Mocca; hal file with button command
27 Jun 2011 20:23 #10905
by michel45
Mocca; hal file with button command was created by michel45
Hello,
I want to order the light of my machine directly from the mocca screen. How to link a button (button8 for example) with the light output. In
The party program that should go with Lazarus. The name is "moc.button.8"?
My file hal
# Eclairage (pin 25 OUT)
setp hm2_5i22.0.gpio.025.is_output TRUE
net eclairage-on <= iocontrol.0.moc.button.8 ?????
net eclairage-on => hm2_5i22.0.gpio.025.out
For now nothing works , but I do not despair
thank you to him who gives me an idea.
Michel
My file hal
Michel
27 Jun 2011 21:54 #10907
Replied by andypugh on topic Re:Mocca; hal file with button command
If you comment out the new lines, then start mocca, then, in a terminal window type:
halcmd show pin
That should give you a list of all the pins, hopefully giving the full correct name of the mocca button pin.
(put the output on pastebin.org perhaps)
halcmd show pin
28 Jun 2011 08:19 #10916
by michel45
Replied by michel45 on topic Re:Mocca; hal file with button command
28 Jun 2011 09:23 - 28 Jun 2011 09:24 #10917
michel45 wrote:
Your pin listing shows that there is no pin called iocontrol.0.moc.buttton.8, your code needs to be:
I am not sure if the mocca buttons latch, if you find that the light is on only when the button is being pressed, then I can show you how to add some more HAL components to make it work properly.
net eclairage-on moc.button.8 => hm2_5i22.0.gpio.025.out
Last edit: 28 Jun 2011 09:24 by andypugh.
28 Jun 2011 12:47 #10923
by michel45
Hello,
thank you for your help
I tried this solution but "moc.button.8" is not recognized.
Michel
hal file
# Arrosage (pin 24 OUT)
setp hm2_5i22.0.gpio.024.is_output TRUE
net coolant-flood iocontrol.0.coolant-flood hm2_5i22.0.gpio.024.out
return
mipretec-desktop:~$ emc
This script only needs to be run once per shell session.
EMC2 - 2.4.5
Machine configuration directory is '/home/mipretec/Documents/emc2-dev-rtai/configs/sim'
Machine configuration file is 'mipretec-c104.ini'
Starting EMC2...
CNC1.hal:158: Pin 'moc.button.8' does not exist
Shutting down and cleaning up EMC2...
Cleanup done
EMC terminated with an error. You can find more information in the log:
/home/mipretec/emc_debug.txt
and
/home/mipretec/emc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Michel
hal file
return
EMC2 - 2.4.5
Starting EMC2...
Cleanup done
and
28 Jun 2011 13:17 #10925
michel45 wrote:
I have never used Mocca, but my guess would be that the buttons don't exist until the GUI is loaded.
Move the button 8 "net" statement line to the custom_postgui.hal file.
Hello,
28 Jun 2011 16:06 #10927
by michel45
Hello,
Thank you Andy, why I did not think!
That was the problem.
Michel
Michel
Time to create page: 0.137 seconds
