stepgen by pncconf
30 Mar 2011 21:00 - 30 Mar 2011 21:05 #8299
by andradela
Replied by andradela on topic Re:stepgen by pncconf
I creat a new configuration with 4 axis and it worked, the difference that i find was the outputs to axis Y and B is changed, another problem is when i run a sample cnc g code, the program stop with a message "joint 2 following error" I read some thing about, this happen when i use encoder it's ok? but this is not my case.
I will send the file.hal.
Last edit: 30 Mar 2011 21:05 by andradela.
31 Mar 2011 06:04 #8310
Replied by cmorley on topic Re:stepgen by pncconf
It is possible to get a following error with a stepper system. If you ask the motion controller to accelerate faster then the stepgen can (within it's settings),
then you'll get a following error.
Can you post all the files.
including the pncconf file
31 Mar 2011 06:19 #8311
by andradela
When i use the hm2 stepper it works normally.
31 Mar 2011 06:46 #8312
When you post all your files I will take a closer look.
31 Mar 2011 21:35 #8348
by andradela
Follow all the files.
01 Apr 2011 00:38 - 01 Apr 2011 00:39 #8360
Just looking at your config... you have very tight following error settings...
.0005 of a mm thats about .00002 thousands
Do you really need that tight of following error?
your minimum step distance is .0025 mm so I think ya gotta increase the feed speed following error and rapid speed following error.
I bet the y axis doesn't follow error - its settings are much larger.
try changing those settings.
Pncconf kinda caters to inch measurements when your talking about defaults.
Last edit: 01 Apr 2011 00:39 by cmorley.
02 Apr 2011 07:35 - 02 Apr 2011 07:36 #8386
by andradela
Ok, Is just my first time with the pncconf, I'm still learning to use it, I will change that parameters and tell you if ok.
Last edit: 02 Apr 2011 07:36 by andradela.
Time to create page: 0.133 seconds
