Best GUI for touch and 4th axis
28 Jul 2013 19:07 #37149 by cncbasher
Marius,
pyngcgui is added to the latest version of gmoccapy and latest verson of linuxcnc
28 Jul 2013 20:00 #37158 by mariusl
Norbert,
I just checked but could not see any config for Gmoccapy with pyngcgui. I tested all the others.
When was it pushed?
Regards
Marius
www.bluearccnc.com
28 Jul 2013 20:40 #37161 by newbynobi
It has been pushed I think with version 0.9.5,
The actual version is gmoccapy 0.9.6 you can look for the version you get in the title bar.
There should be two INI files for pyngcgui.
pyngcgui_gmoccapy.ini
pyngcgui_gmoccapy_with_popupkeyboard.ini
This INIS does not come from my hand. They came from the pyngc developer.
Norbert
28 Jul 2013 23:51 - 28 Jul 2013 23:53 #37173 by mariusl
Ok I found it after a fresh pull.
I did the following and get an error: I copied the gmoccapy.glade, gmoccapy_handler.py, gmocca_handler.pyc to my config. I also changed the gscreen call to this:- DISPLAY = gscreen -c gmoccapy -d.
Down the bottom of the dump there is a line that says "unknown Axis 4" I attached the error file.
File Name: error_dump.txt
File Size:17 KB
File Name: bluearc_mill.ini
File Size:7 KB
Regards
Marius
www.bluearccnc.com
Last edit: 28 Jul 2013 23:53 by mariusl.
29 Jul 2013 00:22 #37176 by newbynobi
Hallo Marius,
I have not seen your hal File, I do hope that the error is there,
You have an error in your ini file, there is not widget notebook_main, it must be named ntb_main.
And you have a base thread of 0, plase try with 10000
Please check your hal file.
Norbert
29 Jul 2013 00:43 #37177 by mariusl
Norbert
My HAL file works with Gscreen but I attached it anyway. I copied the example code into my INI file as is. The error is still the same.
Regards
Marius
www.bluearccnc.com
29 Jul 2013 01:08 #37178 by cncbasher
Marius ,
I think the problem is with the hidden preferences config file not being the latest etc , open the settings page in gmoccapy and then exit and restart , so it re-saves the newer format
29 Jul 2013 01:45 #37180 by mariusl
I deleted the hidden file and still the same. I attached a snapshot of the first error.
Regards
Marius
www.bluearccnc.com
29 Jul 2013 03:14 #37183 by newbynobi
Hallo Marius,
the error image is showing only one of the 5 errors witch are launched? Am I correct, I need the last one to go on.
I am verry surprised, because your version does throw the error "unknown axis 4"
This message should come normaly from gmoccapy, but I have not include such a message ???
Please start gmoccapy.ini from sim and look about the version, I am sure, you have mixed something around.
Does gmoccapy_4_axis.ini load without an error?
Have you Tried to start your config, just with 3 axis?
Norbert
29 Jul 2013 03:38 #37185 by mariusl
I included it below
It is 0.9.6
Yes no problem
Takes a long time to start and the errors remain.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.390 seconds
