pyngcgui
04 Feb 2013 20:07 #29561
by tjamscad
Thanks, Andy. I don think this is something that I would use in a production shop. But, I can see that it would be useful for a smaller 1 or 2 guys size shop.
The new thing here is not the GUI (it's just normal "Touchy") but the integration of ngcgui which is somewhere between a macro language and a conversational programming interface.What does this have not have? Benifits over current GUI's?
linuxcnc.org/docs/html/gui/ngcgui.html
04 Feb 2013 20:28 #29563
by BigJohnT
It really doesn't matter how many guys you have in the shop but what kind of things your making. If you doing production work your needs are 180 degrees out from people doing one-off''s and people building custom design equipment. If you have a lathe that does one-off's then your missing the boat by not using the power of ngcgui. I can take a print and walk up to my Hardinge CHNC and in a minute have a part running on the lathe from start to finish. It takes me longer to change the collet than it does to program the part in.
04 Feb 2013 20:38 #29564
by BigJohnT
The sample subroutines may be a bit confusing but they are working samples. The DB25 sample will mill out a hole for a DB25 shell and that is pretty neat.
By top and bottom bars are you talking about the title bar?
I briefly tried this out.
I have not ever use ngcgui before.
I need a help button. first thing I thought was what is XYZ for? what's a gosper ?
on the programming side:
I think the popup keyboard should also be a gladevcp widget - very handy.
But It's going to break fullscreen GUIs -ask me how I know I have this same problem with Gscreen.
When the dialog pops it will make the top and bottom bars show.
There are some specific things that can be done to fix that but there may be some drawbacks too - I'm researching.
I would suggest that in your sample TOUCHY config you add a gladeVCP panel that has a HAL_gremlin.
then you can see what you made before you run it.
Very nice work !
Chris M
04 Feb 2013 22:13 #29570
by tjamscad
Good point John, If you were doing one-of type of work that didnt need a model and a drawing it would come in handy to have a macro-wizzard type of thing to use. I am not trying to say what you have here is bad it just doens't fit my enviorment. Sorry for the disruption.
26 May 2013 01:52 #34696
by dgarrett
i haven't looked at pyngcgui for a while but a current patchset (for git-master) is at:
www.panix.com/~dgarrett/pyngcgui/v043.patch
The patched code includes gladevcp widgets for:
PyNgcGui -- compatible with the existing tcl implementation of ngcgui
Hal_GremlinPlus -- a gremlin viewer with some built-in buttons
Included demonstration configs are:
configs/sim/ngcgui/pyngcgui_gscreen.ini
configs/sim/ngcgui/pyngcgui_gscreen_popupkeyboard.ini
and (non-gladevcp) demos for touchy:
configs/sim/ngcgui/pyngcgui_touchy.ini
configs/sim/ngcgui/pyngcgui_touchy2.ini
configs/sim/ngcgui/pyngcgui_touchy_lathe.ini
configs/sim/ngcgui/pyngcgui_touchy_small.ini
These sim configs work with (existing) ngcgui-compatible gcode files
like the ones located in nc_files/ngcgui_lib
Also included are standalone applications:
gremlin_view (use --help for info)
pyngcgui (use --help for info)
To try in a rip build::
$ cd src # the src directory in a git clone
$ git pull # make sure master is up-to-date
$ git checkout master # start in master branch
$ git branch ptst # make a test branch
$ git checkout ptst # use the new test branch
$ git am v043.patch # apply the patch
$ make && sudo make setuid # build
$ . ../scripts/rip-environment # ensure environment in all shells
$ linuxcnc ../configs/sim/ngcgui/pyngcgui_gscreen.ini
etc.
If you start another terminal to try the standalone applications be
sure to source rip-environemnt there too
etc.
10 Jun 2013 02:52 - 10 Jun 2013 03:05 #35474
by dgarrett
pyngcgui update:
The latest patch (v045) for git master includes:
1) gladevcp widget: Python Ngcgui -- pyngcgui (uses ini options NGCGUI_*)
2) gladevcp widget: Hal Gremlin Plus -- hal_gremlin with some buttons
3) standalone pyngcgui (for help: pyngcgui -h)
4) standalone gremlin_view (for help: gremlin_view -h)
5) a popup numeric keyboard suitable for touchscreen usage
6) 4 example ini files based on touchy (includes gremlin)
7) 2 example ini files based on gscreen
8) 1 example ini file based on axis
(compatibilty demo, the tcl based ngcgui integrates better with axis)
The patch is at:
www.panix.com/~dgarrett/pyngcgui/v045.patch
Instructions for applying the patch:
www.panix.com/~dgarrett/pyngcgui/pyngcgui.txt
The patch is at:
Last edit: 10 Jun 2013 03:05 by dgarrett.
10 Jun 2013 09:57 #35479
by dgarrett
I think it is ready but could benefit from tests by users. That would be simplified if it were in master and available with a buildbot package instead of requiring a user to patch the source tree.
The patch is mostly new code and is thus a non-interfering set of changes. There are a few code changes to touchy to let it (optionally) include gremlin and pyngcgui. Cradek will probably want to review.
Time to create page: 0.402 seconds
