Gscreen keyboard usage
29 Jul 2013 00:19 #37175
by mariusl
Regards
Marius
www.bluearccnc.com
Gscreen keyboard usage was created by mariusl
I am having trouble understanding or getting the keyboard to work with Gscreen. How do I use the pop-up keyboard to edit the tool table for instance? I am still running on the desktop without a touch screen using the mouse pointer. Does this matter?
Regards
Marius
www.bluearccnc.com
29 Jul 2013 11:12 #37194
Replied by cmorley on topic Gscreen keyboard usage
What problem are you having with the keyboard?
I did notice that with a mouse the keyboard tended to repeat the letters sometimes, this didn't happen with the touch screen.
Chris M
Chris M
29 Jul 2013 14:18 #37197
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gscreen keyboard usage
The field that must receive the characters looses focus and the input is not transferred to the field. I tried to edit the tool table but it seems impossible. That is why I thought that maybe it will only work if you have no keyboard.
Regards
Marius
www.bluearccnc.com
29 Jul 2013 14:35 #37198
Never had that problem. What version of linux are you using?
29 Jul 2013 15:29 #37199
by mariusl
Regards
Marius
www.bluearccnc.com
The latest master on 10.04
Regards
Marius
www.bluearccnc.com
30 Jul 2013 00:07 #37237
thats what I use.
So you pop the keyboard up
click a tooledit checkbox and then a column to edit
then when you click the keyboard it does nor show on the column?
Have you tried it in other places?
Chris M
Chris M
30 Jul 2013 00:44 #37238
by mariusl
Regards
Marius
www.bluearccnc.com
I pop up the keyboard. Click the tool editor line - the keyboard disappears.
Then I try this - click the line to edit, click the field, pop up the keyboard. The field closes and nothing transfers to the field.
MDI works OK, I have not tested it anywhere else.
Regards
Marius
www.bluearccnc.com
30 Jul 2013 00:50 #37239
Ok I see the difference. You are using full screen, I am not.
Industrial doesn't have this problem because the keyboard is not a separate window.
I will see what I can do about it.
Chris M
Chris M
30 Jul 2013 12:38 #37252
Ok I pushed a reasonable fix for this problem.
Give it a spin please.
Chris M
Chris M
The following user(s) said Thank You: mariusl
30 Jul 2013 14:21 #37255
by mariusl
Regards
Marius
www.bluearccnc.com
Chis
Works really well now thanks. It does not cause the desktop tool bars to pop up anymore either.
Regards
Marius
www.bluearccnc.com
