Re:pncconf - feature requests
23 Feb 2012 19:46 - 23 Feb 2012 19:47 #17978 by BigJohnT
Here is the dmesg output from earlier this morning. Using this line to load the driver
loadrt hostmot2 debug_idrom=1 debug_module_descriptors=1 debug_pin_descriptors=1 debug_modules=1
File Name: 5i25dmesg.txt
File Size:25 KB
Last edit: 23 Feb 2012 19:47 by BigJohnT.
23 Feb 2012 20:26 #17982 by PCW
Replied by PCW on topic Re:pncconf - feature requests
I dont think its anything low level just that the name in hal is wrong somehow. (the extraneous "/hm2")
The proper parameter name is in the parameter list (from your 5i25_7i77_pins_parameters.txt)
9 u32 RW 0x3B9ACA00 hm2_5i25.0.watchdog.timeout_ns
24 Feb 2012 04:22 #17999 by cmorley
not sure if its a typo but Johns quote has 5125 instead of 5i25.
24 Feb 2012 04:40 #18000 by PCW
Sure looks like the name in the hal setp line is wrong, whatever the cause...
24 Feb 2012 12:00 #18016 by BigJohnT
Chris,
Good catch on my typo and the two keys are not even on the same hand!
25 Feb 2012 04:08 #18068 by cmorley
I do it too. 5125 is just more natural :)
25 Feb 2012 06:31 #18069 by cmorley
Thank you for the 7i77 pinouts guys.
I assume this is mode 0 . is that the only mode?
25 Feb 2012 14:16 - 25 Feb 2012 14:27 #18079 by BigJohnT
Yes, it was mode 0, I don't know if others are supported yet... let me see if it blows up.
I'm not sure how to change the mode at this time. I changed the sserial part from 002XXX to 102XXX and it loaded but the pins seem to be the same.
Last edit: 25 Feb 2012 14:27 by BigJohnT.
25 Feb 2012 16:09 #18082 by PCW
mode 1 should add 4 analog inputs
mode 2 should add the 4 analog inputs plus field voltage
mode 3 should throw an error (well it may just cause all field I/O pins to disappear)
this is the first number in the config string
the second is for the analog out section (mode 0 only)
the third is for the expansion connector (not used unless you have an additional SSERIAL card)
04 Mar 2012 15:02 #18342 by BigJohnT
BigJohnT wrote:
Chris,
Here you go... I had a bit of a time getting it up and running, didn't seem to like the setp hm2_5125.0.watchdog.timeout_ns 10000000 line.
File Name: 5i25_7i77_...ters.txt
File Size:22 KB
Chris,
This list is not complete as I didn't have the field power connected when I made it. I'll get you an updated list if you don't all ready have it...
Time to create page: 0.181 seconds
