Subroutine GUI
05 Apr 2011 15:05 #8577
by piasdom
Replied by piasdom on topic Re:Subroutine GUI
COOL
05 Apr 2011 15:19 #8579
Replied by andypugh on topic Re:Subroutine GUI
piasdom wrote:
You can't do that, that pin name is already taken. You need a new, unique, chosen-by-you name for the HAL pin that belongs to the GUI button.<halpin>"halui.joint.0.home"</halpin>
Bear in mind that this tag only sets the text that appears on the button, not the name of the hal pin....<text>"Home X"</text>
... So this won't work.net home-x halui.joint.0.home pyvcp.home-x
05 Apr 2011 15:27 #8580
by BigJohnT
Replied by BigJohnT on topic Re:Subroutine GUI
Andy,
You can actually have a pyvcp hal pin name the same as other pins as it evaluates out to pyvcp.halui.joint.0.home so it becomes unique and a valid pin even if it doesn't make sense to do so.
05 Apr 2011 15:31 #8583
BigJohnT wrote:
While we are at it, you can add things randomly to the INI file, and you will be able to access them in hal with [STANZA]ATTRIBUTE, but the rest of EMC2 will pay no attention.
Ah, yes. Good point.You can actually have a pyvcp hal pin name the same as other pins as it evaluates out to pyvcp.halui.joint.0.home so it becomes unique and a valid pin even if it doesn't make sense to do so.
05 Apr 2011 15:39 #8585
by BigJohnT
And that is not mentioned anywhere that I know of yet...
05 Apr 2011 15:43 #8586
Perhaps I ought to make sure that it is true first, then
05 Apr 2011 15:49 #8587
by BigJohnT
I noticed in the hm2 configs but didn't think of it till now...
Time to create page: 0.200 seconds
