GUI Discussion
02 Feb 2012 01:09 #17326 by cmorley
Replied by cmorley on topic Re:GUI Discussion
Yes the module name change from emc to linuxccnc.
I don't know how recently 2.5 was merged to master but it should be there.
You may need to make clean;make
to clear out every thing.
and of course you must run linuxcnc from the terminal (I'm sure you know that)
02 Feb 2012 09:37 - 02 Feb 2012 12:26 #17334 by cncbasher
Replied by cncbasher on topic Re:GUI Discussion
older gscreen version runs fine
just this last one version
found one problem and gained another
segfault
(gscreen.py:10990): GtkGLExt-CRITICAL gtk_widget_get_gl_window: assertion 'GTK_WIDGET_REALIZED (widget) failed
Segmentation fault
i see some changes to Gladevcp recently so perhaps related
also
gscreen.py:11438 warning expected enumeration type GtkEntryIconPosition , but got GTKPosition instead
HAL: ERROR
Last edit: 02 Feb 2012 12:26 by cncbasher.
03 Feb 2012 01:23 #17350 by cmorley
I am developing it on 2.5,I will compile master and try it
03 Feb 2012 02:10 #17352 by cmorley
I just pulled and compiled master it worked for me.
you can ignore the warning:
** (gscreen.py:29671): WARNING **: expected enumeration type GtkEntryIconPosition, but got GtkPositionType instead
do you switch between 2.5 and master from the same terminal ? I had to close the terminal and start again.
04 Feb 2012 05:49 #17378 by cmorley
I realize i forgot to mention the new way of loading gscreen
add a line like this to your ini file;
HALCMD = loadusr python /home/chris/glade/gscreen/gscreen.py axis.ini axis.ini
changing the path and config names to match your config.
04 Feb 2012 08:43 #17386 by cncbasher
yes that was it Chris
loading from the ini file sorted it
16 Feb 2012 07:56 #17711 by cmorley
Ok here is a patch file for master to add gscreen as it is now.
It supports lathes better now.
Still experimental!!
need to change the INI entry to:
[DISPLAY]
DISPLAY = gscreen
need a resolution of 1280 x 768 or better 1280 x 1024
File Name: gscreen_master.txt
File Size:265 KB
17 Feb 2012 16:10 #17762 by BigJohnT
Replied by BigJohnT on topic Re:GUI Discussion
Chris,
You might want to start a new thread "Gscreen" :) took me a while to remember where you were talking about it...
Will it run stand alone now?
18 Feb 2012 04:59 #17782 by cmorley
Yes you are right - I will start a new thread.
Yes the last posting is a patch file to add gscreen to master as a stand alone GUI.
But it's still experimental.
Cncbasher is testing it on his setup.
18 Feb 2012 12:05 #17789 by BigJohnT
Nice! I can't wait to see this.
Time to create page: 0.098 seconds
