Check Axis
10 Dec 2012 21:52 #27516 by Rick G
Check Axis was created by Rick G
Here is a simple NGCGUI to exorcise and check an axis.
The idea is to put as much stress as possible with an air cut on an axis by having it rapidly change directions in ever smaller moves.
You set the axis, the start and stop points, the amount to reduce each move, the rapid speed and the slow speed to the check location.
There is another sub I use that moves 2 axis together I will post later.
Rick G
Time to create page: 0.059 seconds
