Re:pncconf - feature requests
18 Jun 2016 11:26 #76254 by epineh
Replied by epineh on topic pncconf - feature requests
One feature I would request and sorry if I have missed it, is a servo fault input, I guess ideally an input per axis would be nice otherwise a global fault input signal for step/dir servo drives. I am currently setting up such a machine and tried to tie the servo fault from the drives to the estop in signal as I couldn't see a drive fault input option, but that removed the existing estop input, seems there can only be one estop in signal.
A workaround could be to link the fault signal to a limit switch but it would be nice to have a following error report if that is what happens.
Great work otherwise, about the only thing I have to manually edit so far is the max velocity, using metric 100mm/min is way too slow for anything, but I am getting quick at editing the .ini file.
Cheers.
Russell.
18 Jun 2016 14:11 #76260 by andypugh
Replied by andypugh on topic pncconf - feature requests
It isn't clear which pins you have tried to use, but for each axis there is a pin
axis.N.amp-fault-in
You can also look at:
iocontrol.0.emc-enable-in
halui.estop.activate
18 Jun 2016 23:54 #76272 by epineh
Can that be done inside Pncconf ?
Being a new machine I am using Pncconf a lot to change settings, as I am setting it up bit by bit.
If I edit it manually I will lose the change once Pncconf is run again.
13 Jul 2016 22:16 #77417 by vre
Replied by vre on topic pncconf - feature requests
Request for supporting xml files generated by mesaflash.
Thanks.
03 Sep 2016 03:33 #79952 by calvin.d
Replied by calvin.d on topic pncconf - feature requests
request for allowing usb devices to be configured for gs2-vfd setup
they are going to be dev/ttyUSB# where # starts at 0
also in the gs2-vfd config that is generated
the line
net spindle-on => spindle-vfd.spindle-on
need to be changed to
net spindle-enable => spindle-vfd.spindle-on
for it to work for me
Thank You
Calvin
03 Sep 2016 05:46 #79956 by cmorley
Replied by cmorley on topic pncconf - feature requests
ok I pushed a change for the ability to set the device name for the gs2 vfd.
And fixed the signal name spindle-on
next release of 2.7 series should have it.
Chris M
07 Sep 2016 01:00 #80102 by calvin.d
ok found 2 more issues
7i76 encoder mode 2 is not being set properly in the hal file
loadrt hm2_pci config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
should be
loadrt hm2_pci config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=20xxxx"
and I had an interesting error
net joint-selected-count <= hm2_5i25.0.7i76.0.0.enc0.count
should be
net joint-selected-count <= hm2_5i25.encoder.00.count
i have attached the config it generated
Thank You
Calvin
07 Sep 2016 01:07 - 07 Sep 2016 01:08 #80104 by PCW
Replied by PCW on topic pncconf - feature requests
should be
I dont think that's an error
(the 5i25 encoder is used for the spindle while the 7i76 MPG encoder is used for jogging)
Last edit: 07 Sep 2016 01:08 by PCW.
07 Sep 2016 01:27 #80106 by calvin.d
i see, so it is still wrong, just not in the way I thought it was :)
let me change it to your way and see what happens
C
07 Sep 2016 01:32 #80107 by calvin.d
ok still not quite right
this works
net joint-selected-count <= hm2_5i25.0.encoder.00.count
my mpg is still not working but it at least loads nows
also is the mode 2 change issue a known problem ?
C
Time to create page: 0.198 seconds
