Checking the pin status with if or M66 ?
16 Aug 2015 19:43 - 16 Aug 2015 19:44 #61434 by bladekel
Hi my friends
I need to learn how to use "if" by checking the parallel port's pin's status.
I am trying to write a line such as ;
If (parallel port pin 10 == true )
Codes here....
Endif
And i think this lines cannbe done by m66, but i couldnt.
I define pins 10 as p0 and i write ;
M66 P0 L3 Q5 to wait the high input for 5 secs.
After 5 seconds it continues the rests of the code. But i need not to continue.
Can anyone help me with this issue?
Last edit: 16 Aug 2015 19:44 by bladekel.
16 Aug 2015 19:52 #61435 by ArcEye
If you search 'pin value gcode' in the left hand search bar, you will get these amoungst others
linuxcnc.org/index.php/english/forum/10-...ing-hal-pin-from-ngc
linuxcnc.org/index.php/english/forum/22-...a-to-g-code-variable
The following user(s) said Thank You: bladekel
Time to create page: 0.059 seconds
