Re:pncconf - feature requests
25 Oct 2011 19:19 #14246 by cncbasher
how about adding in a copy configuration , or backup to file
yes i know we can all use the keyboard but once you have a known good configuration , it would be helpful to know you have it all backed up or can copy to a new config for further modification
including all the hidden files
26 Oct 2011 04:20 #14266 by cmorley
actually all you need to do is load the config that you want to copy in pncconf and change the config name on the basic page and then run to the end.
It will save the config with the name you picked.
02 Nov 2011 21:15 #14529 by chimpera
Peter, as a new user what is the best way for me to get the 5i25+7i76 configured with steppers?
Thanks, Ben
03 Nov 2011 02:10 #14534 by PCW
Replied by PCW on topic Re:pncconf - feature requests
Very crudely its:
First download EMC 2.5 (either build from source or get from buildbot)
run the hm2-stepper-5i20 demo from the EMC menu (this will copy the HAL and ini files to your
~/emc/configs/hm2-stepper directory)
Then copy the 5i20.ini in the ~/emc/configs/hm2-stepper directory to a file called 5i25 .ini
now edit this file and delete the firmware parameter in the config='xxxx" line
and change the 5I20 references to 5I25
You now have a very basic set of config files.
You may need to delete some GPIO references in the hm2-stepper.hal file as they are not appropriate to the 5I25
then run the 5i25 hm2-stepper demo from the menu...
03 Nov 2011 13:46 #14548 by BigJohnT
I will have a basic 5i25 + 7i76 config up on my web site later this morning that you can build on. As soon as I'm done I'll post a link. When I'm happy with it I'll add it to 2.5.
03 Nov 2011 15:23 #14550 by BigJohnT
Thanks, Ben
You can get it here for now:
gnipsel.com/shop/emc2/emc2.xhtml
03 Nov 2011 15:38 #14551 by andypugh
"404 File not found
Well it looks like I screwed up a link."
03 Nov 2011 15:48 #14552 by BigJohnT
Well, for some strange reason the upload of the file failed but reported a good upload.
I uploaded it again...
04 Nov 2011 02:06 #14560 by cmorley
John can you post the complete HAL pin list with the 7i76 connected? or do you have two connected?
04 Nov 2011 02:07 #14561 by cmorley
If possible could you show separately the pinouts when using different modes?
Time to create page: 0.175 seconds
