Re:pncconf - feature requests
02 Oct 2011 20:20 #13610
Replied by cmorley on topic Re:pncconf - feature requests
Peter can you explain how the 7i76 works? I'm guessing it uses one of the smart serial channels for the 48 I/O points? Which one?
Is the 48 I/O points similar to the 7i64 ? ie the inputs and outputs are designated (they are not GPIO)
02 Oct 2011 22:56 - 02 Oct 2011 23:30 #13614
Replied by PCW on topic Re:pncconf - feature requests
Yes, it has a local SSERIAL device for the 32 inputs and 16 outputs, spindle output voltage, direction, and enable flags and possibly 4 analog inputs (and one analog field voltage pin)
I think it may be difficult to completely support via pncconf unless pncconf can work with data from a
live system since some pins may or may not be there depending in the SSERIAL device mode.
The I/O pin names are Input and Output not sure about the other names yet
Last edit: 02 Oct 2011 23:30 by PCW.
03 Oct 2011 03:39 #13616
Peter do you mean for instance the 7i76 could have different components depending on something like dip switches on the board?
While I'd like PNCconf to read live systems ( and I think Andy is thinking on a mechanism) most things are predictable.
Of course it requires the user to select the right answers, which is unpredictable - but that is no worse then someone hand writing a HAL file.
For the 5i25 the user must know what firmware the board was programmed for and pick that firmware in PNCconf.
Then the user must pick the right sserial daughterboard in the right sserial channel.
then what choices are there in the sserial daughter board?
Do you see one 5i25 firmware / daughter board choice that will be heads above more popular?
Chris M
Chris M
07 Oct 2011 01:09 #13722
Can anyone post a print out of the HAL pins when the 7i76 is connected to the 5i25.
Thanks.
Thanks.
07 Oct 2011 01:16 - 07 Oct 2011 01:19 #13723
Replied by andypugh on topic Re:pncconf - feature requests
Not yet.
(I don't know how to wire up the 7i76 yet)
Last edit: 07 Oct 2011 01:19 by andypugh.
07 Oct 2011 02:27 #13725
The 7I76 can have different HAL pins depending on mode (user settable) and firmware version. Also you can connect an external SSERIAL card to the 7I76 and that card has the same possibilities, though it will show up as a a SSERIAL device
under the main FPGA card.
Only the older SSERIAL cards like the 8I20 and 7I64 have fixed pins, all new cards have modes and new modes with new pins may be added.
11 Oct 2011 15:24 #13835
by ericson
Replied by ericson on topic Re:pncconf - feature requests
hi does anyone know if there is
a firmware for the 7i43 and 7i48
I have EMC2 2.5
I have EMC2 2.5
11 Oct 2011 17:21 #13837
by ericson
I'm sorry I'm a newbie on this
12 Oct 2011 00:01 #13848
by BigJohnT
Replied by BigJohnT on topic Re:pncconf - feature requests
No problem the best way is to start a new thread with a subject that reflects your question. This makes it easier to find at a later date by newbee's.
Time to create page: 0.134 seconds
