pyngcgui
02 Feb 2013 20:08 - 02 Feb 2013 20:17 #29481
by BigJohnT
Just to give you a preview of what Dewey has been up to here is a screen shot of the new pyngcgui with touchy.
Seems like Add File is broken on Firefox, Opera, IE, Chrome...
imagebin.org/245192
imagebin.org/245192
Last edit: 02 Feb 2013 20:17 by BigJohnT.
03 Feb 2013 05:14 #29508
by dgarrett
patch and instructions for rip build as a test branch (v2.5_branch) are at:
www.panix.com/~dgarrett/pyngcgui/
04 Feb 2013 17:17 #29552
I briefly tried this out.
I have not ever use ngcgui before.
I need a help button. first thing I thought was what is XYZ for? what's a gosper ?
on the programming side:
I think the popup keyboard should also be a gladevcp widget - very handy.
But It's going to break fullscreen GUIs -ask me how I know I have this same problem with Gscreen.
When the dialog pops it will make the top and bottom bars show.
There are some specific things that can be done to fix that but there may be some drawbacks too - I'm researching.
I would suggest that in your sample TOUCHY config you add a gladeVCP panel that has a HAL_gremlin.
then you can see what you made before you run it.
Very nice work !
Chris M
Very nice work !
Chris M
04 Feb 2013 18:07 #29557
linuxcnc.org/docs/html/gui/ngcgui.html
The new thing here is not the GUI (it's just normal "Touchy") but the integration of ngcgui which is somewhere between a macro language and a conversational programming interface.What does this have not have? Benifits over current GUI's?
