updated usefull-subroutines
- somenewguy
17 Nov 2013 01:53 - 17 Nov 2013 02:09 #40873
by somenewguy
updated usefull-subroutines was created by somenewguy
I was playing around and modifiedthe usefull-subroutines.ngc that ships with linuxCNC. I updated it to not require you to pass it tool diameter since that is already known to the machine, and allow you to pass it a %DOC rather than have it hard coded to 50%. I am very new to github, and have never contributed to a real project so I don't want to mess anything up, but I think it is ready to make a pull request on github if that is the best way to try an incorperate the changes
Last edit: 17 Nov 2013 02:09 by BigJohnT. Reason: This is a G rated Forum
18 Nov 2013 20:49 #40935
Replied by andypugh on topic updated usefull-subroutines
There is a new manual page which might help: linuxcnc.org/docs/2.5/html/code/Contributing-to-LinuxCNC.html
The following user(s) said Thank You: somenewguy
- somenewguy
20 Nov 2013 11:18 #40992
by somenewguy
Replied by somenewguy on topic updated usefull-subroutines
thank you, I will read that while the printer warms up
- somenewguy
31 Dec 2013 04:46 #42206
by somenewguy
started working on my own library for ngcgui after discovering how easy it is to do, i figured why not go the whole ten yards
