Touchy update?
10 Jul 2013 01:13 #36461
by tjamscad
Touchy update? was created by tjamscad
Issuing EMC_TRAJ_SET_ROTATION -- (+226,+20, +0,0.000000,)
/home/swatson/linuxcnc-simulator/bin/touchy:81: GtkWarning: _gdk_drawable_get_source_drawable: assertion `GDK_IS_DRAWABLE (drawable)' failed
pix = gtk.gdk.pixmap_create_from_data(None, pix_data, 1, 1, 1, color, color)
ini /home/swatson/linuxcnc-simulator/configs/sim/touchy.ini
File "/home/swatson/linuxcnc-simulator/bin/touchy", line 824, in <module>
hwg = touchy(sys.argv[2])
File "/home/swatson/linuxcnc-simulator/bin/touchy", line 208, in __init__
self.filechooser = filechooser.filechooser(gtk, linuxcnc, filechooser_labels, filechooser_eventboxes, self.listing)
File "/home/swatson/linuxcnc-simulator/lib/python/touchy/filechooser.py", line 26, in __init__
self.reload(0)
File "/home/swatson/linuxcnc-simulator/lib/python/touchy/filechooser.py", line 85, in reload
self.files = os.listdir(self.dir)
OSError: [Errno 2] No such file or directory: '/home/swatson/linuxcnc/nc_files'
Cleanup done
LinuxCNC terminated with an error. You can find more information in the log:
/home/swatson/linuxcnc_debug.txt
and
/home/swatson/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
self.reload(0)
Cleanup done
and
10 Jul 2013 21:11 #36499
by tjamscad
Replied by tjamscad on topic Touchy update?
reply from Chris Radek
You need to create this directory. This is where it looks for gcode
files.
When we did the rebranding from emc2 to linuxcnc, this changed. You
might have custom configs there too; you'll want to just rename the
directory if so.
files.
directory if so.
Time to create page: 0.283 seconds
