Touch screen setup GUI
29 Jan 2013 05:54 #29241
by viski
Touch screen setup GUI was created by viski
Hi!
I bought 19'' touch monitor and try touch screen GUI example but it doesnt work.
Do i have to install it under linux first and configure?
How to do it?
How to do it?
29 Jan 2013 06:00 #29242
by BigJohnT
Replied by BigJohnT on topic Touch screen setup GUI
Yea, you need to install drivers in Ubuntu to make it work. Searching on the web is how I figured out how to get one to work for me
What model touch screen do you have?
30 Jan 2013 01:07 #29272
by viski
Replied by viski on topic Touch screen setup GUI
Elo touch screen monitor.
www.elotouch.com/Support/Downloads/dnld.asp
Do i have to change it to DISPLAY= touchy or could it be AXIS ?
If i change it i would have a lot of work with spindle speed bar to view actual RPM from encoder.
30 Jan 2013 01:43 #29275
by BigJohnT
I use Axis with a touch screen until I get my custom GUI done...
31 Jan 2013 05:23 #29338
by viski
How to install drivers?
31 Jan 2013 08:15 #29345
by BigJohnT
It's a Ubuntu thing so I googled for ELO Ubuntu 10.04 till I found the page.
- beltramidave
- Thank you received: 4
27 Feb 2013 23:02 #30652
by beltramidave
Replied by beltramidave on topic Touch screen setup GUI
John,
How is your touch screen working for you? Can you tell me what model you have? To use the monitor with Touchy instead of Axis, is it as simple as changing the 'Display = Touchy' in the .ini file?
Thank you
Thank you
27 Feb 2013 23:56 #30654
by BigJohnT
I have two ELO touch screens and both are Intellitouch models with both serial and USB. The one on the BP is an ELO 1515L Model # E700813.
Not quite that simple, to use Touchy it requires at least two hardwired buttons to work and a MPG of some sort to jog.
I used Evtouch to connect the touch part to Ubuntu and had to hand edit the config file to get the XY scale correct.
- beltramidave
28 Feb 2013 00:33 #30655
by beltramidave
Thank you, I will have to look into Evtouch to see what that is. Would you be interested in sharing what you had to do to the config file when/if I get to that stage?
Thanks again!
Thanks again!
28 Feb 2013 00:42 #30656
by BigJohnT
I always share...
Time to create page: 0.093 seconds
