Re:pncconf - feature requests
05 Nov 2011 22:40 #14599 by BigJohnT
That makes sense even to me.
05 Nov 2011 23:06 - 06 Nov 2011 06:53 #14600 by cmorley
yes I suspected this was going to be the answer.
since mode 1 or 2 doesn't add anything that PNCconf configures then mode 0 it is.
It would be trivial for the user to change modes and add the HAL commands for the pins.
Last edit: 06 Nov 2011 06:53 by cmorley.
15 Nov 2011 01:05 #14820 by shasse
If you're still taking feature requests in this thread, here is one: If the custom messages component (thread.gmane.org/gmane.linux.distributions.emc.user/29167) makes it into 2.5, it would be great to have a page for configuring custom messages (message, signal, etc.).
Thanks,
Scott
15 Nov 2011 08:07 #14824 by cmorley
hmmm I'm not sure how that would work.
what would control the messages?
Do you mean you want to connect physical pins to messages?
What kind of messages are you thinking of?
15 Nov 2011 12:35 #14829 by andypugh
even if that does make it in, I think it is perhaps a bit too specialised to be part of pncconf. (It is also not specific to Mesa hardware)
15 Nov 2011 23:56 #14851 by shasse
Fair enough. My use case is for additional messages such as "spindle VFD faulted" that would (in that case, for instance) be hooked to custom named input pins. In my ideal vision, I would be able to generate the config via pncconf, but seems that is not the general goal, which is fine. I can always add in the extra handling in a custom postgui hal sourced file.
Scott
16 Nov 2011 00:27 #14852 by andypugh
It has become a bit more complicated due to the differences between LGPL and GPL.
You can, if you want, install the comp yourself, without recompiling EMC2. You would need to save the code to a file called "message.comp" then comp --install message.comp.
That ought to work on an installed system, even without the sources.
16 Nov 2011 01:21 #14853 by cmorley
well you can somewhat do what you wish with pncconf now.
pncconf can load extra components if you add the commands ( hal component page)
pncconf can have custom signal names just write them in the combo box. (mesa or parport page)
then you just need to add HAL glue code in the custom_hal file.
While your message idea is interesting, I have enough work just keeping up to EMC and mesa changes :)
Chris M
12 Dec 2011 21:14 #15609 by cmorley
Hey Andy could you post the pin outs for the 7i70,7i71 and 7i69 cards?
at your convenience of course.
Thanks Chris M
12 Dec 2011 22:42 #15611 by andypugh
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-00
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-00-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-01
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-01-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-02
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-02-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-03
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-03-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-04
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-04-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-05
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-05-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-06
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-06-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-07
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-07-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-08
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-08-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-09
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-09-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-10
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-10-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-11
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-11-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-12
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-12-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-13
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-13-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-14
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-14-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-15
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-15-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-16
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-16-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-17
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-17-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-18
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-18-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-19
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-19-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-20
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-20-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-21
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-21-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-22
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-22-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-23
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-23-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-24
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-24-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-25
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-25-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-26
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-26-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-27
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-27-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-28
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-28-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-29
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-29-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-30
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-30-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-31
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-31-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-32
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-32-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-33
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-33-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-34
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-34-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-35
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-35-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-36
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-36-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-37
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-37-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-38
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-38-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-39
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-39-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-40
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-40-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-41
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-41-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-42
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-42-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-43
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-43-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-44
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-44-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-45
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-45-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-46
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-46-not
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-47
5 bit OUT FALSE hm2_5i23.0.7i69.0.4.input-47-not
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-00
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-01
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-02
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-03
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-04
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-05
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-06
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-07
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-08
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-09
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-10
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-11
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-12
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-13
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-14
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-15
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-16
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-17
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-18
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-19
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-20
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-21
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-22
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-23
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-24
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-25
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-26
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-27
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-28
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-29
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-30
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-31
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-32
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-33
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-34
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-35
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-36
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-37
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-38
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-39
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-40
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-41
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-42
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-43
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-44
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-45
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-46
5 bit IN FALSE hm2_5i23.0.7i69.0.4.output-47
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-00
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-00-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-01
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-01-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-02
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-02-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-03
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-03-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-04
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-04-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-05
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-05-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-06
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-06-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-07
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-07-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-08
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-08-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-09
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-09-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-10
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-10-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-11
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-11-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-12
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-12-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-13
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-13-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-14
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-14-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-15
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-15-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-16
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-16-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-17
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-17-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-18
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-18-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-19
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-19-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-20
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-20-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-21
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-21-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-22
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-22-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-23
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-23-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-24
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-24-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-25
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-25-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-26
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-26-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-27
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-27-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-28
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-28-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-29
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-29-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-30
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-30-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-31
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-31-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-32
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-32-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-33
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-33-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-34
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-34-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-35
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-35-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-36
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-36-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-37
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-37-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-38
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-38-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-39
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-39-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-40
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-40-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-41
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-41-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-42
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-42-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-43
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-43-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-44
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-44-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-45
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-45-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-46
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-46-not
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-47
5 bit OUT FALSE hm2_5i23.0.7i70.0.6.input-47-not
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-00
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-01
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-02
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-03
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-04
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-05
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-06
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-07
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-08
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-09
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-10
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-11
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-12
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-13
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-14
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-15
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-16
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-17
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-18
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-19
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-20
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-21
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-22
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-23
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-24
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-25
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-26
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-27
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-28
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-29
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-30
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-31
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-32
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-33
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-34
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-35
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-36
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-37
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-38
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-39
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-40
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-41
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-42
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-43
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-44
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-45
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-46
5 bit IN FALSE hm2_5i23.0.7i71.0.7.output-47
Time to create page: 0.238 seconds
