Use A-axis to mill a radial feature.
07 Aug 2016 22:38 #78463
by cncnoel
Replied by cncnoel on topic Use A-axis to mill a radial feature.
Hi Rick & Tommy
Yes I did used to have NGCGUI_PREAMBLE set for a while, but found when I put the plasma torch on the machine, I found I used a different preamble setup. As a result I have migrated to using 2 preamble files o<preamble> and o<plasma>, Any better ideas out there?.
Yet to set up my A axis, I have the Gecko drive and servomotor / encoder ready, and the machine is wired for it (now), just need to build the rotary bed. Then it will be code-wars as I have yet another axis to crash!
Regards
Noel
Regards
Noel
- Thank you received: 5922
08 Aug 2016 00:52 #78468
Replied by tommylight on topic Use A-axis to mill a radial feature.
Easy, if you intend to use that 4th axis with the plasma, you just need to make another config with the setings, except in this case substitute Y axis (or X axis, depending on your setup) with A axis. So instead of moving Y axis you move A axis. Just be vary of the perimeter of the pipe you are cutting.
I have done this plenty, no need for 4 axis CAM software, and a lot easier to draw. Made some pretty complicated oval tube cuts with it.
Regards,
Tom
P.S. i think i mentioned using inkscape with gcodetools, as it has all the preamble already in.
Regards,
Tom
Time to create page: 0.144 seconds
