Radial Slot Subroutine
- vederstein
- Thank you received: 3
24 May 2013 01:38 #34606
by vederstein
Radial Slot Subroutine was created by vederstein
I had some time off from work, so I whipped this up. Use at your own risk. If you find issues, please let me know:
Known issues:
*Choosing an arc radius too small can cause weird paths.
*I'm not sure the transition from the side arcs to end end arcs is perfect yet.
*To flip the curve from convex to concave, switch P1 and P2 coordinates.
Have fun
...ved.
Known issues:
Have fun
...ved.
The following user(s) said Thank You: Rick G
24 May 2013 03:05 #34611
by BigJohnT
Replied by BigJohnT on topic Radial Slot Subroutine
Thanks for sharing.
JT
JT
24 May 2013 03:14 #34612
by dgarrett
Replied by dgarrett on topic Radial Slot Subroutine
nice work -- thanks
There are also some arc gcode programs in the distribution (v2.5+ probably):
nc_files/ngcgui_lib/arc1.ngc and nc_files/ngcgui_lib/arc2.ngc
These use cutter radius compensation based on tool table tool diameter and provide additional methods for specifying an arc
24 May 2013 18:11 - 24 May 2013 18:13 #34633
by Rick G
Replied by Rick G on topic Radial Slot Subroutine
Looks good, I will have to give it a try. Thanks for sharing.
I use something similar as far as calculations for multiple radial arcs and use G10 to set their locations.
Rick G
G10 L2 P#<_pc:1> R#<start_angle> (rotate for start angle)
Rick G
Last edit: 24 May 2013 18:13 by Rick G.
Time to create page: 0.144 seconds
