stepgen by pncconf
27 Mar 2011 22:28 - 27 Mar 2011 22:29 #8174
by andradela
stepgen by pncconf was created by andradela
Hello guys, today I start some tests with my 7i43's card, i create a simple project with 3 stepgen only, so when i use test/tune/axis i have no signal in the 7i43 output, but when I use the sample "hm2 stepper" it works. Why my project doesn't work?
Last edit: 27 Mar 2011 22:29 by andradela.
27 Mar 2011 23:19 #8177
Replied by cmorley on topic Re:stepgen by pncconf
What version of EMC are you using?
Can you post your files?
28 Mar 2011 21:38 #8231
by andradela
Replied by andradela on topic Re:stepgen by pncconf
My emc version is 2.4.6
28 Mar 2011 21:52 #8232
in the file teste.hal remove lines 11 and 12:
loadrt abs names=
loadrt lowpass names=
and try that.
Also could you post the pncconf file
should find it in /emc2/configs/teste.pncconf
loadrt abs names=
and try that.
28 Mar 2011 22:26 - 28 Mar 2011 22:27 #8233
by andradela
OK follow the file teste.pncconf
Last edit: 28 Mar 2011 22:27 by andradela.
28 Mar 2011 22:29 #8234
by andradela
what are these lines?
28 Mar 2011 22:36 #8235
absolute and lowpass components are used when displaying spindle speed in a pyvcp panel.
pncconf incorrectly added them when not needed (that why there are no names attached)
I'm pretty sure this error was found and fixed but has not been released yet.
29 Mar 2011 18:03 #8261
by andradela
I removed the lines and did a test it didn't work, just works with the sample.
30 Mar 2011 00:22 #8270
Can you give more info.
Does EMC give an error ( if yes what is it) or is there just no output on the 7i43?
30 Mar 2011 00:30 #8271
hmm I checked the logs and there was another problem with the 7i43 with pncconf which had to do with the connector numbering being wrong.
can you check that your signals are not on the other connector.
