LinuxCNC 2.9 RPi - PNCconf error
12 Jul 2022 21:44 #247191
by Gifix
LinuxCNC 2.9 RPi - PNCconf error was created by Gifix
13 Jul 2022 03:33 #247209
Replied by cmorley on topic LinuxCNC 2.9 RPi - PNCconf error
try running from a terminal like this:
LC_ALL=C pncconf
Sometimes different languages present problems.
LC_ALL=C pncconf
13 Jul 2022 07:47 #247214
by Gifix
Replied by Gifix on topic LinuxCNC 2.9 RPi - PNCconf error
Unfortunately this didn't work. I've changed system language to english but that either don't work.
Still the same error.
- Thank you received: 5944
13 Jul 2022 12:01 #247228
Replied by tommylight on topic LinuxCNC 2.9 RPi - PNCconf error
Did you try changing locale to UTF8 ?
13 Jul 2022 19:48 #247248
by Gifix
Yes, still the same error...
15 Jul 2022 09:50 #247361
by Gifix
I've manage to go through configuration in pncconf without error, by disabling advanced options pages at the beginning of configuration.
Currently I am running system on M.2 ssd connected via usb, so I made fresh system on sd card and it work without problem. Later I'll try to make fresh system on ssd and see if then it will work.
28 Mar 2023 23:02 #267738
by mor
Replied by mor on topic LinuxCNC 2.9 RPi - PNCconf error
Any suggestions for resolving this issue without disabling Advanced Options? I'm trying to use "pncconf -d debug" and need the advanced options to enable board discovery.
Thanks in advance!
Thanks in advance!
29 Mar 2023 00:54 #267744
by phillc54
Replied by phillc54 on topic LinuxCNC 2.9 RPi - PNCconf error
I have tried PNCconf on 2.9 and I am unable to duplicate this error. I haven't changed anything from the defaults other than enabling Show Advanced Option Pages
29 Mar 2023 00:56 #267745
by mor
I've tried both 2.9 and 2.10 and always have the same issue as the OP.
I'm using RPI 4 with 64-bit PREEMPT_RT and built 2.9 from source.
29 Mar 2023 01:02 #267746
by phillc54
I tried on a Debian 11 arm64 VM (iMac host) with 2.9 built from source. I have a RPI 64 somewhere here, I find it and give it a try.
The following user(s) said Thank You: mor
Time to create page: 0.103 seconds
