTL871X: survey done event(3) band:0 for wlan0
[ 913.426092] RTL871X: rtw_indicate_scan_done(wlan0)
[ 918.864701] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 918.864711] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 926.881029] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 926.881041] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 928.884853] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 928.884861] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 930.888683] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 930.888690] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 936.901169] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 936.901178] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 962.952962] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 962.952970] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 964.956791] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 964.956799] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 968.965451] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 968.965458] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 970.969283] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 970.969291] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 972.973107] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 972.973116] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 980.989431] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 980.989439] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 995.017359] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 1027.538791] I-pipe: head domain RTAI registered.
[ 1027.538800] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1027.538845] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1027.538850] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12557835, CLK_FREQ 2009406000, CPU_FREQ 2009406000
[ 1027.538854] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1027.538858] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12557835, 12557835, 12475250
[ 1027.547813] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1027.547870] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1027.547876] RTAI[sched]: hard timer type/freq = APIC/12557835(Hz); default timing: oneshot; linear timed lists.
[ 1027.547880] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2009406000 hz.
[ 1027.547883] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1027.558088] RTAI[math]: loaded.
[ 1027.725346] hm2: loading Mesa HostMot2 driver version 0.15
[ 1027.727735] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1027.727783] hm2_pci: discovered 5i25 at 0000:01:06.0
[ 1027.728868] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1027.786003] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 1027.788794] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 1027.791188] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 1027.795224] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 1027.800402] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 1027.924521] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 1027.927067] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 1028.027093] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1028.027097] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 1028.027101] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 1028.027104] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 1028.027108] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 1028.027112] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 1028.027116] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 1028.027120] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 1028.027124] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 1028.027128] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 1028.027132] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 1028.027135] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 1028.027139] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 1028.027143] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 1028.027147] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 1028.027151] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 1028.027154] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 1028.027158] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 1028.027162] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #0, pin Direction (Output)
[ 1028.027166] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #0, pin Step (Output)
[ 1028.027170] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #1, pin Direction (Output)
[ 1028.027173] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #1, pin Step (Output)
[ 1028.027177] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #2, pin Direction (Output)
[ 1028.027180] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #2, pin Step (Output)
[ 1028.027184] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #3, pin Direction (Output)
[ 1028.027188] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #3, pin Step (Output)
[ 1028.027191] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #4, pin Direction (Output)
[ 1028.027195] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #4, pin Step (Output)
[ 1028.027198] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 1028.027201] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 1028.027204] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 1028.027207] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 1028.027210] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 1028.027213] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 1028.027217] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 1028.027382] hm2/hm2_5i25.0: registered
[ 1028.027385] hm2_5i25.0: initialized AnyIO board at 0000:01:06.0
[ 1028.302364] hm2_5i25.0: dropping AnyIO board at 0000:01:06.0
[ 1028.302372] hm2/hm2_5i25.0: unregistered
[ 1028.302438] hm2_pci: driver unloaded
[ 1028.304735] hm2: unloading
[ 1030.429512] RTAI[math]: unloaded.
[ 1030.431808] SCHED releases registered named ALIEN PEDV$D
[ 1030.435091] RTAI[malloc]: unloaded.
[ 1030.532026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1030.534299] I-pipe: head domain RTAI unregistered.
[ 1030.534355] RTAI[hal]: unmounted.
[ 1032.006575] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1032.006583] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1032.012436] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 1033.423850] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 1033.425848] RTL871X: survey done event(3) band:0 for wlan0
[ 1033.425856] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1037.100667] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1037.100675] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1059.144917] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 1093.212906] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1093.212914] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1095.216733] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1095.216740] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1099.225393] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1099.225399] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1101.229223] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1101.229230] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1115.257157] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 1131.288793] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 1152.007536] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1152.007545] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1152.016286] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 1153.427664] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 1153.429537] RTL871X: survey done event(4) band:0 for wlan0
[ 1153.429563] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1159.345290] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1159.345297] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1173.373223] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 1189.404858] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 1191.408573] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1191.408581] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1195.417231] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1195.417239] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1197.421061] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1197.421069] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1199.424889] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1199.424897] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1217.554991] I-pipe: head domain RTAI registered.
[ 1217.554999] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1217.555046] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1217.555051] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12557835, CLK_FREQ 2009406000, CPU_FREQ 2009406000
[ 1217.555055] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1217.555059] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12557835, 12557835, 11417500
[ 1217.567561] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1217.567621] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1217.567709] RTAI[sched]: hard timer type/freq = APIC/12557835(Hz); default timing: oneshot; linear timed lists.
[ 1217.567714] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2009406000 hz.
[ 1217.567717] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1217.573352] RTAI[math]: loaded.
[ 1217.743267] hm2: loading Mesa HostMot2 driver version 0.15
[ 1217.746046] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1217.746096] hm2_pci: discovered 5i25 at 0000:01:06.0
[ 1217.747352] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1217.804257] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 1217.806903] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 1217.809142] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 1217.813206] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 1217.818287] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 1217.941830] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 1217.944376] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 1218.044490] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1218.044494] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 1218.044497] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 1218.044499] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 1218.044503] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 1218.044507] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 1218.044511] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 1218.044515] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 1218.044519] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 1218.044523] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 1218.044526] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 1218.044530] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 1218.044534] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 1218.044537] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 1218.044541] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 1218.044544] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 1218.044548] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 1218.044552] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 1218.044556] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #0, pin Direction (Output)
[ 1218.044559] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #0, pin Step (Output)
[ 1218.044563] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #1, pin Direction (Output)
[ 1218.044566] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #1, pin Step (Output)
[ 1218.044570] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #2, pin Direction (Output)
[ 1218.044573] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #2, pin Step (Output)
[ 1218.044577] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #3, pin Direction (Output)
[ 1218.044581] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #3, pin Step (Output)
[ 1218.044584] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #4, pin Direction (Output)
[ 1218.044588] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #4, pin Step (Output)
[ 1218.044591] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 1218.044593] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 1218.044596] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 1218.044599] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 1218.044602] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 1218.044605] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 1218.044607] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 1218.044772] hm2/hm2_5i25.0: registered
[ 1218.044775] hm2_5i25.0: initialized AnyIO board at 0000:01:06.0
[ 1218.319377] hm2_5i25.0: dropping AnyIO board at 0000:01:06.0
[ 1218.319385] hm2/hm2_5i25.0: unregistered
[ 1218.319451] hm2_pci: driver unloaded
[ 1218.321990] hm2: unloading
[ 1220.444296] RTAI[math]: unloaded.
[ 1220.446556] SCHED releases registered named ALIEN PEDV$D
[ 1220.454285] RTAI[malloc]: unloaded.
[ 1220.552026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1220.554331] I-pipe: head domain RTAI unregistered.
[ 1220.554387] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.8.0-pre1-3393-g8afc258
Machine configuration directory is '/home/linuxcnc/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/home/linuxcnc/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
VERSION=1.0
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./my_LinuxCNC_machine.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=4544
Debug file information:
./my_LinuxCNC_machine.hal:318: Signal 'spindle-override' can not add OUT pin 'halui.spindle-override.value', it already has OUT pin 'spindle-scale.out'
4544
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f400 (usable)
[ 0.000000] BIOS-e820: 000000000009f400 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007fff0000 (usable)
[ 0.000000] BIOS-e820: 000000007fff0000 - 000000007fff3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007fff3000 - 0000000080000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.2 present.
[ 0.000000] DMI: /nForce4 DDR: 9NPA+ / 9NPA+Ultra / 9NPAJ / 9NPA Ultra Series, BIOS 6.00 PG 08/11/2006
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7fff0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask FF80000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00f4250] f4250
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 3652a000 - 3728d000
[ 0.000000] ACPI: RSDP 000f8380 00014 (v00 Nvidia)
[ 0.000000] ACPI: RSDT 7fff3040 00030 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 7fff30c0 00074 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 7fff3180 06633 (v01 NVIDIA AWRDACPI 00001000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 7fff0000 00040
[ 0.000000] ACPI: MCFG 7fff98c0 0003C (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: APIC 7fff9800 0007C (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1159MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007fff0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0007fff0
[ 0.000000] On node 0 totalpages: 524159
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f552a200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2320 pages used for memmap
[ 0.000000] HighMem zone: 294626 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] Nvidia board detected. Ignoring ACPI timer override.
[ 0.000000] If you got timer trouble try acpi_use_timer_override
[ 0.000000] ACPI: PM-Timer IO Port: 0x4008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: BIOS IRQ0 override ignored.
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] ACPI: IRQ14 used by override.
[ 0.000000] ACPI: IRQ15 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:60000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77cf000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 520063
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=61e7afdd-fdbe-4754-b456-10b0e2c56271 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 4194048 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007fff0)
[ 0.000000] Memory: 2055600k/2097088k available (3495k kernel code, 41036k reserved, 1237k data, 416k init, 1187784k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f5006000 soft=f5008000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2009.406 MHz processor.
[ 0.000000] Marking TSC unstable due to TSCs unsynchronized
[ 0.008005] Calibrating delay loop (skipped), value calculated using timer frequency.. 4018.81 BogoMIPS (lpj=8037624)
[ 0.008010] pid_max: default: 32768 minimum: 301
[ 0.008064] Security Framework initialized
[ 0.008070] AppArmor: AppArmor disabled by boot time parameter
[ 0.008090] Mount-cache hash table entries: 512
[ 0.008298] Initializing cgroup subsys cpuacct
[ 0.008301] Initializing cgroup subsys memory
[ 0.008310] Initializing cgroup subsys devices
[ 0.008312] Initializing cgroup subsys freezer
[ 0.008315] Initializing cgroup subsys net_cls
[ 0.008317] Initializing cgroup subsys blkio
[ 0.008325] Initializing cgroup subsys perf_event
[ 0.008351] CPU: Physical Processor ID: 0
[ 0.008353] CPU: Processor Core ID: 0
[ 0.008356] mce: CPU supports 5 MCE banks
[ 0.008413] ACPI: Core revision 20120320
[ 0.016090] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.016447] ..TIMER: vector=0x30 apic1=0 pin1=0 apic2=-1 pin2=-1
[ 0.056432] CPU0: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ stepping 01
[ 0.060003] Performance Events: AMD PMU driver.
[ 0.060003] ... version: 0
[ 0.060003] ... bit width: 48
[ 0.060003] ... generic registers: 4
[ 0.060003] ... value mask: 0000ffffffffffff
[ 0.060003] ... max period: 00007fffffffffff
[ 0.060003] ... fixed-purpose events: 0
[ 0.060003] ... event mask: 000000000000000f
[ 0.068026] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.080023] CPU 1 irqstacks, hard=f5094000 soft=f5096000
[ 0.080025] Booting Node 0, Processors #1 Ok.
[ 0.012000] Initializing CPU#1
[ 0.168103] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.168134] Brought up 2 CPUs
[ 0.168138] Total of 2 processors activated (8037.58 BogoMIPS).
[ 0.168542] devtmpfs: initialized
[ 0.168542] PM: Registering ACPI NVS region [mem 0x7fff0000-0x7fff2fff] (12288 bytes)
[ 0.168542] dummy:
[ 0.168542] NET: Registered protocol family 16
[ 0.168542] node 0 link 0: io port [6000, ffff]
[ 0.168542] TOM: 0000000080000000 aka 2048M
[ 0.168542] node 0 link 0: mmio [a0000, bffff]
[ 0.168542] node 0 link 0: mmio [feb00000, fec0ffff]
[ 0.168542] node 0 link 0: mmio [80000000, fe02ffff]
[ 0.168542] node 0 link 0: mmio [e0000000, e05fffff]
[ 0.168542] bus: [00, 05] on node 0 link 0
[ 0.168542] bus: 00 index 0 [io 0x0000-0xffff]
[ 0.168542] bus: 00 index 1 [mem 0x000a0000-0x000bffff]
[ 0.168542] bus: 00 index 2 [mem 0xfe030000-0xffffffff]
[ 0.168542] bus: 00 index 3 [mem 0x80000000-0xfe02ffff]
[ 0.168542] ACPI: bus type pci registered
[ 0.168542] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.168542] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.168542] PCI: Using MMCONFIG for extended config space
[ 0.168542] PCI: Using configuration type 1 for base access
[ 0.169126] bio: create slab <bio-0> at 0
[ 0.169126] ACPI: Added _OSI(Module Device)
[ 0.169126] ACPI: Added _OSI(Processor Device)
[ 0.169126] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.169126] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.172206] ACPI: EC: Look up EC in DSDT
[ 0.178317] ACPI: Interpreter enabled
[ 0.178324] ACPI: (supports S0 S1 S4 S5)
[ 0.178352] ACPI: Using IOAPIC for interrupt routing
[ 0.185356] ACPI: No dock devices found.
[ 0.185363] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.186074] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-05])
[ 0.187419] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.187422] pci_root PNP0A08:00: host bridge window [io 0x6000-0xffff] (ignored)
[ 0.187426] pci_root PNP0A08:00: host bridge window [io 0x03b0-0x03df] (ignored)
[ 0.187429] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.187433] pci_root PNP0A08:00: host bridge window [mem 0x80000000-0xfe02ffff] (ignored)
[ 0.187437] pci_root PNP0A08:00: host bridge window [mem 0xfeb00000-0xfebfffff] (ignored)
[ 0.187440] PCI: root bus 00: hardware-probed resources
[ 0.187484] PCI host bridge to bus 0000:00
[ 0.187488] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.187491] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.187495] pci_bus 0000:00: root bus resource [mem 0xfe030000-0xffffffff]
[ 0.187498] pci_bus 0000:00: root bus resource [mem 0x80000000-0xfe02ffff]
[ 0.187516] pci 0000:00:00.0: [10de:005e] type 00 class 0x058000
[ 0.187586] pci 0000:00:01.0: [10de:0050] type 00 class 0x060100
[ 0.187612] HPET not enabled in BIOS. You might try hpet=force boot option
[ 0.187626] pci 0000:00:01.1: [10de:0052] type 00 class 0x0c0500
[ 0.187636] pci 0000:00:01.1: reg 10: [io 0xfc00-0xfc1f]
[ 0.187651] pci 0000:00:01.1: reg 20: [io 0xf800-0xf83f]
[ 0.187658] pci 0000:00:01.1: reg 24: [io 0xf400-0xf43f]
[ 0.187672] pci 0000:00:01.1: PME# supported from D3hot D3cold
[ 0.187690] pci 0000:00:02.0: [10de:005a] type 00 class 0x0c0310
[ 0.187700] pci 0000:00:02.0: reg 10: [mem 0xfe02f000-0xfe02ffff]
[ 0.187728] pci 0000:00:02.0: supports D1 D2
[ 0.187731] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.187746] pci 0000:00:02.1: [10de:005b] type 00 class 0x0c0320
[ 0.187756] pci 0000:00:02.1: reg 10: [mem 0xfeb00000-0xfeb000ff]
[ 0.187789] pci 0000:00:02.1: supports D1 D2
[ 0.187791] pci 0000:00:02.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.187813] pci 0000:00:06.0: [10de:0053] type 00 class 0x01018a
[ 0.187834] pci 0000:00:06.0: reg 20: [io 0xe800-0xe80f]
[ 0.187863] pci 0000:00:07.0: [10de:0054] type 00 class 0x010185
[ 0.187872] pci 0000:00:07.0: reg 10: [io 0x09f0-0x09f7]
[ 0.187878] pci 0000:00:07.0: reg 14: [io 0x0bf0-0x0bf3]
[ 0.187884] pci 0000:00:07.0: reg 18: [io 0x0970-0x0977]
[ 0.187890] pci 0000:00:07.0: reg 1c: [io 0x0b70-0x0b73]
[ 0.187896] pci 0000:00:07.0: reg 20: [io 0xd400-0xd40f]
[ 0.187902] pci 0000:00:07.0: reg 24: [mem 0xfe02c000-0xfe02cfff]
[ 0.187924] pci 0000:00:08.0: [10de:0055] type 00 class 0x010185
[ 0.187933] pci 0000:00:08.0: reg 10: [io 0x09e0-0x09e7]
[ 0.187940] pci 0000:00:08.0: reg 14: [io 0x0be0-0x0be3]
[ 0.187946] pci 0000:00:08.0: reg 18: [io 0x0960-0x0967]
[ 0.187952] pci 0000:00:08.0: reg 1c: [io 0x0b60-0x0b63]
[ 0.187958] pci 0000:00:08.0: reg 20: [io 0xc000-0xc00f]
[ 0.187965] pci 0000:00:08.0: reg 24: [mem 0xfe02b000-0xfe02bfff]
[ 0.187986] pci 0000:00:09.0: [10de:005c] type 01 class 0x060401
[ 0.188018] pci 0000:00:0a.0: [10de:0057] type 00 class 0x068000
[ 0.188028] pci 0000:00:0a.0: reg 10: [mem 0xfe02a000-0xfe02afff]
[ 0.188034] pci 0000:00:0a.0: reg 14: [io 0xbc00-0xbc07]
[ 0.188060] pci 0000:00:0a.0: supports D1 D2
[ 0.188063] pci 0000:00:0a.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.188079] pci 0000:00:0b.0: [10de:005d] type 01 class 0x060400
[ 0.188109] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.188127] pci 0000:00:0c.0: [10de:005d] type 01 class 0x060400
[ 0.188155] pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.188173] pci 0000:00:0d.0: [10de:005d] type 01 class 0x060400
[ 0.188201] pci 0000:00:0d.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.188218] pci 0000:00:0e.0: [10de:005d] type 01 class 0x060400
[ 0.188246] pci 0000:00:0e.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.188268] pci 0000:00:18.0: [1022:1100] type 00 class 0x060000
[ 0.188293] pci 0000:00:18.1: [1022:1101] type 00 class 0x060000
[ 0.188315] pci 0000:00:18.2: [1022:1102] type 00 class 0x060000
[ 0.188336] pci 0000:00:18.3: [1022:1103] type 00 class 0x060000
[ 0.188379] pci 0000:01:06.0: [2718:5125] type 00 class 0x110000
[ 0.188390] pci 0000:01:06.0: reg 10: [mem 0xfdee0000-0xfdeeffff]
[ 0.188439] pci 0000:01:09.0: [1106:3044] type 00 class 0x0c0010
[ 0.188453] pci 0000:01:09.0: reg 10: [mem 0xfdeff000-0xfdeff7ff]
[ 0.188462] pci 0000:01:09.0: reg 14: [io 0xac00-0xac7f]
[ 0.188504] pci 0000:01:09.0: supports D2
[ 0.188506] pci 0000:01:09.0: PME# supported from D2 D3hot D3cold
[ 0.188533] pci 0000:00:09.0: PCI bridge to [bus 01-01] (subtractive decode)
[ 0.188538] pci 0000:00:09.0: bridge window [io 0xa000-0xafff]
[ 0.188542] pci 0000:00:09.0: bridge window [mem 0xfde00000-0xfdefffff]
[ 0.188546] pci 0000:00:09.0: bridge window [mem 0xfdf00000-0xfdffffff pref]
[ 0.188550] pci 0000:00:09.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.188553] pci 0000:00:09.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.188557] pci 0000:00:09.0: bridge window [mem 0xfe030000-0xffffffff] (subtractive decode)
[ 0.188561] pci 0000:00:09.0: bridge window [mem 0x80000000-0xfe02ffff] (subtractive decode)
[ 0.188586] pci 0000:00:0b.0: PCI bridge to [bus 02-02]
[ 0.188590] pci 0000:00:0b.0: bridge window [io 0x9000-0x9fff]
[ 0.188594] pci 0000:00:0b.0: bridge window [mem 0xfdd00000-0xfddfffff]
[ 0.188600] pci 0000:00:0b.0: bridge window [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.188625] pci 0000:00:0c.0: PCI bridge to [bus 03-03]
[ 0.188630] pci 0000:00:0c.0: bridge window [io 0x8000-0x8fff]
[ 0.188634] pci 0000:00:0c.0: bridge window [mem 0xfdb00000-0xfdbfffff]
[ 0.188639] pci 0000:00:0c.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.188663] pci 0000:00:0d.0: PCI bridge to [bus 04-04]
[ 0.188668] pci 0000:00:0d.0: bridge window [io 0x7000-0x7fff]
[ 0.188672] pci 0000:00:0d.0: bridge window [mem 0xfd900000-0xfd9fffff]
[ 0.188677] pci 0000:00:0d.0: bridge window [mem 0xfd800000-0xfd8fffff 64bit pref]
[ 0.188710] pci 0000:05:00.0: [102b:2539] type 00 class 0x030000
[ 0.188724] pci 0000:05:00.0: reg 10: [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.188735] pci 0000:05:00.0: reg 18: [mem 0xfd7fe000-0xfd7fffff 64bit]
[ 0.188752] pci 0000:05:00.0: reg 30: [mem 0x00000000-0x0001ffff pref]
[ 0.196025] pci 0000:00:0e.0: PCI bridge to [bus 05-05]
[ 0.196030] pci 0000:00:0e.0: bridge window [io 0x6000-0x6fff]
[ 0.196034] pci 0000:00:0e.0: bridge window [mem 0xfd700000-0xfd7fffff]
[ 0.196039] pci 0000:00:0e.0: bridge window [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.196051] pci_bus 0000:00: on NUMA node 0
[ 0.196055] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.196280] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
[ 0.196510] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.237174] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237238] ACPI: PCI Interrupt Link [LNK2] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237302] ACPI: PCI Interrupt Link [LNK3] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.237364] ACPI: PCI Interrupt Link [LNK4] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.237425] ACPI: PCI Interrupt Link [LNK5] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237488] ACPI: PCI Interrupt Link [LUBA] (IRQs 3 *4 5 7 9 10 11 12 14 15)
[ 0.237549] ACPI: PCI Interrupt Link [LUBB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237615] ACPI: PCI Interrupt Link [LMAC] (IRQs 3 4 5 *7 9 10 11 12 14 15)
[ 0.237678] ACPI: PCI Interrupt Link [LACI] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237740] ACPI: PCI Interrupt Link [LMCI] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237803] ACPI: PCI Interrupt Link [LSMB] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.237865] ACPI: PCI Interrupt Link [LUB2] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.237926] ACPI: PCI Interrupt Link [LIDE] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.237997] ACPI: PCI Interrupt Link [LSID] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.238066] ACPI: PCI Interrupt Link [LFID] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.238134] ACPI: PCI Interrupt Link [LPCA] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.238180] ACPI: PCI Interrupt Link [APC1] (IRQs *16), disabled.
[ 0.238219] ACPI: PCI Interrupt Link [APC2] (IRQs *17), disabled.
[ 0.238258] ACPI: PCI Interrupt Link [APC3] (IRQs *18)
[ 0.238296] ACPI: PCI Interrupt Link [APC4] (IRQs *19)
[ 0.238334] ACPI: PCI Interrupt Link [APC5] (IRQs *16), disabled.
[ 0.238420] ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0
[ 0.238506] ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22 23) *0, disabled.
[ 0.238594] ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0
[ 0.238679] ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22 23) *0, disabled.
[ 0.238765] ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22 23) *0, disabled.
[ 0.238850] ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0
[ 0.238936] ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0
[ 0.239020] ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled.
[ 0.239113] ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0
[ 0.239205] ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0
[ 0.239297] ACPI: PCI Interrupt Link [APCP] (IRQs 20 21 22 23) *0, disabled.
[ 0.239372] vgaarb: device added: PCI:0000:05:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.239372] vgaarb: loaded
[ 0.239372] vgaarb: bridge control possible 0000:05:00.0
[ 0.239372] PCI: Using ACPI for IRQ routing
[ 0.245045] PCI: pci_cache_line_size set to 64 bytes
[ 0.245108] reserve RAM buffer: 000000000009f400 - 000000000009ffff
[ 0.245112] reserve RAM buffer: 000000007fff0000 - 000000007fffffff
[ 0.245390] pnp: PnP ACPI init
[ 0.245402] ACPI: bus type pnp registered
[ 0.245426] pnp 00:00: [io 0x4000-0x407f]
[ 0.245429] pnp 00:00: [io 0x4080-0x40ff]
[ 0.245432] pnp 00:00: [io 0x4400-0x447f]
[ 0.245435] pnp 00:00: [io 0x4480-0x44ff]
[ 0.245438] pnp 00:00: [io 0x4800-0x487f]
[ 0.245441] pnp 00:00: [io 0x4880-0x48ff]
[ 0.245494] system 00:00: [io 0x4000-0x407f] has been reserved
[ 0.245498] system 00:00: [io 0x4080-0x40ff] has been reserved
[ 0.245502] system 00:00: [io 0x4400-0x447f] has been reserved
[ 0.245506] system 00:00: [io 0x4480-0x44ff] has been reserved
[ 0.245509] system 00:00: [io 0x4800-0x487f] has been reserved
[ 0.245513] system 00:00: [io 0x4880-0x48ff] has been reserved
[ 0.245517] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.246231] pnp 00:01: [bus 00-05]
[ 0.246234] pnp 00:01: [io 0x0cf8-0x0cff]
[ 0.246238] pnp 00:01: [io 0x0000-0x0cf7 window]
[ 0.246241] pnp 00:01: [io 0x6000-0xffff window]
[ 0.246244] pnp 00:01: [io 0x03b0-0x03df window]
[ 0.246248] pnp 00:01: [mem 0x000a0000-0x000bffff window]
[ 0.246251] pnp 00:01: [mem 0x80000000-0xfe02ffff window]
[ 0.246255] pnp 00:01: [mem 0x00000000 window]
[ 0.246259] pnp 00:01: [mem 0xfeb00000-0xfebfffff window]
[ 0.246324] pnp 00:01: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.247028] pnp 00:02: [io 0x0010-0x001f]
[ 0.247031] pnp 00:02: [io 0x0022-0x003f]
[ 0.247035] pnp 00:02: [io 0x0044-0x005f]
[ 0.247038] pnp 00:02: [io 0x0062-0x0063]
[ 0.247041] pnp 00:02: [io 0x0065-0x006f]
[ 0.247044] pnp 00:02: [io 0x0074-0x007f]
[ 0.247047] pnp 00:02: [io 0x0091-0x0093]
[ 0.247050] pnp 00:02: [io 0x00a2-0x00bf]
[ 0.247053] pnp 00:02: [io 0x00e0-0x00ef]
[ 0.247056] pnp 00:02: [io 0x0b78-0x0b7b]
[ 0.247059] pnp 00:02: [io 0x0f78-0x0f7b]
[ 0.247062] pnp 00:02: [io 0x0a78-0x0a7b]
[ 0.247065] pnp 00:02: [io 0x0e78-0x0e7b]
[ 0.247068] pnp 00:02: [io 0x0bbc-0x0bbf]
[ 0.247071] pnp 00:02: [io 0x0fbc-0x0fbf]
[ 0.247074] pnp 00:02: [io 0x04d0-0x04d1]
[ 0.247078] pnp 00:02: [io 0x0290-0x029f]
[ 0.247080] pnp 00:02: [io 0x04e0-0x04e7]
[ 0.247174] system 00:02: [io 0x0b78-0x0b7b] has been reserved
[ 0.247177] system 00:02: [io 0x0f78-0x0f7b] has been reserved
[ 0.247181] system 00:02: [io 0x0a78-0x0a7b] has been reserved
[ 0.247185] system 00:02: [io 0x0e78-0x0e7b] has been reserved
[ 0.247189] system 00:02: [io 0x0bbc-0x0bbf] has been reserved
[ 0.247192] system 00:02: [io 0x0fbc-0x0fbf] has been reserved
[ 0.247196] system 00:02: [io 0x04d0-0x04d1] has been reserved
[ 0.247199] system 00:02: [io 0x0290-0x029f] has been reserved
[ 0.247203] system 00:02: [io 0x04e0-0x04e7] has been reserved
[ 0.247207] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.247225] pnp 00:03: [dma 4]
[ 0.247228] pnp 00:03: [io 0x0000-0x000f]
[ 0.247232] pnp 00:03: [io 0x0080-0x0090]
[ 0.247235] pnp 00:03: [io 0x0094-0x009f]
[ 0.247238] pnp 00:03: [io 0x00c0-0x00df]
[ 0.247288] pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.247304] pnp 00:04: [io 0x0070-0x0073]
[ 0.247319] pnp 00:04: [irq 8]
[ 0.247370] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.247383] pnp 00:05: [io 0x0061]
[ 0.247433] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.247446] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.247453] pnp 00:06: [irq 13]
[ 0.247504] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.248156] pnp 00:07: [mem 0xe0000000-0xefffffff]
[ 0.248233] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.248237] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.248383] pnp 00:08: [mem 0x000d0000-0x000d3fff]
[ 0.248387] pnp 00:08: [mem 0x000f0000-0x000f7fff]
[ 0.248390] pnp 00:08: [mem 0x000f8000-0x000fbfff]
[ 0.248393] pnp 00:08: [mem 0x000fc000-0x000fffff]
[ 0.248397] pnp 00:08: [mem 0x7fff0000-0x7fffffff]
[ 0.248400] pnp 00:08: [mem 0xffff0000-0xffffffff]
[ 0.248403] pnp 00:08: [mem 0x00000000-0x0009ffff]
[ 0.248406] pnp 00:08: [mem 0x00100000-0x7ffeffff]
[ 0.248410] pnp 00:08: [mem 0xfec00000-0xfec00fff]
[ 0.248413] pnp 00:08: [mem 0xfee00000-0xfeefffff]
[ 0.248416] pnp 00:08: [mem 0xfefff000-0xfeffffff]
[ 0.248419] pnp 00:08: [mem 0xfff80000-0xfff80fff]
[ 0.248423] pnp 00:08: [mem 0xfff90000-0xfffbffff]
[ 0.248426] pnp 00:08: [mem 0xfffed000-0xfffeffff]
[ 0.248513] system 00:08: [mem 0x000d0000-0x000d3fff] has been reserved
[ 0.248517] system 00:08: [mem 0x000f0000-0x000f7fff] could not be reserved
[ 0.248521] system 00:08: [mem 0x000f8000-0x000fbfff] could not be reserved
[ 0.248525] system 00:08: [mem 0x000fc000-0x000fffff] could not be reserved
[ 0.248529] system 00:08: [mem 0x7fff0000-0x7fffffff] could not be reserved
[ 0.248532] system 00:08: [mem 0xffff0000-0xffffffff] has been reserved
[ 0.248539] system 00:08: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.248543] system 00:08: [mem 0x00100000-0x7ffeffff] could not be reserved
[ 0.248547] system 00:08: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.248551] system 00:08: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.248555] system 00:08: [mem 0xfefff000-0xfeffffff] has been reserved
[ 0.248558] system 00:08: [mem 0xfff80000-0xfff80fff] has been reserved
[ 0.248562] system 00:08: [mem 0xfff90000-0xfffbffff] has been reserved
[ 0.248566] system 00:08: [mem 0xfffed000-0xfffeffff] has been reserved
[ 0.248570] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.248583] pnp: PnP ACPI: found 9 devices
[ 0.248586] ACPI: ACPI bus type pnp unregistered
[ 0.248590] PnPBIOS: Disabled by ACPI PNP
[ 0.285541] Switching to clocksource acpi_pm
[ 0.285594] pci 0000:00:09.0: PCI bridge to [bus 01-01]
[ 0.285598] pci 0000:00:09.0: bridge window [io 0xa000-0xafff]
[ 0.285603] pci 0000:00:09.0: bridge window [mem 0xfde00000-0xfdefffff]
[ 0.285607] pci 0000:00:09.0: bridge window [mem 0xfdf00000-0xfdffffff pref]
[ 0.285612] pci 0000:00:0b.0: PCI bridge to [bus 02-02]
[ 0.285615] pci 0000:00:0b.0: bridge window [io 0x9000-0x9fff]
[ 0.285620] pci 0000:00:0b.0: bridge window [mem 0xfdd00000-0xfddfffff]
[ 0.285624] pci 0000:00:0b.0: bridge window [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.285629] pci 0000:00:0c.0: PCI bridge to [bus 03-03]
[ 0.285632] pci 0000:00:0c.0: bridge window [io 0x8000-0x8fff]
[ 0.285636] pci 0000:00:0c.0: bridge window [mem 0xfdb00000-0xfdbfffff]
[ 0.285640] pci 0000:00:0c.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.285645] pci 0000:00:0d.0: PCI bridge to [bus 04-04]
[ 0.285648] pci 0000:00:0d.0: bridge window [io 0x7000-0x7fff]
[ 0.285653] pci 0000:00:0d.0: bridge window [mem 0xfd900000-0xfd9fffff]
[ 0.285657] pci 0000:00:0d.0: bridge window [mem 0xfd800000-0xfd8fffff 64bit pref]
[ 0.285666] pci 0000:05:00.0: BAR 6: assigned [mem 0xfd700000-0xfd71ffff pref]
[ 0.285669] pci 0000:00:0e.0: PCI bridge to [bus 05-05]
[ 0.285673] pci 0000:00:0e.0: bridge window [io 0x6000-0x6fff]
[ 0.285677] pci 0000:00:0e.0: bridge window [mem 0xfd700000-0xfd7fffff]
[ 0.285681] pci 0000:00:0e.0: bridge window [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.285691] pci 0000:00:09.0: setting latency timer to 64
[ 0.285706] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.285709] pci_bus 0000:00: resource 5 [mem 0x000a0000-0x000bffff]
[ 0.285712] pci_bus 0000:00: resource 6 [mem 0xfe030000-0xffffffff]
[ 0.285716] pci_bus 0000:00: resource 7 [mem 0x80000000-0xfe02ffff]
[ 0.285719] pci_bus 0000:01: resource 0 [io 0xa000-0xafff]
[ 0.285723] pci_bus 0000:01: resource 1 [mem 0xfde00000-0xfdefffff]
[ 0.285726] pci_bus 0000:01: resource 2 [mem 0xfdf00000-0xfdffffff pref]
[ 0.285729] pci_bus 0000:01: resource 4 [io 0x0000-0xffff]
[ 0.285733] pci_bus 0000:01: resource 5 [mem 0x000a0000-0x000bffff]
[ 0.285736] pci_bus 0000:01: resource 6 [mem 0xfe030000-0xffffffff]
[ 0.285739] pci_bus 0000:01: resource 7 [mem 0x80000000-0xfe02ffff]
[ 0.285742] pci_bus 0000:02: resource 0 [io 0x9000-0x9fff]
[ 0.285746] pci_bus 0000:02: resource 1 [mem 0xfdd00000-0xfddfffff]
[ 0.285749] pci_bus 0000:02: resource 2 [mem 0xfdc00000-0xfdcfffff 64bit pref]
[ 0.285753] pci_bus 0000:03: resource 0 [io 0x8000-0x8fff]
[ 0.285756] pci_bus 0000:03: resource 1 [mem 0xfdb00000-0xfdbfffff]
[ 0.285759] pci_bus 0000:03: resource 2 [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.285763] pci_bus 0000:04: resource 0 [io 0x7000-0x7fff]
[ 0.285766] pci_bus 0000:04: resource 1 [mem 0xfd900000-0xfd9fffff]
[ 0.285769] pci_bus 0000:04: resource 2 [mem 0xfd800000-0xfd8fffff 64bit pref]
[ 0.285773] pci_bus 0000:05: resource 0 [io 0x6000-0x6fff]
[ 0.285776] pci_bus 0000:05: resource 1 [mem 0xfd700000-0xfd7fffff]
[ 0.285780] pci_bus 0000:05: resource 2 [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.285887] NET: Registered protocol family 2
[ 0.285961] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.286237] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.286926] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.287285] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.287288] TCP: reno registered
[ 0.287292] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.287305] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.287432] NET: Registered protocol family 1
[ 0.287645] ACPI: PCI Interrupt Link [APCF] enabled at IRQ 23
[ 0.356171] ACPI: PCI Interrupt Link [APCL] enabled at IRQ 22
[ 0.356206] pci 0000:00:0b.0: Linking AER extended capability
[ 0.356212] pci 0000:00:0c.0: Linking AER extended capability
[ 0.356217] pci 0000:00:0d.0: Linking AER extended capability
[ 0.356222] pci 0000:00:0e.0: Linking AER extended capability
[ 0.356241] pci 0000:05:00.0: Boot video device
[ 0.356244] PCI: CLS 32 bytes, default 64
[ 0.356303] Unpacking initramfs...
[ 0.723533] Freeing initrd memory: 13708k freed
[ 0.732406] audit: initializing netlink socket (disabled)
[ 0.732424] type=2000 audit(1514539782.728:1): initialized
[ 0.747166] highmem bounce pool size: 64 pages
[ 0.747172] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.747490] VFS: Disk quotas dquot_6.5.2
[ 0.747526] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.747611] msgmni has been set to 1721
[ 0.747862] alg: No test for stdrng (krng)
[ 0.747904] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.747909] io scheduler noop registered
[ 0.747911] io scheduler deadline registered
[ 0.747938] io scheduler cfq registered (default)
[ 0.748226] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.748259] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.748262] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.748933] GHES: HEST is not enabled!
[ 0.748947] isapnp: Scanning for PnP cards...
[ 1.101534] isapnp: No Plug & Play device found
[ 1.101613] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.102121] Linux agpgart interface v0.103
[ 1.102448] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.104920] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.104935] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.105096] mousedev: PS/2 mouse device common for all mice
[ 1.105135] rtc_cmos 00:04: RTC can wake from S4
[ 1.105276] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.105300] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 1.105443] TCP: cubic registered
[ 1.105523] NET: Registered protocol family 10
[ 1.105771] Mobile IPv6
[ 1.105775] NET: Registered protocol family 17
[ 1.105780] Registering the dns_resolver key type
[ 1.105833] Using IPI No-Shortcut mode
[ 1.105988] PM: Hibernation image not present or could not be loaded.
[ 1.106005] registered taskstats version 1
[ 1.106383] rtc_cmos 00:04: setting system clock to 2017-12-29 09:29:43 UTC (1514539783)
[ 1.106494] Freeing unused kernel memory: 416k freed
[ 1.106790] Write protecting the kernel text: 3496k
[ 1.106821] Write protecting the kernel read-only data: 984k
[ 1.121289] udevd[49]: starting version 175
[ 1.140866] usbcore: registered new interface driver usbfs
[ 1.140896] usbcore: registered new interface driver hub
[ 1.148875] usbcore: registered new device driver usb
[ 1.155179] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.155255] ehci_hcd 0000:00:02.1: setting latency timer to 64
[ 1.155261] ehci_hcd 0000:00:02.1: EHCI Host Controller
[ 1.155300] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1
[ 1.155333] ehci_hcd 0000:00:02.1: debug port 1
[ 1.155340] ehci_hcd 0000:00:02.1: cache line size of 32 is not supported
[ 1.155363] ehci_hcd 0000:00:02.1: irq 22, io mem 0xfeb00000
[ 1.157331] SCSI subsystem initialized
[ 1.161965] libata version 3.00 loaded.
[ 1.164085] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00
[ 1.164144] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.164149] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.164153] usb usb1: Product: EHCI Host Controller
[ 1.164156] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.164159] usb usb1: SerialNumber: 0000:00:02.1
[ 1.165750] hub 1-0:1.0: USB hub found
[ 1.165759] hub 1-0:1.0: 10 ports detected
[ 1.166345] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.166409] ohci_hcd 0000:00:02.0: setting latency timer to 64
[ 1.166413] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 1.166426] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
[ 1.166461] ohci_hcd 0000:00:02.0: irq 23, io mem 0xfe02f000
[ 1.190574] microcode: AMD CPU family 0xf not supported
[ 1.196162] ACPI: Fan [FAN] (on)
[ 1.222080] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.222086] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.222091] usb usb2: Product: OHCI Host Controller
[ 1.222094] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 1.222096] usb usb2: SerialNumber: 0000:00:02.0
[ 1.222302] hub 2-0:1.0: USB hub found
[ 1.222312] hub 2-0:1.0: 10 ports detected
[ 1.222457] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64.
[ 1.222700] ACPI: PCI Interrupt Link [APCH] enabled at IRQ 21
[ 1.222725] forcedeth 0000:00:0a.0: setting latency timer to 64
[ 1.225301] ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19
[ 1.288074] firewire_ohci 0000:01:09.0: added OHCI v1.0 device as card 0, 4 IR + 8 IT contexts, quirks 0x11
[ 1.536030] usb 1-2: new high-speed USB device number 3 using ehci_hcd
[ 1.669272] usb 1-2: New USB device found, idVendor=0bda, idProduct=8179
[ 1.669277] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.669280] usb 1-2: Product: 802.11n NIC
[ 1.669283] usb 1-2: Manufacturer: Realtek
[ 1.669286] usb 1-2: SerialNumber: 7CDD90D4AD5B
[ 1.744698] forcedeth 0000:00:0a.0: ifname eth0, PHY OUI 0x3f1 @ 1, addr 00:04:61:ab:77:94
[ 1.744705] forcedeth 0000:00:0a.0: highdma csum gbit lnktim desc-v3
[ 1.744741] sata_nv 0000:00:07.0: version 3.5
[ 1.744995] ACPI: PCI Interrupt Link [APSI] enabled at IRQ 20
[ 1.745088] sata_nv 0000:00:07.0: setting latency timer to 64
[ 1.745774] scsi0 : sata_nv
[ 1.746000] scsi1 : sata_nv
[ 1.746173] ata1: SATA max UDMA/133 cmd 0x9f0 ctl 0xbf0 bmdma 0xd400 irq 20
[ 1.746177] ata2: SATA max UDMA/133 cmd 0x970 ctl 0xb70 bmdma 0xd408 irq 20
[ 1.746452] ACPI: PCI Interrupt Link [APSJ] enabled at IRQ 23
[ 1.746512] sata_nv 0000:00:08.0: setting latency timer to 64
[ 1.746801] scsi2 : sata_nv
[ 1.746881] scsi3 : sata_nv
[ 1.747032] ata3: SATA max UDMA/133 cmd 0x9e0 ctl 0xbe0 bmdma 0xc000 irq 23
[ 1.747036] ata4: SATA max UDMA/133 cmd 0x960 ctl 0xb60 bmdma 0xc008 irq 23
[ 1.747078] pata_amd 0000:00:06.0: version 0.4.1
[ 1.747121] pata_amd 0000:00:06.0: setting latency timer to 64
[ 1.747504] scsi4 : pata_amd
[ 1.747735] scsi5 : pata_amd
[ 1.748318] ata5: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xe800 irq 14
[ 1.748321] ata6: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xe808 irq 15
[ 1.748644] ata5: port disabled--ignoring
[ 1.788151] firewire_core 0000:01:09.0: created device fw0: GUID 00046100000cb97a, S400
[ 2.056037] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.140030] usb 2-1: new low-speed USB device number 2 using ohci_hcd
[ 2.212034] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.220357] ata3.00: ATA-9: SanDisk SDSSDP064G, 2.0.0, max UDMA/133
[ 2.220360] ata3.00: 125045424 sectors, multi 1: LBA48 NCQ (depth 0/32)
[ 2.236221] ata3.00: configured for UDMA/133
[ 2.368025] ata2: SATA link down (SStatus 0 SControl 300)
[ 2.368232] scsi 2:0:0:0: Direct-Access ATA SanDisk SDSSDP06 2.0. PQ: 0 ANSI: 5
[ 2.474084] usb 2-1: New USB device found, idVendor=1532, idProduct=0001
[ 2.474088] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.474092] usb 2-1: Product: Razer 1600dpi Mouse
[ 2.474094] usb 2-1: Manufacturer: Razer
[ 2.680033] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.680131] ata6: port disabled--ignoring
[ 2.686587] sd 2:0:0:0: [sda] 125045424 512-byte logical blocks: (64.0 GB/59.6 GiB)
[ 2.686678] sd 2:0:0:0: [sda] Write Protect is off
[ 2.686685] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.686748] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.687680] sda: sda1 sda2 < sda5 >
[ 2.688191] sd 2:0:0:0: [sda] Attached SCSI disk
[ 2.690368] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 2.692165] input: Razer Razer 1600dpi Mouse as /devices/pci0000:00/0000:00:02.0/usb2/2-1/2-1:1.0/input/input0
[ 2.693199] generic-usb 0003:1532:0001.0001: input,hidraw0: USB HID v1.10 Mouse [Razer Razer 1600dpi Mouse] on usb-0000:00:02.0-1/input0
[ 2.693322] usbcore: registered new interface driver usbhid
[ 2.693325] usbhid: USB HID core driver
[ 2.784039] usb 2-3: new low-speed USB device number 3 using ohci_hcd
[ 3.016083] usb 2-3: New USB device found, idVendor=062a, idProduct=0102
[ 3.016089] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.016093] usb 2-3: Product: Wireless Keyboard & Mouse
[ 3.016096] usb 2-3: Manufacturer: MOSART Semi.
[ 3.026616] input: MOSART Semi. Wireless Keyboard & Mouse as /devices/pci0000:00/0000:00:02.0/usb2/2-3/2-3:1.0/input/input1
[ 3.026721] generic-usb 0003:062A:0102.0002: input,hidraw1: USB HID v1.10 Keyboard [MOSART Semi. Wireless Keyboard & Mouse] on usb-0000:00:02.0-3/input0
[ 3.037366] input: MOSART Semi. Wireless Keyboard & Mouse as /devices/pci0000:00/0000:00:02.0/usb2/2-3/2-3:1.1/input/input2
[ 3.037503] generic-usb 0003:062A:0102.0003: input,hiddev0,hidraw2: USB HID v1.10 Mouse [MOSART Semi. Wireless Keyboard & Mouse] on usb-0000:00:02.0-3/input1
[ 3.340028] usb 2-4: new full-speed USB device number 4 using ohci_hcd
[ 3.566078] usb 2-4: New USB device found, idVendor=0403, idProduct=6001
[ 3.566082] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.566086] usb 2-4: Product: USB-SMV2
[ 3.566088] usb 2-4: Manufacturer: FTDI
[ 3.566091] usb 2-4: SerialNumber: AH026T6E
[ 7.776315] microcode: AMD CPU family 0xf not supported
[ 8.176447] PM: Starting manual resume from disk
[ 8.176453] PM: Hibernation image partition 8:5 present
[ 8.176456] PM: Looking for hibernation image.
[ 8.176796] PM: Image not found (code -22)
[ 8.176798] PM: Hibernation image not present or could not be loaded.
[ 8.196340] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.484069] udevd[375]: starting version 175
[ 8.608535] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 8.608544] ACPI: Power Button [PWRB]
[ 8.608755] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 8.608760] ACPI: Power Button [PWRF]
[ 8.610690] i2c i2c-0: nForce2 SMBus adapter at 0xf800
[ 8.610721] i2c i2c-1: nForce2 SMBus adapter at 0xf400
[ 8.695747] microcode: AMD CPU family 0xf not supported
[ 8.715637] usbcore: registered new interface driver usbserial
[ 8.715657] usbcore: registered new interface driver usbserial_generic
[ 8.715673] USB Serial support registered for generic
[ 8.715697] usbserial: USB Serial Driver core
[ 8.717902] usbcore: registered new interface driver ftdi_sio
[ 8.717924] USB Serial support registered for FTDI USB Serial Device
[ 8.717987] ftdi_sio 2-4:1.0: FTDI USB Serial Device converter detected
[ 8.718029] usb 2-4: Detected FT232RL
[ 8.718032] usb 2-4: Number of endpoints 2
[ 8.718035] usb 2-4: Endpoint 1 MaxPacketSize 64
[ 8.718038] usb 2-4: Endpoint 2 MaxPacketSize 64
[ 8.718040] usb 2-4: Setting MaxPacketSize 64
[ 8.722160] usb 2-4: FTDI USB Serial Device converter now attached to ttyUSB0
[ 8.722178] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[ 8.753091] RTL871X: module init start
[ 8.753887] RTL871X: rtl8188eu v4.3.0.8_13968.20150417
[ 8.753891] RTL871X: build time: Apr 1 2017 21:56:46
[ 8.753930] RTL871X:
[ 8.753931] usb_endpoint_descriptor(0):
[ 8.753934] RTL871X: bLength=7
[ 8.753936] RTL871X: bDescriptorType=5
[ 8.753938] RTL871X: bEndpointAddress=81
[ 8.753940] RTL871X: wMaxPacketSize=512
[ 8.753942] RTL871X: bInterval=0
[ 8.753944] RTL871X: RT_usb_endpoint_is_bulk_in = 1
[ 8.753947] RTL871X:
[ 8.753948] usb_endpoint_descriptor(1):
[ 8.753950] RTL871X: bLength=7
[ 8.753952] RTL871X: bDescriptorType=5
[ 8.753954] RTL871X: bEndpointAddress=2
[ 8.753956] RTL871X: wMaxPacketSize=512
[ 8.753959] RTL871X: bInterval=0
[ 8.753961] RTL871X: RT_usb_endpoint_is_bulk_out = 2
[ 8.753963] RTL871X:
[ 8.753964] usb_endpoint_descriptor(2):
[ 8.753966] RTL871X: bLength=7
[ 8.753968] RTL871X: bDescriptorType=5
[ 8.753970] RTL871X: bEndpointAddress=3
[ 8.753972] RTL871X: wMaxPacketSize=512
[ 8.753975] RTL871X: bInterval=0
[ 8.753976] RTL871X: RT_usb_endpoint_is_bulk_out = 3
[ 8.753979] RTL871X: nr_endpoint=3, in_num=1, out_num=2
[ 8.753980]
[ 8.753983] RTL871X: USB_SPEED_HIGH
[ 8.754017] RTL871X: CHIP TYPE: RTL8188E
[ 8.754028] RTL871X: register rtw_netdev_ops to netdev_ops
[ 8.754496] RTL871X: Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_K_CUT_1T1R_RomVer(0)
[ 8.754499] RTL871X: RF_Type is 3!!
[ 8.754503] RTL871X: _ConfigNormalChipOutEP_8188E OutEpQueueSel(0x05), OutEpNumber(2)
[ 8.754787] RTL871X: EEPROM type is E-FUSE
[ 8.754790] RTL871X: ====> _ReadAdapterInfo8188EU
[ 8.755171] RTL871X: Boot from EFUSE, Autoload OK !
[ 8.759926] RTL871X: SetHwReg8188EU: bMacPwrCtrlOn=1
[ 8.760142] bFWReady == _FALSE call reset 8051...
[ 8.761028] RTL871X: =====> _8051Reset88E(): 8051 reset success .
[ 8.775894] RTL871X: efuse_read_phymap_from_txpktbuf bcnhead:0
[ 8.776897] RTL871X: efuse_read_phymap_from_txpktbuf len:111, lenbak:111, aaa:111, aaabak:111
[ 8.785148] RTL871X: efuse_read_phymap_from_txpktbuf read count:109
[ 8.785543] RTL871X: EEPROM ID=0x8129
[ 8.785546] RTL871X: VID = 0x0BDA, PID = 0x8179
[ 8.785549] RTL871X: Customer ID: 0x00, SubCustomer ID: 0xCD
[ 8.785553] RTL871X: Hal_ReadPowerSavingMode88E...bHWPwrPindetect(0)-bHWPowerdown(0) ,bSupportRemoteWakeup(1)
[ 8.785556] RTL871X: ### PS params=> power_mgnt(1),usbss_enable(0) ###
[ 8.785560] RTL871X: ======= Path 0, Channel 1 =======
[ 8.785563] RTL871X: Index24G_CCK_Base[0][1] = 0x30
[ 8.785566] RTL871X: Index24G_BW40_Base[0][1] = 0x30
[ 8.785568] RTL871X: ======= Path 0, Channel 2 =======
[ 8.785571] RTL871X: Index24G_CCK_Base[0][2] = 0x30
[ 8.785574] RTL871X: Index24G_BW40_Base[0][2] = 0x30
[ 8.785577] RTL871X: ======= Path 0, Channel 3 =======
[ 8.785580] RTL871X: Index24G_CCK_Base[0][3] = 0x30
[ 8.785583] RTL871X: Index24G_BW40_Base[0][3] = 0x30
[ 8.785586] RTL871X: ======= Path 0, Channel 4 =======
[ 8.785590] RTL871X: Index24G_CCK_Base[0][4] = 0x30
[ 8.785593] RTL871X: Index24G_BW40_Base[0][4] = 0x30
[ 8.785597] RTL871X: ======= Path 0, Channel 5 =======
[ 8.785600] RTL871X: Index24G_CCK_Base[0][5] = 0x30
[ 8.785604] RTL871X: Index24G_BW40_Base[0][5] = 0x30
[ 8.785607] RTL871X: ======= Path 0, Channel 6 =======
[ 8.785610] RTL871X: Index24G_CCK_Base[0][6] = 0x30
[ 8.785614] RTL871X: Index24G_BW40_Base[0][6] = 0x30
[ 8.785617] RTL871X: ======= Path 0, Channel 7 =======
[ 8.785620] RTL871X: Index24G_CCK_Base[0][7] = 0x30
[ 8.785623] RTL871X: Index24G_BW40_Base[0][7] = 0x30
[ 8.785626] RTL871X: ======= Path 0, Channel 8 =======
[ 8.785629] RTL871X: Index24G_CCK_Base[0][8] = 0x30
[ 8.785631] RTL871X: Index24G_BW40_Base[0][8] = 0x30
[ 8.785634] RTL871X: ======= Path 0, Channel 9 =======
[ 8.785636] RTL871X: Index24G_CCK_Base[0][9] = 0x30
[ 8.785639] RTL871X: Index24G_BW40_Base[0][9] = 0x30
[ 8.785641] RTL871X: ======= Path 0, Channel 10 =======
[ 8.785644] RTL871X: Index24G_CCK_Base[0][10] = 0x30
[ 8.785646] RTL871X: Index24G_BW40_Base[0][10] = 0x30
[ 8.785649] RTL871X: ======= Path 0, Channel 11 =======
[ 8.785651] RTL871X: Index24G_CCK_Base[0][11] = 0x30
[ 8.785654] RTL871X: Index24G_BW40_Base[0][11] = 0x30
[ 8.785656] RTL871X: ======= Path 0, Channel 12 =======
[ 8.785659] RTL871X: Index24G_CCK_Base[0][12] = 0x30
[ 8.785661] RTL871X: Index24G_BW40_Base[0][12] = 0x30
[ 8.785664] RTL871X: ======= Path 0, Channel 13 =======
[ 8.785667] RTL871X: Index24G_CCK_Base[0][13] = 0x30
[ 8.785669] RTL871X: Index24G_BW40_Base[0][13] = 0x30
[ 8.785672] RTL871X: ======= Path 0, Channel 14 =======
[ 8.785675] RTL871X: Index24G_CCK_Base[0][14] = 0x30
[ 8.785677] RTL871X: Index24G_BW40_Base[0][14] = 0x30
[ 8.785680] RTL871X: ======= TxCount 0 =======
[ 8.785682] RTL871X: CCK_24G_Diff[0][0]= 0
[ 8.785685] RTL871X: OFDM_24G_Diff[0][0]= 0
[ 8.785687] RTL871X: BW20_24G_Diff[0][0]= -3
[ 8.785690] RTL871X: BW40_24G_Diff[0][0]= 0
[ 8.785692] RTL871X: EEPROMRegulatory = 0x0
[ 8.785695] RTL871X: mlmepriv.ChannelPlan = 0x20
[ 8.785697] RTL871X: CrystalCap: 0x2d
[ 8.785700] RTL871X: EEPROM Customer ID: 0x 0
[ 8.785702] RTL871X: EEPROM : AntDivCfg = 1, TRxAntDivType = 1
[ 8.785704] RTL871X: Board Type: 0x 0
[ 8.785706] RTL871X: ThermalMeter = 0x1a
[ 8.785709] RTL871X: <==== _ReadAdapterInfo8188EU in 32 ms
[ 8.785821] RTL871X: init_channel_set ChannelPlan ID 20 Chan num:13
[ 8.786293] RTL871X: pwrctrlpriv.bSupportRemoteWakeup~~~~~~
[ 8.786296] RTL871X: pwrctrlpriv.bSupportRemoteWakeup~~~[1]~~~
[ 8.786302] RTL871X: rtw_macaddr_cfg MAC Address = 7c:dd:90:d4:ad:5b
[ 8.786305] RTL871X: bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0
[ 8.786320] RTL871X: rtw_ndev_init(wlan0)
[ 8.786649] RTL871X: _rtw_drv_register_netdev, MAC Address (if1) = 7c:dd:90:d4:ad:5b
[ 8.786720] usbcore: registered new interface driver rtl8188eu
[ 8.786723] RTL871X: module init ret=0
[ 9.180570] Adding 2579452k swap on /dev/sda5. Priority:-1 extents:1 across:2579452k SS
[ 9.198726] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 9.255868] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 9.291391] loop: module loaded
[ 10.143652] RPC: Registered named UNIX socket transport module.
[ 10.143658] RPC: Registered udp transport module.
[ 10.143661] RPC: Registered tcp transport module.
[ 10.143664] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 10.152609] FS-Cache: Loaded
[ 10.161371] NFS: Registering the id_resolver key type
[ 10.161398] FS-Cache: Netfs 'nfs' registered for caching
[ 10.168194] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 11.326939] Bluetooth: Core ver 2.16
[ 11.326977] NET: Registered protocol family 31
[ 11.326980] Bluetooth: HCI device and connection manager initialized
[ 11.326984] Bluetooth: HCI socket layer initialized
[ 11.326987] Bluetooth: L2CAP socket layer initialized
[ 11.326993] Bluetooth: SCO socket layer initialized
[ 11.341130] Bluetooth: RFCOMM TTY layer initialized
[ 11.341138] Bluetooth: RFCOMM socket layer initialized
[ 11.341141] Bluetooth: RFCOMM ver 1.11
[ 11.350122] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.350128] Bluetooth: BNEP filters: protocol multicast
[ 11.385019] lp: driver loaded but no devices found
[ 11.391927] ppdev: user-space parallel port driver
[ 11.459932] RTL871X: LeaveAllPowerSaveMode(wlan0): bup=0 Skip!
[ 11.459938] RTL871X: rtw_wx_set_scan: bDriverStopped=1, bup=0, hw_init_completed=0
[ 11.460751] RTL871X: +871x_drv - drv_open, bup=0
[ 11.460758] RTL871X: Set RF Chip ID to RF_6052 and RF type to 1T1R.
[ 11.461478] RTL871X: rtl8188e_FirmwareDownload fw:NIC, size: 13904
[ 11.461483] RTL871X: rtl8188e_FirmwareDownload: fw_ver=b fw_subver=0001 sig=0x88e1, Month=11, Date=27, Hour=30, Minute=36
[ 11.485986] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00030005
[ 11.487472] RTL871X: =====> _8051Reset88E(): 8051 reset success .
[ 11.490100] RTL871X: _FWFreeToGo: Polling FW ready OK! (18, 4ms), REG_MCUFWDL:0x000300c6
[ 11.490104] RTL871X: FWDL success. write_fw:1, 28ms
[ 11.664945] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input5
[ 11.788582] ==> rtl8188e_iol_efuse_patch
[ 11.863693] RTL871X: ==> _InitAntenna_Selection ....
[ 11.864318] RTL871X: _InitAntenna_Selection,Cur_ant:(1)MAIN_ANT
[ 11.875943] RTL871X: pDM_Odm TxPowerTrackControl = 1
[ 12.168920] RTL871X: rtl8188eu_hal_init in 708ms
[ 12.169538] RTL871X: hw_var_set_opmode()-4042 mode = 2
[ 12.176668] RTL871X: MAC Address = 7c:dd:90:d4:ad:5b
[ 12.184097] RTL871X: -871x_drv - drv_open, bup=1
[ 12.184316] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 12.195539] forcedeth 0000:00:0a.0: eth0: no link during initialization
[ 12.196851] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.212767] RTL871X: [rtw_wx_set_pmkid] IW_PMKSA_FLUSH!
[ 12.212778] RTL871X: set_mode = IW_MODE_INFRA
[ 12.212874] RTL871X: set bssid:00:00:00:00:00:00
[ 12.212930] RTL871X: =>rtw_wx_set_essid
[ 12.212933] RTL871X: ssid=g\xffffffc6isQ\xffffffffJ\xffffffec)\xffffffcd\xffffffba\xffffffba\xffffffab\xfffffff2\xfffffffb\xffffffe3F|\xffffffc2T\xfffffff8\x1b\xffffffe8\xffffffe7\xffffff8dvZ.c3\xffffff9f\xffffffc9\xffffff9a\xffffff9a, len=32
[ 12.212937] RTL871X: set ssid [g\xffffffc6isQ\xffffffffJ\xffffffec)\xffffffcd\xffffffba\xffffffba\xffffffab\xfffffff2\xfffffffb\xffffffe3F|\xffffffc2T\xfffffff8\x1b\xffffffe8\xffffffe7\xffffff8dvZ.c3\xffffff9f\xffffffc9\xffffff9a\xffffff9a\xffffffbd\xffffffe7\xffffffb9N\xfffffff2\xffffffff\xffffffff\xffffffff\x1a\xffffff8b] fw_state=0x00000008
[ 12.212941] RTL871X: Set SSID under fw_state=0x00000008
[ 12.212947] RTL871X: <=rtw_wx_set_essid, ret 0
[ 12.213914] RTL871X: hw_var_set_opmode()-4042 mode = 2
[ 12.220178] RTL871X: [rtw_wx_set_pmkid] IW_PMKSA_FLUSH!
[ 14.303488] RTL871X: survey done event(2) band:0 for wlan0
[ 14.303498] RTL871X: rtw_select_and_join_from_scanned_queue: return _FAIL(candidate == NULL)
[ 14.303502] RTL871X: try_to_join, but select scanning queue fail, to_roam:0
[ 14.303506] RTL871X: indicate disassoc
[ 14.303518] RTL871X: rtw_indicate_scan_done(wlan0)
[ 14.303525] RTL871X: rtl8188e_set_FwJoinBssReport_cmd mstatus(0)
[ 14.304413] RTL871X: ==>rtw_ps_processor .fw_state(8)
[ 14.304418] RTL871X: ==>ips_enter cnts:1
[ 14.304420] RTL871X: nolinked power save enter
[ 14.304423] RTL871X: ===> rtw_ips_pwr_down...................
[ 14.304425] RTL871X: ====> rtw_ips_dev_unload...
[ 14.334650] RTL871X: usb_read_port_cancel
[ 14.334724] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340099] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340221] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340345] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340471] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340595] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340720] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340846] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 14.340856] RTL871X: usb_write_port_cancel
[ 14.340875] RTL871X: ==> rtl8188eu_hal_deinit
[ 14.341349] RTL871X: bkeepfwalive(0)
[ 14.348109] RTL871X: SetHwReg8188EU: bMacPwrCtrlOn=0
[ 14.348115] RTL871X: <=== rtw_ips_pwr_down..................... in 44ms
[ 14.403935] RTL871X: _rtw_pwr_wakeup call ips_leave....
[ 14.403938] RTL871X: ==>ips_leave cnts:1
[ 14.403941] RTL871X: ===> rtw_ips_pwr_up..............
[ 14.403946] RTL871X: ===> ips_netdrv_open.........
[ 14.406976] RTL871X: SetHwReg8188EU: bMacPwrCtrlOn=1
[ 14.406978] RTL871X: Set RF Chip ID to RF_6052 and RF type to 1T1R.
[ 14.407725] RTL871X: rtl8188e_FirmwareDownload fw:NIC, size: 13904
[ 14.407729] RTL871X: rtl8188e_FirmwareDownload: fw_ver=b fw_subver=0001 sig=0x88e1, Month=11, Date=27, Hour=30, Minute=36
[ 14.426725] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00030005
[ 14.428224] RTL871X: =====> _8051Reset88E(): 8051 reset success .
[ 14.430847] RTL871X: _FWFreeToGo: Polling FW ready OK! (21, 4ms), REG_MCUFWDL:0x000300c6
[ 14.430850] RTL871X: FWDL success. write_fw:1, 20ms
[ 14.716706] ==> rtl8188e_iol_efuse_patch
[ 14.791825] RTL871X: ==> _InitAntenna_Selection ....
[ 14.792571] RTL871X: _InitAntenna_Selection,Cur_ant:(1)MAIN_ANT
[ 14.804448] RTL871X: pDM_Odm TxPowerTrackControl = 1
[ 15.053300] RTL871X: rtl8188eu_hal_init in 652ms
[ 15.053921] RTL871X: hw_var_set_opmode()-4042 mode = 2
[ 15.062308] RTL871X: <=== rtw_ips_pwr_up.............. in 660ms
[ 15.062314] RTL871X: nolinked power save leave
[ 15.062417] RTL871X: ==> ips_leave.....LED(0x00828282)...
[ 15.062422] RTL871X: IW_SCAN_THIS_ESSID, ssid=Net_M, len=5
[ 17.160249] RTL871X: survey done event(2) band:0 for wlan0
[ 17.160259] RTL871X: rtw_indicate_scan_done(wlan0)
[ 17.160620] RTL871X: wpa_set_auth_algs, AUTH_ALG_OPEN_SYSTEM
[ 17.160629] RTL871X: set_mode = IW_MODE_INFRA
[ 17.160646] RTL871X:
[ 17.160647] wpa_ie(length:22):
[ 17.160650] RTL871X: 0x30 0x14 0x01 0x00 0x00 0x0f 0xac 0x02
[ 17.160654] RTL871X: 0x01 0x00 0x00 0x0f 0xac 0x04 0x01 0x00
[ 17.160658] RTL871X: 0x00 0x0f 0xac 0x02 0x00 0x00 0x52 0xf4
[ 17.160996] RTL871X: SetHwReg8188EU, 2964, RCR= 700060ca
[ 17.161009] RTL871X: rtw_wx_set_freq: set to channel 3
[ 17.161016] RTL871X: =>rtw_wx_set_essid
[ 17.161018] RTL871X: ssid=Net_M, len=5
[ 17.161022] RTL871X: set ssid [Net_M] fw_state=0x00000008
[ 17.161025] RTL871X: Set SSID under fw_state=0x00000008
[ 17.161031] RTL871X: [by_bssid:0][assoc_ssid:Net_M][to_roam:0] new candidate: Net_M(00:a0:57:19:f0:39, ch3) rssi:-49
[ 17.161036] RTL871X: rtw_select_and_join_from_scanned_queue: candidate: Net_M(00:a0:57:19:f0:39, ch:3)
[ 17.161039] RTL871X: #### Opt_Ant_(A) , cur_Ant(A)
[ 17.161045] RTL871X: link to new AP
[ 17.161050] RTL871X: <=rtw_wx_set_essid, ret 0
[ 17.161056] RTL871X: set bssid:00:a0:57:19:f0:39
[ 17.161058] RTL871X: Set BSSID under fw_state=0x00000088
[ 17.161615] RTL871X: hw_var_set_opmode()-4042 mode = 2
[ 17.162239] RTL871X: start_join_set_ch_bw: ch=3, bwmode=0, ch_offset=0
[ 17.192376] RTL871X: link to new AP
[ 17.192379] RTL871X: start auth
[ 17.192383] RTL871X: issue_auth
[ 17.193861] RTL871X: OnAuthClient
[ 17.193863] RTL871X: auth success, start assoc
[ 17.193869] RTL871X: network.SupportedRates[0]=0C
[ 17.193872] RTL871X: network.SupportedRates[1]=12
[ 17.193874] RTL871X: network.SupportedRates[2]=98
[ 17.193876] RTL871X: network.SupportedRates[3]=24
[ 17.193878] RTL871X: network.SupportedRates[4]=30
[ 17.193881] RTL871X: network.SupportedRates[5]=48
[ 17.193883] RTL871X: network.SupportedRates[6]=60
[ 17.193885] RTL871X: network.SupportedRates[7]=6C
[ 17.193888] RTL871X: bssrate_len = 8
[ 17.195861] RTL871X: OnAssocRsp
[ 17.195865] RTL871X: report_join_res(3)
[ 17.195869] RTL871X: rtw_joinbss_update_network
[ 17.195877] RTL871X: rtw_alloc_macid = 0
[ 17.195879] RTL871X: rtw_joinbss_update_stainfo
[ 17.195883] RTL871X: ### Set STA_(0) info
[ 17.195887] RTL871X: assoc success
[ 17.195919] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x15f -> 0x15f
[ 17.196107] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 17.198115] RTL871X: HTOnAssocRsp
[ 17.198622] RTL871X: recv eapol packet
[ 17.199492] RTL871X: send eapol packet
[ 17.204743] RTL871X: UpdateHalRAMask8188E => mac_id:0, networkType:0x02, mask:0x00000ff0
[ 17.204745] ==> rssi_level:0, rate_bitmap:0x00000ff0
[ 17.204750] RTL871X: ### MacID(1),Set Max Tx RPT MID(2)
[ 17.204860] RTL871X: ### rtl8188e_set_FwMediaStatus_cmd: MStatus=1 MACID=0
[ 17.205860] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 17.206985] RTL871X: rtl8188e_set_FwJoinBssReport_cmd mstatus(1)
[ 17.208119] RTL871X: SetFwRsvdPagePkt(wlan0)
[ 17.208122] RsvdPageNum: 8
[ 17.208134] RTL871X: SetFwRsvdPagePkt: Set RSVD page location to Fw ,TotalPacketLen(706)
[ 17.209109] RTL871X: wlan0: 1 DL RSVD page success! DLBcnCount:1, poll:1
[ 17.209858] RTL871X: Set RSVD page location to Fw.
[ 17.209984] RTL871X: =>mlmeext_joinbss_event_callback
[ 17.499852] RTL871X: recv eapol packet
[ 17.499978] RTL871X: send eapol packet
[ 17.504965] RTL871X: recv eapol packet
[ 17.505082] RTL871X: send eapol packet
[ 17.505098] RTL871X: ~~~~set sta key:unicastkey
[ 17.505127] RTL871X: set pairwise key camid:4, addr:00:a0:57:19:f0:39, kid:0, type:AES
[ 17.505191] RTL871X: ~~~~set sta key:groupkey
[ 17.505195] RTL871X: ==> rtw_set_key algorithm(2),keyid(1),key_mask(0)
[ 17.508840] RTL871X: set group key camid:5, addr:00:a0:57:19:f0:39, kid:1, type:TKIP
[ 17.509209] RTL871X: SetHwReg8188EU, 2960, RCR= 700060ce
[ 19.074462] RTL871X: UpdateHalRAMask8188E => mac_id:0, networkType:0x02, mask:0x00000ff0
[ 19.074464] ==> rssi_level:1, rate_bitmap:0x00000f00
[ 21.078166] RTL871X: UpdateHalRAMask8188E => mac_id:0, networkType:0x02, mask:0x00000ff0
[ 21.078168] ==> rssi_level:2, rate_bitmap:0x00000ff0
[ 28.032021] wlan0: no IPv6 routers present
[ 29.558929] I-pipe: head domain RTAI registered.
[ 29.558937] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 29.558985] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 29.558990] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12557835, CLK_FREQ 2009406000, CPU_FREQ 2009406000
[ 29.558994] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 29.558998] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12557835, 12557835, 12003250
[ 29.581508] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 29.581566] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 29.581571] RTAI[sched]: hard timer type/freq = APIC/12557835(Hz); default timing: oneshot; linear timed lists.
[ 29.581575] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2009406000 hz.
[ 29.581578] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 29.596157] RTAI[math]: loaded.
[ 29.693802] hm2: loading Mesa HostMot2 driver version 0.15
[ 29.697887] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 29.698034] ACPI: PCI Interrupt Link [APC3] enabled at IRQ 18
[ 29.698054] hm2_pci: discovered 5i25 at 0000:01:06.0
[ 29.699096] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 29.756103] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 29.758848] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 29.761137] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 29.765151] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 29.770336] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 29.894217] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 29.896764] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 29.997000] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 29.997004] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 29.997008] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 29.997011] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 29.997015] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 29.997019] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 29.997023] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 29.997027] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 29.997031] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 29.997035] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 29.997039] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 29.997043] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 29.997047] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 29.997050] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 29.997054] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 29.997058] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 29.997062] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 29.997066] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 29.997070] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #0, pin Direction (Output)
[ 29.997073] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #0, pin Step (Output)
[ 29.997077] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #1, pin Direction (Output)
[ 29.997081] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #1, pin Step (Output)
[ 29.997084] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #2, pin Direction (Output)
[ 29.997088] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #2, pin Step (Output)
[ 29.997092] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #3, pin Direction (Output)
[ 29.997095] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #3, pin Step (Output)
[ 29.997099] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #4, pin Direction (Output)
[ 29.997104] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #4, pin Step (Output)
[ 29.997107] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 29.997110] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 29.997113] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 29.997116] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 29.997119] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 29.997122] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 29.997125] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 29.997291] hm2/hm2_5i25.0: registered
[ 29.997294] hm2_5i25.0: initialized AnyIO board at 0000:01:06.0
[ 30.327270] hm2_5i25.0: dropping AnyIO board at 0000:01:06.0
[ 30.327277] hm2/hm2_5i25.0: unregistered
[ 30.327342] hm2_pci: driver unloaded
[ 30.329735] hm2: unloading
[ 32.001926] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 32.458196] RTAI[math]: unloaded.
[ 32.461183] SCHED releases registered named ALIEN PEDV$D
[ 32.467479] RTAI[malloc]: unloaded.
[ 32.564031] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 32.566688] I-pipe: head domain RTAI unregistered.
[ 32.566742] RTAI[hal]: unmounted.
[ 33.415741] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 33.417615] RTL871X: survey done event(2) band:0 for wlan0
[ 33.417633] RTL871X: rtw_indicate_scan_done(wlan0)
[ 39.109387] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 39.111126] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 67.165127] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 72.006727] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 72.006735] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 72.012336] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 73.419346] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 73.421844] RTL871X: survey done event(2) band:0 for wlan0
[ 73.421850] RTL871X: rtw_indicate_scan_done(wlan0)
[ 75.181324] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 75.181331] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 99.229283] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 99.229289] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 109.249435] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 109.249443] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 129.288855] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 132.006665] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 132.006672] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 132.016249] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 133.424253] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 133.426369] RTL871X: survey done event(3) band:0 for wlan0
[ 133.426376] RTL871X: rtw_indicate_scan_done(wlan0)
[ 135.301221] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 135.301229] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 137.305050] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 137.305058] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 139.308881] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 139.308889] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 163.356962] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 179.388601] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 195.421239] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 201.432604] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 201.432611] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 203.436437] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 203.436444] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 212.002897] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 212.002905] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 212.012343] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 213.423460] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 213.425582] RTL871X: survey done event(2) band:0 for wlan0
[ 213.425592] RTL871X: rtw_indicate_scan_done(wlan0)
[ 213.456586] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 213.456593] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 213.815181] I-pipe: head domain RTAI registered.
[ 213.815191] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 213.815244] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 213.815249] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12557835, CLK_FREQ 2009406000, CPU_FREQ 2009406000
[ 213.815252] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 213.815256] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12557835, 12557835, 10894250
[ 213.824090] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 213.824176] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 213.824182] RTAI[sched]: hard timer type/freq = APIC/12557835(Hz); default timing: oneshot; linear timed lists.
[ 213.824186] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2009406000 hz.
[ 213.824189] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 213.829850] RTAI[math]: loaded.
[ 213.999804] hm2: loading Mesa HostMot2 driver version 0.15
[ 214.002519] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 214.002568] hm2_pci: discovered 5i25 at 0000:01:06.0
[ 214.003844] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 214.060730] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 214.063376] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 214.065715] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 214.069845] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 214.074821] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 214.198900] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 214.201447] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 214.301567] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 214.301571] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 214.301574] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 214.301578] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 214.301582] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 214.301586] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 214.301590] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 214.301594] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 214.301598] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 214.301602] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 214.301606] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 214.301610] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 214.301614] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 214.301618] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 214.301621] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 214.301625] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 214.301629] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 214.301633] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 214.301637] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #0, pin Direction (Output)
[ 214.301641] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #0, pin Step (Output)
[ 214.301644] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #1, pin Direction (Output)
[ 214.301648] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #1, pin Step (Output)
[ 214.301652] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #2, pin Direction (Output)
[ 214.301656] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #2, pin Step (Output)
[ 214.301659] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #3, pin Direction (Output)
[ 214.301663] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #3, pin Step (Output)
[ 214.301667] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #4, pin Direction (Output)
[ 214.301670] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #4, pin Step (Output)
[ 214.301674] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 214.301677] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 214.301680] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 214.301683] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 214.301686] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 214.301689] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 214.301693] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 214.301858] hm2/hm2_5i25.0: registered
[ 214.301862] hm2_5i25.0: initialized AnyIO board at 0000:01:06.0
[ 214.559058] hm2_5i25.0: dropping AnyIO board at 0000:01:06.0
[ 214.559066] hm2/hm2_5i25.0: unregistered
[ 214.559132] hm2_pci: driver unloaded
[ 214.561419] hm2: unloading
[ 216.684648] RTAI[math]: unloaded.
[ 216.686871] SCHED releases registered named ALIEN PEDV$D
[ 216.701231] RTAI[malloc]: unloaded.
[ 216.800024] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 216.802288] I-pipe: head domain RTAI unregistered.
[ 216.802341] RTAI[hal]: unmounted.
[ 221.473029] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 237.504668] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 253.537306] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 269.568823] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 269.568831] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 271.572653] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 271.572660] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 291.613074] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 307.644713] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 312.004536] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 312.004543] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 312.012343] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 313.423972] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 313.426345] RTL871X: survey done event(3) band:0 for wlan0
[ 313.426351] RTL871X: rtw_indicate_scan_done(wlan0)
[ 313.657078] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 313.657084] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 323.677352] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 355.740631] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 371.773269] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 387.804908] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 423.876846] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 432.007469] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 432.007477] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 432.016442] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 433.427786] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 433.429408] RTL871X: survey done event(1) band:0 for wlan0
[ 433.429415] RTL871X: rtw_indicate_scan_done(wlan0)
[ 433.896872] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 433.896879] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 439.909483] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 448.722997] I-pipe: head domain RTAI registered.
[ 448.723005] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 448.723056] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 448.723060] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12557835, CLK_FREQ 2009406000, CPU_FREQ 2009406000
[ 448.723064] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 448.723068] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12557835, 12557835, 11380750
[ 448.731516] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 448.731574] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 448.731580] RTAI[sched]: hard timer type/freq = APIC/12557835(Hz); default timing: oneshot; linear timed lists.
[ 448.731584] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2009406000 hz.
[ 448.731587] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 448.739971] RTAI[math]: loaded.
[ 448.907247] hm2: loading Mesa HostMot2 driver version 0.15
[ 448.909697] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 448.909750] hm2_pci: discovered 5i25 at 0000:01:06.0
[ 448.911017] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 448.967949] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 448.970645] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 448.972884] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 448.976947] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 448.982029] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 449.105642] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 449.108183] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 449.208335] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 449.208339] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 449.208343] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 449.208346] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 449.208350] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 449.208355] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 449.208359] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 449.208363] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 449.208367] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 449.208371] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 449.208374] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 449.208378] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 449.208382] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 449.208386] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 449.208390] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 449.208394] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 449.208398] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 449.208402] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 449.208406] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #0, pin Direction (Output)
[ 449.208409] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #0, pin Step (Output)
[ 449.208413] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #1, pin Direction (Output)
[ 449.208417] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #1, pin Step (Output)
[ 449.208421] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #2, pin Direction (Output)
[ 449.208424] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #2, pin Step (Output)
[ 449.208428] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #3, pin Direction (Output)
[ 449.208432] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #3, pin Step (Output)
[ 449.208435] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #4, pin Direction (Output)
[ 449.208439] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #4, pin Step (Output)
[ 449.208442] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 449.208445] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 449.208449] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 449.208452] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 449.208455] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 449.208458] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 449.208461] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 449.208626] hm2/hm2_5i25.0: registered
[ 449.208629] hm2_5i25.0: initialized AnyIO board at 0000:01:06.0
[ 449.480059] hm2_5i25.0: dropping AnyIO board at 0000:01:06.0
[ 449.480066] hm2/hm2_5i25.0: unregistered
[ 449.480304] hm2_pci: driver unloaded
[ 449.482456] hm2: unloading
[ 451.605946] RTAI[math]: unloaded.
[ 451.608313] SCHED releases registered named ALIEN PEDV$D
[ 451.614178] RTAI[malloc]: unloaded.
[ 451.712034] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 451.714478] I-pipe: head domain RTAI unregistered.
[ 451.714531] RTAI[hal]: unmounted.
[ 455.941124] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 492.013062] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 508.044700] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 524.077338] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 536.101191] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 536.101200] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 540.108851] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 540.108864] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 542.112677] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 542.112685] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 550.129005] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 550.129014] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 552.004566] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 552.004575] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 552.012809] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 553.423586] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 553.425586] RTL871X: survey done event(1) band:0 for wlan0
[ 553.425614] RTL871X: rtw_indicate_scan_done(wlan0)
[ 556.140496] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 556.140504] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 564.156810] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 564.156818] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 578.184622] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 578.184630] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 586.200942] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 586.200950] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 588.204775] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 588.204783] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 594.217256] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 594.217264] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 598.224921] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 598.224930] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 600.228753] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 600.228761] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 602.232581] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 602.232589] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 604.237414] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 604.237422] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 608.245074] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 608.245082] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 616.261391] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 616.261399] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 618.265223] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 618.265231] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 620.268424] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 620.268432] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 622.272883] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 622.272891] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 624.276710] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 624.276717] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 628.285372] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 628.285380] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 630.289197] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 630.289206] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 634.296861] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 634.296869] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 636.300692] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 636.300699] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 638.304521] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 638.304528] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 646.320837] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 646.320844] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 648.324667] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 648.324674] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 656.340989] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 656.340995] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 658.344820] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 658.344828] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 660.348650] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 660.348658] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 662.352480] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 662.352488] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 666.361139] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 666.361147] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 668.364970] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 668.364977] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 672.006974] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 672.006983] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 672.016306] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 673.427412] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 673.429533] RTL871X: survey done event(3) band:0 for wlan0
[ 673.429539] RTL871X: rtw_indicate_scan_done(wlan0)
[ 674.376458] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 674.376466] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 676.381289] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 676.381297] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 678.385117] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 678.385126] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 680.388948] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 680.388956] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 682.392779] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 682.392787] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 690.409097] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 690.409105] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 692.412927] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 692.412935] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 720.898745] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_SPECIAL_PACKET
[ 720.898755] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 722.473376] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 722.473384] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 746.521334] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 746.521342] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 750.528998] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 750.529006] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 766.560755] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 782.593395] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 792.007341] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 792.007349] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 792.016427] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 793.424225] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 793.426216] RTL871X: survey done event(3) band:0 for wlan0
[ 793.426223] RTL871X: rtw_indicate_scan_done(wlan0)
[ 794.617253] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 794.617262] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 800.628739] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 800.628747] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 802.632570] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 802.632578] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 808.645311] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 808.645318] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 810.648892] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 810.648901] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 812.652720] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 812.652727] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 814.656551] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 814.656559] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 832.693142] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 848.724781] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 864.757419] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 900.829356] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 912.004653] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 912.004661] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 912.012529] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 913.424041] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 913.426071] RTL871X: survey done event(3) band:0 for wlan0
[ 913.426092] RTL871X: rtw_indicate_scan_done(wlan0)
[ 918.864701] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 918.864711] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 926.881029] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 926.881041] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 928.884853] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 928.884861] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 930.888683] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 930.888690] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 936.901169] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 936.901178] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 962.952962] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 962.952970] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 964.956791] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 964.956799] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 968.965451] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 968.965458] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 970.969283] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 970.969291] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 972.973107] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 972.973116] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 980.989431] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 980.989439] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 995.017359] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 1027.538791] I-pipe: head domain RTAI registered.
[ 1027.538800] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1027.538845] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1027.538850] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12557835, CLK_FREQ 2009406000, CPU_FREQ 2009406000
[ 1027.538854] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1027.538858] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12557835, 12557835, 12475250
[ 1027.547813] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1027.547870] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1027.547876] RTAI[sched]: hard timer type/freq = APIC/12557835(Hz); default timing: oneshot; linear timed lists.
[ 1027.547880] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2009406000 hz.
[ 1027.547883] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1027.558088] RTAI[math]: loaded.
[ 1027.725346] hm2: loading Mesa HostMot2 driver version 0.15
[ 1027.727735] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1027.727783] hm2_pci: discovered 5i25 at 0000:01:06.0
[ 1027.728868] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1027.786003] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 1027.788794] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 1027.791188] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 1027.795224] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 1027.800402] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 1027.924521] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 1027.927067] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 1028.027093] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1028.027097] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 1028.027101] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 1028.027104] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 1028.027108] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 1028.027112] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 1028.027116] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 1028.027120] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 1028.027124] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 1028.027128] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 1028.027132] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 1028.027135] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 1028.027139] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 1028.027143] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 1028.027147] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 1028.027151] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 1028.027154] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 1028.027158] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 1028.027162] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #0, pin Direction (Output)
[ 1028.027166] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #0, pin Step (Output)
[ 1028.027170] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #1, pin Direction (Output)
[ 1028.027173] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #1, pin Step (Output)
[ 1028.027177] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #2, pin Direction (Output)
[ 1028.027180] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #2, pin Step (Output)
[ 1028.027184] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #3, pin Direction (Output)
[ 1028.027188] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #3, pin Step (Output)
[ 1028.027191] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #4, pin Direction (Output)
[ 1028.027195] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #4, pin Step (Output)
[ 1028.027198] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 1028.027201] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 1028.027204] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 1028.027207] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 1028.027210] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 1028.027213] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 1028.027217] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 1028.027382] hm2/hm2_5i25.0: registered
[ 1028.027385] hm2_5i25.0: initialized AnyIO board at 0000:01:06.0
[ 1028.302364] hm2_5i25.0: dropping AnyIO board at 0000:01:06.0
[ 1028.302372] hm2/hm2_5i25.0: unregistered
[ 1028.302438] hm2_pci: driver unloaded
[ 1028.304735] hm2: unloading
[ 1030.429512] RTAI[math]: unloaded.
[ 1030.431808] SCHED releases registered named ALIEN PEDV$D
[ 1030.435091] RTAI[malloc]: unloaded.
[ 1030.532026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1030.534299] I-pipe: head domain RTAI unregistered.
[ 1030.534355] RTAI[hal]: unmounted.
[ 1032.006575] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1032.006583] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1032.012436] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 1033.423850] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 1033.425848] RTL871X: survey done event(3) band:0 for wlan0
[ 1033.425856] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1037.100667] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1037.100675] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1059.144917] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 1093.212906] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1093.212914] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1095.216733] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1095.216740] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1099.225393] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1099.225399] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1101.229223] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1101.229230] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1115.257157] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 1131.288793] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 1152.007536] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1152.007545] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1152.016286] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x48c=0x00000000
[ 1153.427664] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000001
[ 1153.429537] RTL871X: survey done event(4) band:0 for wlan0
[ 1153.429563] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1159.345290] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1159.345297] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1173.373223] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 1189.404858] RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
[ 1191.408573] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1191.408581] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1195.417231] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1195.417239] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1197.421061] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1197.421069] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1199.424889] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1199.424897] RTL871X: rtl8188e_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1217.554991] I-pipe: head domain RTAI registered.
[ 1217.554999] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1217.555046] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1217.555051] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12557835, CLK_FREQ 2009406000, CPU_FREQ 2009406000
[ 1217.555055] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1217.555059] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12557835, 12557835, 11417500
[ 1217.567561] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1217.567621] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1217.567709] RTAI[sched]: hard timer type/freq = APIC/12557835(Hz); default timing: oneshot; linear timed lists.
[ 1217.567714] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2009406000 hz.
[ 1217.567717] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1217.573352] RTAI[math]: loaded.
[ 1217.743267] hm2: loading Mesa HostMot2 driver version 0.15
[ 1217.746046] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1217.746096] hm2_pci: discovered 5i25 at 0000:01:06.0
[ 1217.747352] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1217.804257] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 1217.806903] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 1217.809142] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 1217.813206] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 1217.818287] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 1217.941830] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 1217.944376] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 1218.044490] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1218.044494] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 1218.044497] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 1218.044499] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 1218.044503] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 1218.044507] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 1218.044511] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 1218.044515] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 1218.044519] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 1218.044523] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 1218.044526] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 1218.044530] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 1218.044534] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 1218.044537] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 1218.044541] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 1218.044544] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 1218.044548] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 1218.044552] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 1218.044556] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #0, pin Direction (Output)
[ 1218.044559] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #0, pin Step (Output)
[ 1218.044563] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #1, pin Direction (Output)
[ 1218.044566] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #1, pin Step (Output)
[ 1218.044570] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #2, pin Direction (Output)
[ 1218.044573] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #2, pin Step (Output)
[ 1218.044577] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #3, pin Direction (Output)
[ 1218.044581] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #3, pin Step (Output)
[ 1218.044584] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #4, pin Direction (Output)
[ 1218.044588] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #4, pin Step (Output)
[ 1218.044591] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 1218.044593] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 1218.044596] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 1218.044599] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 1218.044602] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 1218.044605] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 1218.044607] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 1218.044772] hm2/hm2_5i25.0: registered
[ 1218.044775] hm2_5i25.0: initialized AnyIO board at 0000:01:06.0
[ 1218.319377] hm2_5i25.0: dropping AnyIO board at 0000:01:06.0
[ 1218.319385] hm2/hm2_5i25.0: unregistered
[ 1218.319451] hm2_pci: driver unloaded
[ 1218.321990] hm2: unloading
[ 1220.444296] RTAI[math]: unloaded.
[ 1220.446556] SCHED releases registered named ALIEN PEDV$D
[ 1220.454285] RTAI[malloc]: unloaded.
[ 1220.552026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1220.554331] I-pipe: head domain RTAI unregistered.
[ 1220.554387] RTAI[hal]: unmounted.
Last edit: 29 Dec 2017 09:50 by Ichzwei.
29 Dec 2017 16:38 #103823
by Henk
Replied by Henk on topic Analog Overrides? 5i25+7i77 Mode 3
HI
I think you are trying to write to a signal that is an "out" pin. not an "in" pin in halui
From the halui man-page
spindle override
halui.spindle-override.count-enable bit in (default: TRUE)
When TRUE, modify spindle override when counts changes.
halui.spindle-override.counts s32 in
counts X scale = spindle override percentage
halui.spindle-override.decrease bit in
pin for decreasing the SO (-=scale)
halui.spindle-override.direct-value bit in
pin to enable direct spindle override value input
halui.spindle-override.increase bit in
pin for increasing the SO (+=scale)
halui.spindle-override.scale float in
pin for setting the scale of counts for SO
halui.spindle-override.value float out
current FO value
You need to connect to halui.spindle-override.counts and set the scale pin so that scale x counts = %override.
eg: net spindle-override spindle-scale.out => halui.spindle-override.counts
But halui.spindle-override.counts is a s32 pin and spindle-scale.out is float, so you will have to convert the out from spindle-scale to s32 using conv_float_s32 component.
in short: analog-in (from pot) => spindle-scale => conv_float_s32 => halui.spindle-override.counts.
You will also have to set the gain of the scale and maybe offset to achieve the desired counts
Hope this helps
Henk
spindle override
current FO value
Hope this helps
Henk
The following user(s) said Thank You: Ichzwei
29 Dec 2017 19:07 - 29 Dec 2017 19:55 #103825
by Ichzwei
Replied by Ichzwei on topic Analog Overrides? 5i25+7i77 Mode 3
thanks henk,
you helpt me solving the problem.
i add this to the hal file... now i can chance the spindle override from 50%-100% on the potentiometer.
but i notice that on the start of linuxcnc the override is not the absolute value of the poti.
i need to rotate it and then the value in linuxcnc chanced.
greetings
michael
loadrt conv_float_s32 count=1
loadrt scale names=spindle-scale
addf spindle-scale servo-thread
addf conv-float-s32.0 servo-thread
setp halui.spindle-override.direct-value false
setp halui.spindle-override.count-enable true
setp spindle-scale.gain 4.16666
setp spindle-scale.offset 0
setp halui.spindle-override.scale 0.005
net spindle-analogue hm2_5i25.0.7i77.0.0.analogin0 => spindle-scale.in
net spindle-convert spindle-scale.out conv-float-s32.0.in
net spindle-override conv-float-s32.0.out halui.spindle-override.counts
greetings
michael
Last edit: 29 Dec 2017 19:55 by Ichzwei.
12 Jan 2018 16:41 #104341
I think this should be "true"
Replied by andypugh on topic Analog Overrides? 5i25+7i77 Mode 3
- xenon-alien
- Thank you received: 3
10 Sep 2020 15:28 - 10 Sep 2020 15:37 #181647
by xenon-alien
Replied by xenon-alien on topic Analog Overrides? 5i25+7i77 Mode 3
Can you help me out?
Did the same for feed override and have a halui.feed−override.direct−value not found error
The spindle part working, when I comment out the "Analog in 1 Feed" part.
www.instagram.com/p/CE9VqzCJiAx/
For now I'm using one input for both.
loadrt conv_float_s32 count=2
loadrt scale names=spindle-scale,feed-scale
# analog 0
# analog 1
addf feed-scale servo-thread
addf conv-float-s32.1 servo-thread
setp halui.feed−override.direct−value false
setp halui.feed−override.count−enable true
setp feed-scale.gain 4.16666
setp feed-scale.offset 0
setp halui.feed−override.scale 0.005
net feed-analogue hm2_7i76e.0.7i76.0.0.analogin0 => feed-scale.in
net feed-convert feed-scale.out conv-float-s32.1.in
net feed-override conv-float-s32.1.out halui.feed−override.counts
Last edit: 10 Sep 2020 15:37 by xenon-alien.
10 Sep 2020 16:27 #181653
Replied by cmorley on topic Analog Overrides? 5i25+7i77 Mode 3
hyphen looks different in direct-value
The following user(s) said Thank You: xenon-alien
Time to create page: 0.173 seconds
