Jogging command failed and Set Origin all axis
- diegoroman17
14 Nov 2012 00:25 #26536
by diegoroman17
Jogging command failed and Set Origin all axis was created by diegoroman17
HI everybody,
I have two problems
I have a GUI with jog buttons. They work fine before of execute a G program, after this they don't work and I have a message in the terminal "can't do that (EMC_AXIS_JOG) in auto mode with the interpreter idle" how I can solution this?
In the middle of Jog buttons I have a button to set the actual position origin of my coordinate system. I think that it is with G53 command but I don't know how set this from my button in my GUI.
Thanks you for your help.
I have two problems
14 Nov 2012 01:19 - 14 Nov 2012 01:27 #26540
by BigJohnT
Replied by BigJohnT on topic Jogging command failed and Set Origin all axis
You need to change the mode back to manual or mdi I forget which.
Some clues here
linuxcnc.org/docs/html/common/python-int...ing_to_send_commands
Some clues here
Last edit: 14 Nov 2012 01:27 by BigJohnT.
14 Nov 2012 03:32 - 14 Nov 2012 03:35 #26545
by BigJohnT
This is one of my jog buttons
In my __init__ is the following
My jog x plus button. See how I check for manual mode and if needed change the mode.
self.cnc = linuxcnc
self.s = self.cnc.stat()
self.c = self.cnc.command()
def on_jog_x_plus_pressed(self, widget, data=None):
self.s.poll()
if self.s.task_mode != self.cnc.MODE_MANUAL:
self.c.mode(self.cnc.MODE_MANUAL)
self.c.wait_complete()
if self.builder.get_object("jog_speed").get_value() > 0:
self.c.jog(self.cnc.JOG_CONTINUOUS, 0, self.builder.get_object("jog_speed").get_value() / 60)
Last edit: 14 Nov 2012 03:35 by BigJohnT.
- diegoroman17
14 Nov 2012 04:26 #26551
by diegoroman17
Replied by diegoroman17 on topic Jogging command failed and Set Origin all axis
Thank you John, now it work
Now can you help me with a action update G Code program without use Update Action in GladeVCP. I want update my current G Code program in phyton code.
14 Nov 2012 04:52 #26553
by BigJohnT
My guess is it is one of these commands
program_open(string)
open an NGC file.
reset_interpreter()
reset the RS274NGC interpreter
open an NGC file.
reset_interpreter()
- diegoroman17
15 Nov 2012 04:44 #26595
by diegoroman17
Neither command works. I tried in MDI mode, in AUTO mode and don't have any result. I tried in MANUAL mode and in my terminal appear a message that say can't do that (EMC_TASK_PLAN_OPEN) in manual mode. And with update action of GladeVCP this work. How this work?
- diegoroman17
15 Nov 2012 07:42 #26599
by diegoroman17
I have solved my problem by assigning both hal_reload_action and an activation signal to my button.
Now can anyone help me with the clean of gremlin component?
15 Nov 2012 16:07 #26614
Replied by cmorley on topic Jogging command failed and Set Origin all axis
answered that already here:
www.linuxcnc.org/index.php/english/forum...utomatic-home-action
Time to create page: 0.267 seconds
