requesting help with 7i80DB-16 and C10 breakout board
23 Jan 2024 20:39 #291464
by gbsd86
requesting help with 7i80DB-16 and C10 breakout board was created by gbsd86
Trying to duplicate PP setup to avoid re-wiring.
Have configured with Pncconf. Linuxcnc will not open.
Using MB ethernet to 7i80. Can ping board.
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
64 bytes from 192.168.1.121: icmp_seq=47 ttl=64 time=0.695 ms
64 bytes from 192.168.1.121: icmp_seq=48 ttl=64 time=0.404 ms
64 bytes from 192.168.1.121: icmp_seq=49 ttl=64 time=0.409 ms
Have included the problem reports. Report1 and info1 are with WiFi card enabled.
2nd set is with the WiFi card disconnected.
- Thank you received: 5944
23 Jan 2024 20:51 #291465
Omit or delete the above mentioned line in the GrizzlyNu.hal
Replied by tommylight on topic requesting help with 7i80DB-16 and C10 breakout board
Note: Using POSIX realtime
./GrizzlyNu.hal:22: parameter or pin 'hm2_7i80.0.dpll.01.timer-us' not found
63925
Stopping realtime threads
Unloading hal components
23 Jan 2024 23:11 #291475
by gbsd86
Replied by gbsd86 on topic requesting help with 7i80DB-16 and C10 breakout board
Thanks. It still errors out.Including new report, hal and ini files.
23 Jan 2024 23:13 - 23 Jan 2024 23:16 #291476
by gbsd86
missing report file.
# Generated by PNCconf at Tue Jan 23 05:23:48 2024
# Using LinuxCNC version: Master (2.9)
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=0 num_pwmgens=0 num_stepgens=10"
setp [HMOT](CARD0).watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.a,pid.s
addf [HMOT](CARD0).read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.a.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf [HMOT](CARD0).write servo-thread
setp [HMOT](CARD0).stepgen.timer-number 1
# external output signals
# external input signals
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.x.maxerror 0.000500
net x-index-enable => pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# Step Gen signals/setup
setp [HMOT](CARD0).stepgen.01.dirsetup [JOINT_0]DIRSETUP
setp [HMOT](CARD0).stepgen.01.dirhold [JOINT_0]DIRHOLD
setp [HMOT](CARD0).stepgen.01.steplen [JOINT_0]STEPLEN
setp [HMOT](CARD0).stepgen.01.stepspace [JOINT_0]STEPSPACE
setp [HMOT](CARD0).stepgen.01.position-scale [JOINT_0]STEP_SCALE
setp [HMOT](CARD0).stepgen.01.step_type 0
setp [HMOT](CARD0).stepgen.01.control-type 1
setp [HMOT](CARD0).stepgen.01.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.01.maxvel [JOINT_0]STEPGEN_MAXVEL
setp [HMOT](CARD0).stepgen.01.direction.invert_output true
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output => [HMOT](CARD0).stepgen.01.velocity-cmd
net x-pos-fb <= [HMOT](CARD0).stepgen.01.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => [HMOT](CARD0).stepgen.01.enable
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
# AXIS Y JOINT 1
setp pid.y.Pgain [JOINT_1]P
setp pid.y.Igain [JOINT_1]I
setp pid.y.Dgain [JOINT_1]D
setp pid.y.bias [JOINT_1]BIAS
setp pid.y.FF0 [JOINT_1]FF0
setp pid.y.FF1 [JOINT_1]FF1
setp pid.y.FF2 [JOINT_1]FF2
setp pid.y.deadband [JOINT_1]DEADBAND
setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror 0.000500
net y-index-enable => pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-pos-fb => pid.y.feedback
net y-output <= pid.y.output
setp [HMOT](CARD0).stepgen.02.dirsetup [JOINT_1]DIRSETUP
setp [HMOT](CARD0).stepgen.02.dirhold [JOINT_1]DIRHOLD
setp [HMOT](CARD0).stepgen.02.steplen [JOINT_1]STEPLEN
setp [HMOT](CARD0).stepgen.02.stepspace [JOINT_1]STEPSPACE
setp [HMOT](CARD0).stepgen.02.position-scale [JOINT_1]STEP_SCALE
setp [HMOT](CARD0).stepgen.02.step_type 0
setp [HMOT](CARD0).stepgen.02.control-type 1
setp [HMOT](CARD0).stepgen.02.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.02.maxvel [JOINT_1]STEPGEN_MAXVEL
setp [HMOT](CARD0).stepgen.02.direction.invert_output true
net y-pos-cmd <= joint.1.motor-pos-cmd
net y-vel-cmd <= joint.1.vel-cmd
net y-output => [HMOT](CARD0).stepgen.02.velocity-cmd
net y-pos-fb <= [HMOT](CARD0).stepgen.02.position-fb
net y-pos-fb => joint.1.motor-pos-fb
net y-enable <= joint.1.amp-enable-out
net y-enable => [HMOT](CARD0).stepgen.02.enable
net y-home-sw => joint.1.home-sw-in
net y-neg-limit => joint.1.neg-lim-sw-in
net y-pos-limit => joint.1.pos-lim-sw-in
# AXIS Z JOINT 2
setp pid.z.Pgain [JOINT_2]P
setp pid.z.Igain [JOINT_2]I
setp pid.z.Dgain [JOINT_2]D
setp pid.z.bias [JOINT_2]BIAS
setp pid.z.FF0 [JOINT_2]FF0
setp pid.z.FF1 [JOINT_2]FF1
setp pid.z.FF2 [JOINT_2]FF2
setp pid.z.deadband [JOINT_2]DEADBAND
setp pid.z.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror 0.000500
net z-index-enable => pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
setp [HMOT](CARD0).stepgen.03.dirsetup [JOINT_2]DIRSETUP
setp [HMOT](CARD0).stepgen.03.dirhold [JOINT_2]DIRHOLD
setp [HMOT](CARD0).stepgen.03.steplen [JOINT_2]STEPLEN
setp [HMOT](CARD0).stepgen.03.stepspace [JOINT_2]STEPSPACE
setp [HMOT](CARD0).stepgen.03.position-scale [JOINT_2]STEP_SCALE
setp [HMOT](CARD0).stepgen.03.step_type 0
setp [HMOT](CARD0).stepgen.03.control-type 1
setp [HMOT](CARD0).stepgen.03.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.03.maxvel [JOINT_2]STEPGEN_MAXVEL
setp [HMOT](CARD0).stepgen.03.direction.invert_output true
net z-pos-cmd <= joint.2.motor-pos-cmd
net z-vel-cmd <= joint.2.vel-cmd
net z-output => [HMOT](CARD0).stepgen.03.velocity-cmd
net z-pos-fb <= [HMOT](CARD0).stepgen.03.position-fb
net z-pos-fb => joint.2.motor-pos-fb
net z-enable <= joint.2.amp-enable-out
net z-enable => [HMOT](CARD0).stepgen.03.enable
net z-home-sw => joint.2.home-sw-in
net z-neg-limit => joint.2.neg-lim-sw-in
net z-pos-limit => joint.2.pos-lim-sw-in
# AXIS A JOINT 3
setp pid.a.Pgain [JOINT_3]P
setp pid.a.Igain [JOINT_3]I
setp pid.a.Dgain [JOINT_3]D
setp pid.a.bias [JOINT_3]BIAS
setp pid.a.FF0 [JOINT_3]FF0
setp pid.a.FF1 [JOINT_3]FF1
setp pid.a.FF2 [JOINT_3]FF2
setp pid.a.deadband [JOINT_3]DEADBAND
setp pid.a.maxoutput [JOINT_3]MAX_OUTPUT
setp pid.a.error-previous-target true
setp pid.a.maxerror 0.000500
net a-index-enable => pid.a.index-enable
net a-enable => pid.a.enable
net a-pos-cmd => pid.a.command
net a-pos-fb => pid.a.feedback
net a-output <= pid.a.output
setp [HMOT](CARD0).stepgen.04.dirsetup [JOINT_3]DIRSETUP
setp [HMOT](CARD0).stepgen.04.dirhold [JOINT_3]DIRHOLD
setp [HMOT](CARD0).stepgen.04.steplen [JOINT_3]STEPLEN
setp [HMOT](CARD0).stepgen.04.stepspace [JOINT_3]STEPSPACE
setp [HMOT](CARD0).stepgen.04.position-scale [JOINT_3]STEP_SCALE
setp [HMOT](CARD0).stepgen.04.step_type 0
setp [HMOT](CARD0).stepgen.04.control-type 1
setp [HMOT](CARD0).stepgen.04.maxaccel [JOINT_3]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.04.maxvel [JOINT_3]STEPGEN_MAXVEL
setp [HMOT](CARD0).stepgen.04.direction.invert_output true
net a-pos-cmd <= joint.3.motor-pos-cmd
net a-vel-cmd <= joint.3.vel-cmd
net a-output => [HMOT](CARD0).stepgen.04.velocity-cmd
net a-pos-fb <= [HMOT](CARD0).stepgen.04.position-fb
net a-pos-fb => joint.3.motor-pos-fb
net a-enable <= joint.3.amp-enable-out
net a-enable => [HMOT](CARD0).stepgen.04.enable
net a-home-sw => joint.3.home-sw-in
net a-neg-limit => joint.3.neg-lim-sw-in
net a-pos-limit => joint.3.pos-lim-sw-in
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable => pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.2.is-homed
net axis-select-a halui.axis.a.select
net jog-a-pos halui.axis.a.plus
net jog-a-neg halui.axis.a.minus
net jog-a-analog halui.axis.a.analog
net a-is-homed halui.joint.3.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request <= iocontrol.0.tool-change
net tool-change-confirmed => iocontrol.0.tool-changed
net tool-number <= iocontrol.0.tool-prep-number
# ---Use external manual tool change dialog---
net tool-change-request => hal_manualtoolchange.change
net tool-change-confirmed <= hal_manualtoolchange.changed
net tool-number => hal_manualtoolchange.number
# ---ignore tool prepare requests---
loadrt hostmot2
# AXIS X JOINT 0
# AXIS Y JOINT 1
# AXIS Z JOINT 2
# AXIS A JOINT 3
# SPINDLE
Last edit: 23 Jan 2024 23:16 by gbsd86. Reason: file didn't attach.
24 Jan 2024 00:35 #291480
Replied by PCW on topic requesting help with 7i80DB-16 and C10 breakout board
The statement:
Will cause an error if there is no DPLL present in the firmware.
Also your ping times are very long, If you have an Intel Ethernet
chip on the host, make sure you disable IRQ coalescing as described
in the hm2_eth manual page:
man hm2_eth
man hm2_eth
25 Jan 2024 01:00 #291562
by gbsd86
Where to find this?
How to know if this the case?
Where to find this?
25 Jan 2024 01:12 #291563
I copy-pasted it from your hal file.
25 Jan 2024 22:32 - 25 Jan 2024 22:33 #291630
by gbsd86
Appoligies for that. I looked for that line, did a search. Missed it somehow.
Took that line out. Now:
/GrizzlyNu.hal:55: parameter or pin 'hm2_7i80.0.stepgen.01.dirsetup' not found
Last edit: 25 Jan 2024 22:33 by gbsd86. Reason: add files
26 Jan 2024 00:15 #291633
Yes, that's because the firmware currently installed
in the 7I80DB-16 has no stepgen hardware
(it looks like a configuration for 4x7I77s)
What daughterboard are you using with the 7I80DB?
This determines the appropriate firmware so the
7I80DB pinout matches your daughterboard.
26 Jan 2024 00:56 #291634
by gbsd86
PnCConf lists 7I80DB - internal data
7I76x2 is the only selection
I am trying to duplicate my parallel port pin to avoid rewiring.
I have not loaded a bit file into the board. I assumed the PnCConf software did that.
Under the assumption the 7I80DB could be configured the same as the parallel port,
I am not using a daughter board, using a C10 breakout board: FEATURES:
- IEEE 1284 Standard compatible.
- PULL-UP or PULL-DOWN selection for inputs.
- Buffered inputs and outputs.
- Bidirectional pins 2-9.
- Output pins 1, 2, 3, 4, 5, 6, 7, 8, 9, 14, 16, 17. Or 1, 14, 16, 17.
- Input pins 10, 11, 12, 13, 15. Or 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 15.
- Input and output pins with the close-by ground or +5vdc connections
- External Enable Pin (EN).
- Works directly with popular CNC hardware and software.
- All TTL 5VDC signals.
- Screw-On connections for all terminals.
- Status LEDs for enable.
Time to create page: 0.193 seconds
