- GCode and Part Programs
- O Codes (subroutines) and NGCGUI
- rigid tapping fail advice and "discriminant" err
- skunkworks
- Thank you received: 148
31 Jul 2015 02:57 #61055
by skunkworks
Replied by skunkworks on topic rigid tapping fail advice and "discriminant" err
31 Jul 2015 05:11 - 31 Jul 2015 05:39 #61057
by tome
Yeah, I was looking at those. By the way, how can that wheel do quadrature? I thought there had to be two sets of holes that were spaced 90 degrees out of phase? Or, can you have another optical emitter that is on a non-hole while the first emitter is on a hole?
-Tom
ps: I see that this unit (below) works with that disk to provide quadrature, so obviously one optical emitter/pickup inside the EM1 module is 90 degrees out of phase of the other. How does one do that on a home made one, that is, if I add another optical pickup to my existing wheel how to I ensure they two are 90 degrees out of phase?
www.usdigital.com/products/encoders/incr...ules/EM1#description
Replied by tome on topic rigid tapping fail advice and "discriminant" err
This maybe?
www.usdigital.com/products/encoders/incr...tary/disks/HUBDISK-2
sam
-Tom
Last edit: 31 Jul 2015 05:39 by tome.
31 Jul 2015 08:59 #61059
by drogge
Replied by drogge on topic rigid tapping fail advice and "discriminant" err
Tom, You would need 5 wires; power, ground, A, B and Index.
31 Jul 2015 09:05 #61060
by drogge
Unless you're good you have to make at least one of the pickups adjustable and then set the phase of the signals using a scope.
Drew
ps: I see that this unit (below) works with that disk to provide quadrature, so obviously one optical emitter/pickup inside the EM1 module is 90 degrees out of phase of the other. How does one do that on a home made one, that is, if I add another optical pickup to my existing wheel how to I ensure they two are 90 degrees out of phase?This maybe?
sam
Drew
31 Jul 2015 20:13 #61066
Replied by andypugh on topic rigid tapping fail advice and "discriminant" err
Just don't put the sensors 180 degrees out of phase. Or you will feel stupid.
Don't ask me how I know this.
Time to create page: 0.656 seconds
