Lathe Macros
16 Dec 2014 21:38 #54063
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Lathe Macros
I have it under the sim directory of the 2.7.0. I am not sure if I put it there myself but I dont think so.
Regards
Marius
www.bluearccnc.com
16 Dec 2014 21:54 #54065
Replied by andypugh on topic Lathe Macros
I have put an updated file in the first post.
The difference is a more logical sequence of events on toolchange and that there is now a button to load a tool.
(Also, this is my current working version of each file).
I have remembered that the ability to do in-box unit conversions isn't part of this config, it is something I did to _all_ HAL widgets in the widget handler:
thread.gmane.org/gmane.linux.distributions.emc.devel/13550
17 Dec 2014 11:47 #54081
by drogge
Replied by drogge on topic Lathe Macros
Thanks again andy. I'll give it a shot tomorrow.
Drew
Drew
17 Dec 2014 16:34 #54089
by mariusl
Ok it looks like I put it there myself but I see no reason why it cannot be placed in the distro. How do I go about voting to get it in the sim directory officially?
Regards
Marius
www.bluearccnc.com
Regards
Marius
www.bluearccnc.com
18 Dec 2014 14:43 #54114
by drogge
Hi andy,
It looks like there's a bug in all the .ngc files where variable #2 is used in the "G96 D1500 S#2 ; Constant Surface Speed" lines before it's set. The fix I tried was to move the setting of the #1 thru #8 vars to the beginning of the subroutines. That seems to work.
Drew
Drew
18 Dec 2014 19:24 #54119
One change I made was to move them all to after the "setup" codes. This was to prevent tool crashes when the positions are read in before the tool offset was applied.
It looks like I need to have a more careful think about this.
I also may decide to send the numbers from the GUI to the subroutines as parameters, so that the NGC code does not have to use the "experimental" ability to read HAL pins directly.
19 Dec 2014 05:12 #54149
by drogge
Since only the variables 1 thru 8 have been moved above the setup code then the position code shouldn't be affected. It's not much different than passing things in as parameters.
22 Dec 2014 08:02 #54199
by kjacobs
Karl
Replied by kjacobs on topic Lathe Macros
For me, the zip file comes up with an empty "lathemacro.hal" file which is the POSTGUI_HALFILE according to the .ini file, and from what I know that file should contain the _hal[gladevcp.turn.z-f] ... definitions? linuxcnc complains.I have put an updated file in the first post.
Karl
22 Dec 2014 08:10 #54200
by drogge
Drew
Mine is zero length too but it doesn't seem to matter. The problem you're having may be that your linuxcnc is too old. I thing the _hal stuff showed up in 2.6. I'm running 2.6.5.
Karl
Drew
22 Dec 2014 14:53 #54207
by kjacobs
I am running 2.7.0~pre on the machinekit branch, The problem may be in that branch, then. The gladevcp panel and everything else comes up fine.
Mine is zero length too but it doesn't seem to matter. The problem you're having may be that your linuxcnc is too old. I thing the _hal stuff showed up in 2.6. I'm running 2.6.5.I have put an updated file in the first post.
Drew
Karl
Time to create page: 0.235 seconds
