Re:pncconf - feature requests
13 Dec 2011 00:18 #15617 by cmorley
Thanks Andy.
Are all the sserial pin names lowercase now?
13 Dec 2011 00:44 #15619 by andypugh
Yes.
13 Dec 2011 00:56 #15620 by PCW
Replied by PCW on topic Re:pncconf - feature requests
Note that the number before the input or output is the sserial channel number...
19 Feb 2012 19:35 #17839 by cmorley
I was toying with playing sound samples in python when i remembered how difficult it was to test my
limit switches on my large lathe because i could not see the screen.
I could make a test screen that plays sounds (and an LED display), based on the limit/home switch that is closed.
Does this sound useful to anyone else?
19 Feb 2012 19:38 #17840 by cmorley
I also request anyone who gets their hands on a 5i25/7i77 board combo to post the HAL pin list here please.
i will incorporate it into PNCconf - I think the 5i25 is going to be very popular.
19 Feb 2012 22:30 #17848 by Rick G
I think adding sound output on a large machine is good idea.
I used "beep" on my larger cnc router for the touch off function when I had the joypad several feet away from the screen where the material was and wanted to confirm what was going on.
Rick G
22 Feb 2012 22:18 #17950 by PCW
freeby.mesanet.com/7i77+7i73.pins
freeby.mesanet.com/7i77+7i73.parms
22 Feb 2012 22:33 #17952 by cncbasher
yes i'll vote for it Chris
the number of times when you cant see the screen or just out of view , when you go to test a limit/home sw
or infact any iopin change an audible or or visual would be good , same for hal configuration too
23 Feb 2012 00:15 #17956 by BigJohnT
I got mine yesterday, I'll plug it in tomorrow and post the info for you.
23 Feb 2012 17:00 - 23 Feb 2012 17:00 #17965 by BigJohnT
Chris,
Here you go... I had a bit of a time getting it up and running, didn't seem to like the setp hm2_5125.0.watchdog.timeout_ns 10000000 line.
File Name: 5i25_7i77_...ters.txt
File Size:22 KB
Last edit: 23 Feb 2012 17:00 by BigJohnT.
Time to create page: 0.250 seconds
