pncconf - feature requests
31 Mar 2011 05:55 - 31 Mar 2011 05:56 #8309 by cmorley
cmorley replied the topic: Re:pncconf - feature requests
here is a sample config with just random settings:
You may need to edit the mesa load config to get it to run
on 2.4. (the 3pwmgen line)
File Name: zig.zip
File Size:5 KB
Last Edit: 31 Mar 2011 05:56 by cmorley.
31 Mar 2011 08:51 #8315 by andypugh
andypugh replied the topic: Re:pncconf - feature requests
Is "numof_3pwmgen" ever a valid modparam? I thought it was "num_3pwmgens".
In either case, it will cause the drivers to not load and emc2 to fail to start with 2.4. On reflection I am not sure that that is the most logical behaviour. Perhaps it should carry on regardless?
31 Mar 2011 22:50 - 31 Mar 2011 22:50 #8350 by Zig
Zig replied the topic: Re:pncconf - feature requests
Chris,
attached the current configuration of the machine.
No spindle control. I need to think through the safety interlocks as the spindle has a pneumatic collet. I have to investigate the spindle speed monitor and interlock the air solenoid ( which is presently push button activated ) so that an auto tool changer functionality can be implemented.
So a basic XYZ METRIC machine.
Leadscrews are 5 mm pitch.
Servo motors are directly coupled to the screws.
Linear scale has a basic resolution of 20 micron but in quadrature mode the resolution is 5 micron.
The reader head on the scale outputs an Index pulse for homing as well as an end of travel flag ( a single flag for both positive and negative limits).
File Name: custom_postgui.hal
File Size:1 KB
Last Edit: 31 Mar 2011 22:50 by Zig.
31 Mar 2011 22:52 - 31 Mar 2011 22:52 #8351 by Zig
Config file
File Name: mat_mill.hal
File Size:4 KB
Last Edit: 31 Mar 2011 22:52 by Zig.
31 Mar 2011 22:54 #8352 by Zig
and the third part of the trilogy ( thank goodnes its not in four parts)
File Name: mat_mill.ini
File Size:2 KB
Sorry about this
31 Mar 2011 23:01 - 31 Mar 2011 23:46 #8353 by Zig
and the planned interface electronics
EDIT..file too large
Last Edit: 31 Mar 2011 23:46 by Zig.
31 Mar 2011 23:54 #8359 by Zig
Ok smaller size file...
File Name: interface_...da98.zip
File Size:114 KB
01 Apr 2011 00:47 #8361 by cmorley
couldn't load this last one...
01 Apr 2011 01:35 - 01 Apr 2011 01:39 #8362 by Zig
Chris,
Apologies...
The file was compressed into a RAR format and relabeled as .ZIP to comply with the file extension filter.
This is a more complete drawing
EDIT: still too large
Last Edit: 01 Apr 2011 01:39 by Zig.
01 Apr 2011 01:45 - 01 Apr 2011 01:49 #8363 by Zig
Updated schematic diagram ( atium DXp 2004 version available)
File Name: interface_...0d10.zip
File Size:117 KB
EDIT:
Ought we move this to a separatetopic?
Last Edit: 01 Apr 2011 01:49 by Zig.
Time to create page: 0.286 seconds
