Subroutine GUI
04 Apr 2011 15:02 #8489
by piasdom
Replied by piasdom on topic Re:Subroutine GUI
got error
Debug file information:
custom.hal:6: Pin 'halui.mdi-command-00' does not exist
16078
16078
04 Apr 2011 15:11 #8490
by BigJohnT
Replied by BigJohnT on topic Re:Subroutine GUI
Sorry, that needs to go in your custom_postgui.hal
04 Apr 2011 15:14 - 04 Apr 2011 15:31 #8492
by piasdom
NP, REALLY appreciate the time and help !
custom_postgui.hal:6: Pin 'halui.mdi-command-00' does not exist
can i add pin(s) by
....... ....halui-mdi-command-01 .......
....... ....halui-mdi-command-02 .......
....... ....halui-mdi-command-03 .......
an so forth ?
as long as i have 'pins'
can i add pin(s) by
an so forth ?
Last edit: 04 Apr 2011 15:31 by piasdom.
04 Apr 2011 15:31 #8493
by BigJohnT
Ah, your missing the last bit to the puzzle.
In your ini file in the [HAL] section add
HALUI = halui
HALUI = halui
04 Apr 2011 15:36 - 04 Apr 2011 15:42 #8494
by piasdom
THANKS
so they're three files i need to work with to get buttons ?
this gives me a great start.....THANKS
and can i add buttons(s) by
an so forth ?
i'm trying to get it to home(i think of homing as zeroing XYZ)
without moving the table. is this possible with pyvcp ?
THANKS
an so forth ?
Last edit: 04 Apr 2011 15:42 by piasdom.
04 Apr 2011 15:38 #8495
by BigJohnT
Yes, as far as I know that is the way. Just remember to add the MDI command into the [HALUI] section of the ini. Let me know how it works.
04 Apr 2011 15:58 #8496
by piasdom
cool i will.
can i get an example somewhere of more then on button ?
i have this in custom_postgui.hal;
# MDI commands
# rapid to home button
net remote-rapid-home halui.mdi-command-00 <= pyvcp.rapid-to-home
# home all button
net remote-home-all halui.mdi-command-01 <= pyvcp.home-all
but it tells me pyvcp.home-all doesn't exist.
i'm guessing i'm naming something in the second button wrong.
i have this in xml;
<pyvcp>
<button>
<halpin>"home-all"</halpin>
<text>"Home All"</text>
<font>('Helvetica',10)</font>
</button>
</pyvcp>
if i could see the pin naming format better, it would help.
# MDI commands
# home all button
i have this in xml;
<pyvcp>
<button>
</button>
</pyvcp>
04 Apr 2011 16:03 - 04 Apr 2011 16:04 #8497
by BigJohnT
the <pyvcp> </pyvcp> tags need to only be in the .xml file once and wrap around all the rest.
As far as I know there is no G Code that will cause a "home all" to happen. What did you have in mind there?
Last edit: 04 Apr 2011 16:04 by BigJohnT.
04 Apr 2011 16:15 #8498
by piasdom
when i start emc, i have to home(zero) each axis.
i have to click on each one - x then "home axis", y "home axis", z "home axis"
i'm trying to be able to home all at once.
i did something before(in ini i think) that gave me a "home all" button on the left, instead of home.
but then i couldn't home each axis individually. so when i zero X, y and z had to be at zero. which is
not possible with me.(don't think it's possible for ANYONE:)
04 Apr 2011 16:21 #8499
by BigJohnT
If you don't have home switches you can't get the "Home All" button on the left.
However now that you have halui loaded some other options show up.
www.linuxcnc.org/component/option,com_ku...o,8498/lang,english/
I assume the halui.home-all pin requires you to have home switches but who knows give it a try.
change your
# home all button
to
# home all button
net remote-home-all halui.home-all <= pyvcp.home-all
and see what happens when you press it.
change your
# home all button
to
# home all button
Time to create page: 0.097 seconds
