Re:pncconf - feature requests
25 Dec 2014 04:11 #54300
Replied by cmorley on topic Suggestion
Well if you do sometime, let me know how it went.
I rely on bug reports as I really can't test enough
Chris M
Chris M
04 Jan 2015 09:04 #54534
I have pushed some pncconf work into master, that covers the basic connections for the gs2 vfd.
The HAL file is based on the snippet from the manual.
One thing that is not clear to me is how to scale the command speed from motor RPM to spindle RPM
without using a scale component, do people just adjust the nameplate RPM setting?
There is also work for using a two speed gearbox for an analog controlled spindle.
Using a Gcode to select the range is not covered yet.
If anyone could build a pncconf config to confirm the GS2 VFD HAL file is correct , that would be great.
if anyone could build a config using the two range spindle and let me know if the 'calculate scale' button
helps to figure out how to set everything that would be great too.
any other bugs / comments / testing / patches is always welcome.
Chris M
Chris M
28 Jun 2015 01:27 - 28 Jun 2015 01:29 #60195
by upa-de
Replied by upa-de on topic pncconf - feature requests
My request would be g540 support. I am not sure if it is applicable based on this post:
Post# 33186
I appreciate the work that goes into this. I am willing to make a donation to make this happen. A g540 selection in stepconf was the only reason i got linuxcnc to work.
best regards, Rory
best regards, Rory
Last edit: 28 Jun 2015 01:29 by upa-de.
- Perumal-insten
20 Jul 2015 16:13 #60778
by Perumal-insten
Replied by Perumal-insten on topic pncconf - feature requests
i have purchased MESA 7i92 and 7i77 card for LinuxCNC. While installing i am not Able to Locate it in the system as well as in Pncconfig. Any one pls guide to how use them.
I am new to this and i need support like how to start.
PCW pls look into this.
21 Jul 2015 00:35 #60784
Replied by cmorley on topic pncconf - feature requests
Sorry the 7i92 is not supported in pncconf.
I don't have hardware to test with.
Chris M
Chris M
21 Jul 2015 01:23 - 21 Jul 2015 01:25 #60785
Replied by PCW on topic pncconf - feature requests
The 7I92 configuration would be pretty much a clone of a 5i25 configuration.
(so one option is to use pncconf to make a 5i25/7i77 config and then edit the hal file to
make it suitable for the 7I92, just globally changing "5i25" to 7I92" is 99 % of the changes)
Differences are these:
Card name is 7i92 instead of 5i25
7I92 is an Ethernet card so it needs the hm2_eth driver instead of hm2_pci
the driver needs the board_ip parameter set to the 7I92s IP address
I/O 0..16 are on the 7I92s P2 instead of P3
I/O 17..33 are on P1 instead of P2
(these connector name changes make no difference in the hal file)
Last edit: 21 Jul 2015 01:25 by PCW.
- Perumal-insten
21 Jul 2015 14:31 #60792
by Perumal-insten
Dear PCW,
I am New to This.
I am not able to see that the 7i92 is detected by linuxcnc.
Please, send me any kind of Step by Step Procedure to use this Card.
S.Perumal
Instrutek Engineers.
India
I am New to This.
S.Perumal
India
- Perumal-insten
21 Jul 2015 14:40 #60793
by Perumal-insten
Dear PCW,
i am in to lot of confusion on Mesaflah and hostmot2, Pncconf..like. Why so, many... why not single graphical interface to do so, only god knows...
i don't know, if at all Mesa selling these cards, they could have developed some kind of graphical interface to get this things done.
when we buy hardware for Mech3, even from china they start work with in an hour,
here in mesa, i have ordered 45 days back. it has came now, and even there is information that the card is presently configured for ????
in linuxCNC there are many Mesa Plugin - go Cards interface has to be updated.
i don't know Why Mesa is Massing up Everything. Directly go to LinuxCNC and select the card and go on.. it should be like that.
This only my Opinion may differ from person to person. but, my exp with low cost Chinese Cards with Mech3 is woks with out Typing single Word. all click away. fantastic..
We also should do something like this for our upcoming new users...
S.Perumal
India[/quote]
S.Perumal
India[/quote]
21 Jul 2015 16:02 #60796
The Mesa cards are general-purpose IO cards. They can be used for many other applications than LinuxCNC. I believe thatLinuxCNC is a minority user of Mesa hardware.
So, the configuration problems are not due to Mesa, who simply provide hardware, but with LinuxCNC. LinuxCNC is an open-source project where things get done for free by people who are feeling helpful and have the time.
In this case the volunteer who has written PNCconf doesn't have a 7i92, so is not in a position to configure PNCconf to support it.
It seems to me that you do have a 7i92, so if you would like to modify PNCconf to support the 7i92, that would be great
Replied by andypugh on topic pncconf - feature requests
I don't know, if at all Mesa selling these cards, they could have developed some kind of graphical interface to get this things done.
01 Feb 2016 17:11 #69371
by vre
Replied by vre on topic pncconf - feature requests
request for supporting 5i24 & 7i80db.
Thank you.
Thank you.
Time to create page: 0.105 seconds
