Lathe OD Turning
12 Dec 2010 15:19 #5989
by Rick G
Replied by Rick G on topic Re:OD Turning Subroutine
and
12 Dec 2010 15:19 #5990
by Rick G
again
12 Dec 2010 15:34 #5991
by BigJohnT
Replied by BigJohnT on topic Re:OD Turning Subroutine
Ok, I'm working on it. Looks like the subroutine for the profile will have to be numbers only to pass it to the main subroutine... I think.
12 Dec 2010 17:44 #5993
by Rick G
John,
Now that the power is back on...
That is what I believe, however naming the files with a number is not the end of the world.
I am also in the process of adding a safe X travel dimension and a safe Z position.
I need to head back out to the shop now but I will research this when I get back.
It would also be neat to automate some of dimensions such as the smallest diameter.
It seems this type of operation could also be used on a mill.
Rick
Rick
12 Dec 2010 18:06 #5994
by BigJohnT
Well, that didn't work out like I wanted. So I have the g71.ngc subroutine taking in all the parameters and handling the work offsets and all the logic. In the loop it just calls a subroutine called "profile". This can have the actual profile or just call the profile.
12 Dec 2010 22:07 #5997
by Rick G
John,
I think I have it working calling a numbered file. I will post in the morning after I give it a test.
Rick G
Rick G
13 Dec 2010 10:39 #6001
by Rick G
Morning John,
This seems to work on my machine in demo mode with subroutine calling a numbered file. The numbered file must be a sub also. I need to add safe travel positions and clean things up but I think it is on it's way. I have a busy week at work but will try to work on this later in the week.
Thanks,
Rick
Thanks,
Rick
13 Dec 2010 10:40 #6002
by Rick G
and
13 Dec 2010 16:38 #6005
by BigJohnT
My internet has been down since last night...
I'll give it a try as soon as I'm done with this job on the lathe.
25 Mar 2012 13:12 - 25 Mar 2012 13:13 #18781
by BigJohnT
Here is the latest version of OD that I'm using.
Last edit: 25 Mar 2012 13:13 by BigJohnT.
