spindle control
- M4MazakUser
- Thank you received: 3
16 Aug 2010 08:06 #3772
by M4MazakUser
spindle control was created by M4MazakUser
HELP!
i have now got a running machine, but can't get the spindle index pulse working.
my setup was originally generated by the Pncconf, and looks nothing like any others.
my problem is the encoder settings for my spindle.
setp hm2_5i20.0.encoder.02.counter-mode false
setp hm2_5i20.0.encoder.02.filter true
setp hm2_5i20.0.encoder.02.index-invert 0
setp hm2_5i20.0.encoder.02.index-enable 1
setp hm2_5i20.0.encoder.02.index-mask 0
setp hm2_5i20.0.encoder.02.index-mask-invert 0
setp hm2_5i20.0.encoder.02.scale [SPINDLE_9]INPUT_SCALE
net spindle-vel-fb <= hm2_5i20.0.encoder.02.velocity
net spindle-index-enable <=> hm2_5i20.0.encoder.02.index-enable
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd <= motion.spindle-speed-out
net spindle-enable <= motion.spindle-on
net spindle-vel-cmd => near.0.in1
net spindle-vel-fb => near.0.in2
# net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed motion.spindle-at-speed <= near.0.out
net spindle-vel-fb => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
setp near.0.scale 1.07
i have checked the pinouts on my card, 14 - 15 - 17 a,b, z
and they all work. but! theZ channel is not making the spindle-index-enable work.
i.e. the z channel just counts and dosen't reset every revolution.
this means i have a big ZERO in spindle-revs
any help appreciated as i've tried and read all i can...
i want feed per rev!
16 Aug 2010 13:07 #3774
by BigJohnT
Replied by BigJohnT on topic Re:spindle control
Is your motion spindle at speed true (not sure of the exact syntax)? Spindle sync waits for spindle at speed...
- M4MazakUser
16 Aug 2010 20:07 - 16 Aug 2010 20:12 #3775
by M4MazakUser
Replied by M4MazakUser on topic Re:spindle control
yes that works fine
this float displays the correct speed
Last edit: 16 Aug 2010 20:12 by M4MazakUser.
16 Aug 2010 21:38 #3777
by BigJohnT
Not the spindle speed but the motion.spindle-at-speed must be "true".
17 Aug 2010 04:17 #3780
Replied by cmorley on topic Re:spindle control
What version of EMC are you using ? Could you post your pncconf files?
spindle configuration has not been tested well in pncconf but we'll fix em as soon as we find them.
- M4MazakUser
17 Aug 2010 07:52 #3782
by M4MazakUser
The spindle at speed works properly, (the bit is on when the speed is in range -I am using near)
I'll post the config files tomorrow, I installed from the live cd, 4weeks ago, I'll check versions.
17 Aug 2010 11:42 #3787
by BigJohnT
I think the Z needs some kind of reset let me check my config on my lathe to see if I can find it.
- M4MazakUser
17 Aug 2010 11:58 #3788
by M4MazakUser
Yes in my thinking, the spindle index should reset the count every revolution therefore making the spindle revs a meaningful number. This would also make the spindle position meaningful.
17 Aug 2010 12:05 - 17 Aug 2010 12:06 #3789
by BigJohnT
I see the problem finally!
should be
net spindle-index motion.spindle-index-enable <= hm2_5i20.0.encoder.02.index-enable
should be
Last edit: 17 Aug 2010 12:06 by BigJohnT.
- M4MazakUser
17 Aug 2010 12:24 #3790
by M4MazakUser
Thanks! I'll give that a try tomorrow, looks to me that should be it.
As long as it tis noted that this is as it was written from pncconf !
Thanks!
Thanks!
Time to create page: 0.092 seconds
