vismach gui not refreshing
14 Jan 2012 15:15 #16765
by dab77
vismach gui not refreshing was created by dab77
Hi all, i wrote my vismach gui, but it doesn't refresh.
I've net the pins, and checked netting works.
As I start emc2 the window with the picture is drawn, and line points net to hal_pins are drawn at 0, of course.
But then on hal-pins changing drawing doesn't change.
Do you know why?
Thanks, Davide.
Do you know why?
Thanks, Davide.
16 Jan 2012 23:11 - 16 Jan 2012 23:13 #16830
by dab77
Replied by dab77 on topic Re:vismach gui not refreshing [SOLVED]
Last edit: 16 Jan 2012 23:13 by dab77.
14 Jul 2017 18:29 #95798
by Hobietime
Replied by Hobietime on topic Re:vismach gui not refreshing [SOLVED]
Hello Davide.
I am trying to do something similar, but I do not see how to change the size of the lines with halrotate() or haltranslate(). Did you add a scale function?
Caio
Caio
17 Jul 2017 12:04 #95883
by dab77
Hi, a lot of time has passed. I can't remember what i did and cannot easily find the files i used. I'm sorry. Wish can help you as soon as i can.
17 Jul 2017 16:13 #95918
by Hobietime
No problem. The python interface looks quite easy to extend, just wanted to make sure I wasn't needlessly starting from scratch.
Caio
Caio
17 Jul 2017 17:11 #95931
by jstoquica
Replied by jstoquica on topic vismach gui not refreshing
Try to compare with operational GUI (python) configuration files. Some HAL connection may be without properly variable or function.
Regards.
Regards.
