pyngcgui
- Zahnrad Kopf
- Thank you received: 3
11 Jun 2013 09:37 #35515
by Zahnrad Kopf
Replied by Zahnrad Kopf on topic pyngcgui
Okay, so for someone that has just built the PC and installed LCNC ( with some amazingly wonderful assistance from cncbasher ), how would one add this to their setup?
11 Jun 2013 14:05 #35520
by cncbasher
adding pyngcgui to your emc2-dev git repro is simple enough
however running it in gui's such as gmoccapy , requires adding and editing code at the moment it does not seem to want to work in gmoccapy , although iv'e not had much time to look at this , I feel some editing of the gui may be required further .
it does work in other gui's available .
so should not be difficult to merge into the newer glade gui's , so it's work in progress
11 Jun 2013 19:03 #35528
by BigJohnT
This is a touch screen GUI just so you know. If you don't have a touch screen the Axis GUI is the best one to use.
In a nutshell you have to install git, pull master, add the patch, then run master as a RIP (Run In Place).
I can get the specifics after breakfast if you like...
JT
JT
- Zahnrad Kopf
11 Jun 2013 22:40 #35535
by Zahnrad Kopf
Ah. Okay. I'll wait till it's been worked out then. Thanks.
however running it in gui's such as gmoccapy , requires adding and editing code at the moment it does not seem to want to work in gmoccapy , although iv'e not had much time to look at this , I feel some editing of the gui may be required further . it does work in other gui's available . so should not be difficult to merge into the newer glade gui's , so it's work in progress
- Zahnrad Kopf
11 Jun 2013 22:45 #35536
by Zahnrad Kopf
Thanks John. By way of heads-up, yes, I did put a touch screen on the box I built for the Emco turning center. I did it specifically because I want to give gmoccapy a try. Frankly, I was pretty excited when cncbasher showed it to me. Very nice. So being able to have this with it would be quite nice. Still if I have to exit out and use ngcgui for now, that is fine too. Thanks.
This is a touch screen GUI just so you know. If you don't have a touch screen the Axis GUI is the best one to use. In a nutshell you have to install git, pull master, add the patch, then run master as a RIP (Run In Place). I can get the specifics after breakfast if you like...
JT
11 Jun 2013 22:55 #35539
by dgarrett
Patch updated:
www.panix.com/~dgarrett/pyngcgui/v046.patch
Instructions (git master reqd):
www.panix.com/~dgarrett/pyngcgui/pyngcgui.txt
Example ini files are:
configs/sim/ngcgui/pyngcgui_touchy.ini
configs/sim/ngcgui/pyngcgui_touchy_lathe.ini
configs/sim/ngcgui/pyngcgui_gscreen.ini
configs/sim/ngcgui/pyngcgui_gscreen_popupkeyboard.ini
configs/sim/ngcgui/pyngcgui_axis.ini
configs/sim/gmoccapy/pyngcgui_gmoccapy.ini
configs/sim/gmoccapy/pyngcgui_gmoccapy_popupkeyboard.ini
The pyngcgui_gmoccapy demo is kind of a kludge but shows embedded usage
of both pyngcgui and gremlin_view.
? the examples included, at least in this patch, don't require any editing of code -- please explain what needs editing if you try this patch
08 Jul 2013 22:44 #36405
by dgarrett
Pyngcgui has been added to linuxcnc git master and is now available with recent buildbot debs. (buildbot.linuxcnc.org/)
The ini demo files illustrate how to add Pyngcgui and Gremlinview tab pages to several guis:
Touchy (with popupkeyboard for touch screen usage)
Gscreen
Gmoccapy
configs/sim/gmoccapy/pyngcgui_gmoccapy_with_popupkeyboard.ini
(for feasibilty demonstration only)
( requires an existing ngcgui config for links)
( not all of gmoccapy files are copied by the config picker)
Axis
(included for completeness)
(the original ngcgui (tcl version) integrates more completely with axis)
Also provided are standalone apps named gremlin_view and pyngcgui.
For options, use:
$ gremlin_view --help
$ pyngcgui --help
Gscreen
Gmoccapy
Axis
For options, use:
$ pyngcgui --help
Time to create page: 0.135 seconds
